Rear jack stand placement - Mustang Evolution
Old 07-10-2015, 09:24 PM   #1
Jvibe92's Avatar
Can you place the jack stands on the body rail just inside of where the pinch welds are?
Ex
Name:	ImageUploadedByMustang Evolution1436585058.781441.jpg
Jvibe92 is offline   Reply With Quote
Old 07-10-2015, 09:32 PM   #2
Rynarok's Avatar
If I don't need the rear suspension unloaded I will place my jackstands under the rear axle on each side.
I'm finicky about using non-standard lift points for weight bearing. Be very careful to not punch through or bend the hell out of your floorpan.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 07-10-2015, 10:17 PM   #3
olerodder's Avatar
Region: Oregon
When I'm on a lift I always put the arms just in front of the LCA mount.
Here is a picture on the lift.
As was mentioned if you don't need to have the rear end loose I'd jack it up from under the center section and put jack stand under each side of the axle housing.
Name:	2015-05-27 11.14.51 (2)123.jpg
Old 07-10-2015, 10:33 PM   #4
Jvibe92's Avatar
I need the suspension unloaded. I just switched it to under the pinch welds. Needed to jack it up tonight to do the work tomorrow. Trying to get everything off so tomorrow I can just put stuff on. Plus it gets to hot here in Texas so the garage only stays "cool" for so long.
Right now I got it in the pinch welds without a block on both sides and my jack that came with the car on one side as an aid
Old 07-13-2015, 10:17 AM   #5
Voltwings's Avatar
There's cut outs in the pinch weld for jack stands. There's literally even Arrows on the body work pointing to where they are.
Old 07-13-2015, 08:05 PM   #6
Jvibe92's Avatar
I understand. Clearly I stated I knew of those positions. Just wondering on other placements since my jack doesn't fit those cutouts too well. That's why I was using the nearest body frame as a prospective position
Old 07-14-2015, 06:46 AM   #7
Voltwings's Avatar
Jack the front by the K-member and the rear by the diff and you'll have all the room in the world.
2013 rear jack stand placement question Jvibe92 General Mustang Discussion 1 07-10-2015 06:40 PM
Jack & jack stand point Otis 2011-2014 V6 Mustang 6 10-15-2013 12:48 AM
2013 Jack Placement in Trunk? kdbdallas 2011-2014 V6 Mustang 25 05-30-2013 03:32 AM
Jack Stand Competition Spark Plug The Bar 24 08-16-2008 05:49 PM
Jack stand positioning 00stang3.8 Pre-2005 V6 Mustang 6 05-27-2007 04:50 PM
08:33 AM
