How a boost a pump works? - Mustang Evolution
Old 07-12-2015, 10:59 AM   #1
RJ13GT's Avatar
So tell me if i'm wrong. The computer controls and varies what voltage the fuel pump runs at depending on fuel demands. And the boost a pump doesn't do anything unless the computer commands more voltage than is available from the charging system?
Sent from my SCH-I545 using Tapatalk
2013 5.0, Black, Auto, Procharger P1SC stg 2, 4.13'' pulley(8 psi), JMS bap, 3'' x pipe, Circle D 3c, Kooks axleback, BMR control arms. 593rwhp
RJ13GT is offline   Reply With Quote
Old 07-12-2015, 11:04 PM   #2
olerodder's Avatar
Region: Oregon
I'm sure there are people on here that can explain it better than myself and since it's been a few years since I've boosted a motor I'll try and work through this so bare with me.
The EEC Feedback Loop Control and Fuel Pressure Feedback Sensor work in conjunction with the EEC monitoring constant signals from the FPFS. The EEC takes the signals from the FPFS and switches the voltage to ground either quickly or slowly....the duty cycle of the pump...........which is dependant upon demand coming from the FPFS on the fuel rail.
So, yes the boost a pump although dormant for a small portion of the time can allow the OE pump to be more efficient and also output more flow at the same pressure.
Just a question, why are you asking this? Are you wanting to no install a boost a pump..........go to a larger pump..............install larger injectors.
Old 07-13-2015, 06:14 AM   #3
RJ13GT's Avatar
I have already installed a JMS boost activated boost a pump and have seen no changes in how my fuel pressure acts. So I was trying to figure out how the thing actually works in conjunction with the ECU. I've tested the boost a pump. It looks to be working. The light flashes and voltage is increased when tested. I tested it from the source at the engine to make sure there are no kinks or whatever in the line. I went ahead and bought and installed the BAP because I'm going to a smaller pulley and exhaust, bigger injectors and a more aggressive tune. I just want to make sure the thing is working properly before we get into tuning and find out it isn't. I just think I had the wrong idea about how it was supposed to work.
Old 07-13-2015, 06:25 AM   #4
Rapinator126's Avatar
It's working fine.
A BAP is not going to change your fuel pressure. It simply adds more voltage to the pump increasing it's flow of fuel.
Old 07-13-2015, 06:56 AM   #5
RJ13GT's Avatar
Originally Posted by Rapinator126 View Post
It's working fine.
Ok yeah i just had the idea it would stabilize the pressure. Its more of a volume thing i see. I will roll with it then. Lol!
Old 07-13-2015, 08:39 AM   #6
Droidman86's Avatar
I've actually been thinking about this too.
Is there a way to check if the BAP is actually doing it's job, working correctly?
2012 Mustang 5.0
Steeda CAI, Boss Manifold, 3.73 Gears, E85, NX Wet 150 Shot, AED Tuned, LT Headers, Aluminum Driveshaft, Mcleod Twin Disc Clutch, KB Bap, N2MB wot box w/ window switch.
Droidman86 is offline   Reply With Quote
Old 07-13-2015, 03:48 PM   #7
RJ13GT's Avatar
All I know is probe the wire (white wire on the JMS unit) and activate it and make sure the voltage is stepped up.
Old 07-14-2015, 07:09 AM   #8
RJ13GT's Avatar
Well after a period of googling I have found out that the Coyote fuel pump has a high speed threshold. The pump is pretty much set to run full speed always with an internal relief valve set at 58 psi and the computer cuts it back under low load conditions. So unless you go into the tune and raise the high speed threshold you are only going to get so much flow out of it.
Boost line for boost gauge TooSlow4U 2011-2014 Mustang GT 0 07-20-2012 09:34 PM
Keene bell boost a pump install HELP Gibby Saleen & SMS Mustang 4 06-22-2012 06:20 PM
kenne bell boost a pump syrupsaleen Saleen & SMS Mustang 128 04-12-2012 11:26 AM
KB Boost A Pump SaleenFiend Mustang Parts for Sale and Wanted 18 03-05-2010 08:47 AM
05:45 PM
