When to get alignment after lowering - Mustang Evolution
Old 07-14-2015, 11:45 AM   #1
Fax22's Avatar
I just made a post regarding lowering but i thought i would make a new thread for this topic specifically
I was wondering when the best time to get the car aligned after getting it lowered. I know the springs need to settle first, but should i go ahead and adjust the panhard bar the same day i install the springs or wait until they settle, adjust the bar, and then get an alignment?
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Fax22 is offline   Reply With Quote
Old 07-14-2015, 03:51 PM   #2
bazinga11's Avatar
What suspension mods are you going to install? Is it a DD? Are you getting camber plates?
Sent from my SGH-I337M using Mustang Evolution mobile app
Old 07-14-2015, 04:00 PM   #3
Fax22's Avatar
Im getting koni orange dampers, j&m cc plates, j&m panhard bar and sr springs. And yes its a dd
Old 07-14-2015, 05:31 PM   #4
Mean14's Avatar
The install sheet said to wait two weeks and then get an alignment done. I waited about a month and then got one. As long as you wait a decent amount of time and not get one within the first week, you'll be good.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 07-14-2015, 06:17 PM   #5
Fax22's Avatar
But should i wait that long to adjust the panhard bar too
Old 07-14-2015, 07:11 PM   #6
BlackBetty5.0's Avatar
No, adjust that when you install it. the axle will shift a little with the drop and you can get it centered right off the bat.
BlackBetty5.0 is offline   Reply With Quote
Old 07-14-2015, 07:11 PM   #7
Fax22's Avatar
Ok thank you
Old 07-14-2015, 08:03 PM   #8
olerodder's Avatar
Region: Oregon
I'm not sure if I mentioned this on your other thread but if you have an iPhone I would suggest you get the app called ialign. It will give you a very accurate indication of where you are at before going to the line-up shop.
I've used it for a number of years on my race car trying different caster/camber combinations.
ialign
Old 07-14-2015, 08:12 PM   #9
Fax22's Avatar
Thanks but i have a S6 so maybe if there is a comparable android app, i would give it a shot
Old 07-16-2015, 10:16 PM   #10
I did mine the same day i did the drop
WundrbreadzDEAD is offline   Reply With Quote
Alignment needed after lowering springs? brittney18 2011-2014 V6 Mustang 6 01-14-2014 11:48 AM
Alignment after lowering robin_gt 1996-2004 Mustang GT 10 12-15-2013 10:33 AM
Alignment after lowering my car question Spiney 1996-2004 Mustang GT 11 10-08-2013 06:44 PM
Do i need a Wheel alignment after installing new wheels Mdazi 2011-2014 Mustang GT 8 05-29-2013 02:50 PM
Same problem after alignment Venomouz831 1996-2004 Mustang GT 46 03-24-2013 07:09 AM
03:07 AM
