Outside temperature reading. - Mustang Evolution
Old 07-18-2015, 08:04 PM   #1
Just curious its nothing serious. In my car my thermostat for outside temperature always reads 50 degrees outside. I live in Florida and i know its hotter than that. It's fu**in hot outside. Is there anyway i can reset it to read correctly. Thanks
Sent from my LG-D950 using Mustang Evolution mobile app
Whitey5.0 is offline   Reply With Quote
Old 07-18-2015, 08:09 PM   #2
Waylap1's Avatar
Region: New Hampshire
That's usually the temp it displays when the sensor is missing, damaged or not working. It's a cheap part and easy to replace...like $8. Underneath the front drivers side but you will need to remove the chin plate which is held on by about 12 screws. Also, it's much easier on ramps.
Waylap1 is offline   Reply With Quote
Old 07-18-2015, 08:11 PM   #3
Ok where can i get the part at
Old 07-18-2015, 08:31 PM   #4
Waylap1's Avatar
I got mine at my local Ford dealer parts counter. I called first, they ordered it and had it the next day.
You might even try disconnecting yours, making sure it's not plugged and it's clean and see if that's it. Or it could be missing if your car was repaired in the front or prior rental car. It's one of those parts that gets scavenged from rentals for resale by crooks.
Old 07-18-2015, 08:48 PM   #5
Thanks bud ill try unplugging it and clean the connections first and go from there
Is there any way to calibrate the temperature reading? sbbamafan General Mustang Discussion 1 04-06-2014 10:25 AM
Outside temp reading Deep Impact 2011-2014 V6 Mustang 7 08-05-2013 10:32 PM
Chain E-mail, but this one is worth reading. WhiteStang99 The Bar 5 07-13-2004 12:19 PM
This book im reading.. Zim The Bar 5 07-09-2004 03:45 PM
Lite Reading Ken The Bar 32 05-01-2004 10:26 AM
01:59 AM
