Am I running lean at WOT? - Mustang Evolution
Old 07-16-2015, 09:20 PM   #1
ResilientMidget's Avatar
Ok to make a long story short: I am switching tuners. I am not going to mention names on here to keep vendor bashing at a minimum (I bet some people could guess who is who though lol). The new tuner is worried that I have been running "dead lean at WOT". At this point I know who I'm using for the new tune, and I am just trying to rule out if my engine could currently be damaged. The new tuner recommends that I run a relative compression test before the new tune just to be safe, and I will be doing that in the next week.
Short history: I have been running the complete Cobra Jet setup with monoblade throttle body and this crap tune for less than 700 miles. The car has never been raced and I red lined fit for the first time during this datalog. The new tuner was iffy about tuning it until I talked about my grandma-like driving habits. I attached my most recent datalog for everyone to review. Green is RPM, blue is measured AFR, and yellow is knock activity.
Also, does anyone know what the knock activity is all about? Is that normal?
2014 GT Premium. Cobra Jet Intake with monoblade throttle body and FRPP CAI. Ford Racing Sport axle backs. Pypes off road H pipe. Numerous appearance mods, it was a plain blue Mustang when I bought it.
ResilientMidget is offline   Reply With Quote
Old 07-16-2015, 09:26 PM   #2
Here is another screenshot with the AFR values on the left of the datalog graph.
Old 07-16-2015, 09:27 PM   #3
It looks like you are getting knock activity and your timing is low.
litfuse is offline   Reply With Quote
Old 07-16-2015, 09:33 PM   #4
The spark advance is between 22 and 28.5 throughout the datalog.
As far as the knock I am not sure what that is all about, but it looks like the knock sensors are correcting it. I used Chevron premium when I fueled up last.
Old 07-16-2015, 09:46 PM   #5
I know i had the same sort of knock activity im my logs. My tuner told me it was because of the fuel in my area (shell 93 V power) said the car needed to get used to it with the new tune loaded...
WundrbreadzDEAD is offline   Reply With Quote
Old 07-17-2015, 03:00 AM   #6
utm18's Avatar
Knock- positive # means your knock sensors are detecting knock activities and is removing timing. A negative number means there is no knock activities and it will add timing.
utm18 is offline   Reply With Quote
Old 07-17-2015, 06:39 AM   #7
Your average timing range is low for full throttle. If I was reading that correctly, it was 23.5, right?
Old 07-17-2015, 08:49 AM   #8
I wouldn't call 0.84 lean, that is a safe lambda. Any leaner like 0.9 would be cause for concern. Stock is 0.81 if I remember the stock tune right.
2014 Mustang 5.0 Brembo Package, 401A
2010 Camaro V6 Supercharged
MagnumForceGB is offline   Reply With Quote
Old 07-17-2015, 08:58 AM   #9
olerodder's Avatar
Region: Oregon
I have had a can'd tune in my car for the past 8 months (bought my TrakPak with 2700 miles and I now have 8400 miles) and I've been buying Chevron the whole time. I started having issues and the car just didn't perform the way it has in the past. Went to AED and did some data logging and I'm getting positive knock at 2k rpm to 7k rpm but not at partial throttle to 5k rpm....0 knock.
So I just ran the Chevron gas out and filled it up with Costco gas which is what AED recommended.......................the difference is like night and day. The motor is more responsive and just feels and even idles better.............I've driven about 25 miles filling up. AED told me that Chevron gas down in California is crap and my guess it's the same up here/down here in Oregon. I'm going up to Portland today and back home....about 200 miles and when I get back I'll do some data logging to see if the knock is still there. I did order some GT100 unleaded 100 octane gas as AED suggested and will still run some through the car to see what difference it makes from the Costco gas.................Also, here in Oregon we can only get 91 octane.........................Costco was 92 octane.
I do have a separate thread about my tune and what I've done so far...New Tune for My Mustang.
If I could figure out how to post a picture of the data log I'd do it.
Old 07-17-2015, 09:29 AM   #10
Voltwings's Avatar
The AFR is not dangerously lean, it actually looks about spot on. As far as the knock, its hard to say without the full log what is actually going on. Can you post the entire log for us?
Old 07-17-2015, 11:30 AM   #11
If you have windows just hold the windows button down (bottom left of keyboard) and then press the "prt sc" which is right above the backspace key. Do this while you are looking at your datalog. The screen will dim shortly, that is the computer capturing your image. The image gets saved to your pictures folder.
Old 07-17-2015, 11:43 AM   #12
Ok here is the entire data log. I pulled it on the freeway, someone cut me off in the process, and as a result you can see my RPMs stagger during the first half of the datalog. When I let my foot off the gas to compensate for the other driver the AFR spiked, and I am starting to think that's what freaked my new tuner out. I ran a second WOT at the end of the datalog and that is why the RPMs rise evenly and the AFR stays around .80
This datalog shows knock and RPM, and it looks like the knock happens on acceleration. Could this be bad gas or part of my current tune? I am worried about the knock at this point as the AFR does look spot on. Car drives funny with the CJ setup though, and I have heard that the new tuner can really dial it in nicely.
Old 07-17-2015, 11:46 AM   #13
Voltwings's Avatar
No lol, like literally the log file so i can open it up on my computer and look through it. Its hard to say definitively without all the information.
Old 07-17-2015, 11:58 AM   #14
I have had a can'd tune in my car for the past 8 months (bought my TrakPak with 2700 miles and I now have 8400 miles) Went to AED and did some data logging and I'm getting positive knock at 2k rpm to 7k rpm but not at partial throttle to 5k rpm....0 knock.
So I just ran the Chevron gas out and filled it up with Costco gas which is what AED recommended.......................the difference is like night and day. .
That sounds pretty similar to what im experiencing, thank you. We have 92 octane in Washington state, but I have been buying my premium on the Army installation that I live on. I'm going to go try Costco.
Old 07-17-2015, 12:16 PM   #15
olerodder's Avatar
Region: Oregon
I tried that but the screen never dimmed and nothing got saved. Sorry I'm not much with computers.
Old 07-17-2015, 12:17 PM   #16
olerodder's Avatar
Region: Oregon
Let me know if the Costco gas works.
Old 07-17-2015, 12:21 PM   #17
Voltwings's Avatar
Hey, posting pictures doesn't help much, if you want to just throw up the excel log file i'd be happy to go through it with you.
Old 07-17-2015, 12:26 PM   #18
olerodder's Avatar
Region: Oregon
I've tried before to upload the excel spreadsheet but it keeps coming up with an error message.
I'm heading out for my 200 road trip and burning the tank of 92 Octane and when I get back tomorrow I'll do another WOT data log to see if knock is there.
Old 07-17-2015, 12:31 PM   #19
I private messaged you.
Old 07-17-2015, 12:35 PM   #20
Voltwings's Avatar
PM me and ill get it sorted for you.
I made a thread on datalogs a while back for the V6 guys if any of yall want to poke through it.
How to: Understand your datalogs
Old 07-17-2015, 12:43 PM   #21
olerodder's Avatar
Region: Oregon
Thanks,
I'll look through it and PM you when I get back.
Old 07-17-2015, 08:14 PM   #22
That was a fantastic write-up. I installed my modifications myself and have been self conscious about a possible leak. I think it is amazing that I can check for leaks by looking at the short term fuel trims. I learned something today.
Old 07-18-2015, 08:26 AM   #23
Voltwings's Avatar
glad it helped
Old 07-18-2015, 11:12 PM   #24
olerodder's Avatar
Region: Oregon
Great writeup.........................I just need to read through it a couple of more times with my excel sheet in front of me.
Thanks for all of the help.
Running Lean Her98StangV6 Pre-2005 V6 Mustang 50 09-08-2015 05:11 PM
Still running rich at WOT! hades1346 1996-2004 Mustang GT 4 07-18-2015 01:32 PM
Running lean ColeJohnson 1996-2004 Mustang GT 20 01-29-2012 06:00 PM
1998 4.6 running lean on bank 1 and 2 eddie1 1996-2004 Mustang GT 22 11-28-2009 04:54 PM
Running Too Lean... MyStangStanks Pre-2005 V6 Mustang 11 10-16-2006 05:29 PM
04:07 PM
