Brake upgrade clearance - Mustang Evolution
Old 07-15-2015, 08:35 AM   #1
Planning on switching over to brembos. Just did my wheels offsets are +28 in the front and +35 in the rear....will I clear brembo calipers? ?
Jstorm is offline   Reply With Quote
Old 07-15-2015, 08:43 AM   #2
Kevin.Cook
Guest
Posts: n/a
What do your rims look like? I would suggest at least 19" rims. Some say 18s have worked but I would not risk it, plus people usually like the aggressive look of bigger rims.
With my 14' V6 PP rims with 255/40/19s I needed 1/2" wheel spacers to clear the rims. Those rims were 19x8.5. However, I now have 15' GT PP replica rims that are 19x8.5 with the same 255/40/19 tire and they clear them fine. Each type of rim is different, usually the spoke clearance is the biggest hurdle.
Old 07-15-2015, 08:44 AM   #3
There 20x8.5 and 20x10.5 kmc 685 districts
Old 07-15-2015, 09:00 AM   #4
Kevin.Cook
Guest
Posts: n/a
The only ones I'd worry about are the front. If you are going Brembo, I think they have a template you could try using to check.
Something like this might give an idea. Might not be "exact" though. Wheel fitment template for Brembo Big Brake Systems
Old 07-15-2015, 09:07 AM   #5
Socal Stangman's Avatar
Based on what I think I know the +28 might be an issue. I have some Rohana RC10's +35 and they clear my Brembo's but there isnt a ton of extra space. I would check with the manufacturer. Worst case since its only an 8.5" wheel you could run a spacer.
Old 07-15-2015, 09:19 AM   #6
Kevin.Cook
Guest
Posts: n/a
Originally Posted by Socal Stangman View Post
Based on what I think I know the +28 might be an issue. I have some Rohana RC10's and they clear my Brembo's but there isnt a ton of extra space. I would check with the manufacturer. Worst case since its only an 8.5" wheel you could run a spacer.
THIS! Also, depending how much stud is left after the spacer, you might either need longer studs OR they sell spacers w/ studs in them.
Old 07-15-2015, 11:31 AM   #7
c_rizzle's Avatar
There's more to the fit than just offset. The thickness of the spokes is what makes or breaks you with the Brembo fitment.
My TSW wheels fit with only 20mm offset with Brembo brakes.
Front wheel Specs:
Diameter 19"
Width 8.5"
Offset +20 mm.
Backspacing 5.5 in.
c_rizzle is offline   Reply With Quote
Old 07-15-2015, 11:53 AM   #8
This is why its best to check with the manufacturer for fitment.
Old 07-15-2015, 02:57 PM   #9
c_rizzle's Avatar
Most don't know. They'll ask you something stupid like is it for a V6 or V8, then "yes it fits".
I've found tirerack's website to be pretty good at fitment checking. IF they sell what you're looking for.
Old 07-15-2015, 04:56 PM   #10
To be honest if I called the manufacturer and they dont know the answer, Id be buying from a different company.
Old 07-15-2015, 05:10 PM   #11
jande063's Avatar
Keep in mind that the FRONT studs (just the front ten) will run you $120. I went with a set of ARPs with a small spacer so I could add some camber at the bottom of the strut with my wider wheels.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 07-15-2015, 06:25 PM   #12
bazinga11's Avatar
Are you going with brembo 4 or 6 pistons? I know on late model it says 6 pistons will only clear sve drifts and ford racing wheels. Call them, they will be able to answer your question since they carry KMC districts
Sent from my SGH-I337M using Mustang Evolution mobile app
Old 07-16-2015, 12:40 PM   #13
c_rizzle's Avatar
To be honest if I called the manufacturer and they don't know the answer, I'd be buying from a different company.
My point is they'll probably say some crap like "Yes, it should, but we don't guarantee it." just to get the sale.
Then you can't return b/c they said they didn't guarantee it would fit.
Old 07-16-2015, 01:04 PM   #14
bazinga11's Avatar
There you go. They won't clear brembos unless you use a minimum 1/8" spacer
Old 07-16-2015, 01:40 PM   #15
Update**** they clear all the way around
Old 07-16-2015, 01:44 PM   #16
Fronts are +28mm rears are +35mm
Brake Upgrade Clearance CV3 poloka 2011-2014 Mustang GT 3 02-27-2013 07:15 PM
Saleen Front Bumper Clearance fasternu_674 Mustang Audio & Video 9 03-06-2008 07:21 AM
Lowering springs and clearance UTGT 1996-2004 Mustang GT 1 06-09-2007 09:04 PM
Summit clearance sale on FMS plug wire Danger Dude Pre-2005 V6 Mustang 19 07-01-2006 01:16 PM
Need help with springs vs. tire clearance saleen0027 1996-2004 Mustang GT 11 06-07-2005 09:16 PM
01:16 AM
