Exhaust rattle after long drive - Mustang Evolution
Old 07-19-2015, 10:13 AM   #1
Fax22's Avatar
After long drives or driving at higher speeds on the highway for about an hour or so, my exhaust starts rattling when I accelerate. It never does this on shorter drives are short periods of hard acceleration. Its almost lie something like a clamp or bolt expands when it heats up and it gets loose. I have MBRP street catbacks.
Any ideas?
Fax22 is offline   Reply With Quote
Old 07-23-2015, 04:58 PM   #2
Auto zone + rubber tubing + zip ties , wrap around the rear hangars, I'll bet they are coming in contact with the brace
Sent from my SAMSUNG-SM-G925A using Mustang Evolution mobile app
WasSHOnow5.0 is offline   Reply With Quote
Old 07-25-2015, 01:03 PM   #3
Fax22's Avatar
I noticed that only rattles under hard acceleration, not over bumps or anything. Hopefully nothing internally is broken.
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Old 07-25-2015, 01:18 PM   #4
Mlp07's Avatar
Mine when I go WOT, I can hear the driver side rattle. When I got my exhaust, it had a dent on the lip were the clamps go. I straighten it just enough just so it would go in. Might need to straighten it more so it might be that.
Mlp07 is offline   Reply With Quote
Old 07-25-2015, 01:29 PM   #5
Fax22's Avatar
The rattle almost sounds like a loose bolt, but its just weird i only hear it after it gets warmed up. Ill have to get under there and check the hangers and bolts again
Old 07-25-2015, 01:41 PM   #6
Mlp07's Avatar
Take them off and adjusting it again, probably something needs to be tightened.
Old 07-25-2015, 01:55 PM   #7
Fax22's Avatar
How tight should exhaust bolts be torqued?
Old 07-25-2015, 07:39 PM   #8
I bet its the hanger bolts coming loose. Mine started coming loose after I installed new axlebacks and they rattled under acceleration.
Try putting some blue lock-tight on the threads and making them really tight. Its worked for me for over 1000 miles now.
Edd2016 is offline   Reply With Quote
Old 07-26-2015, 07:29 PM   #9
Stangholio's Avatar
I have the same thing going on. Its driving me nuts. Off Wednesday and jacking the car up to look at it.
GHIGitty
Stangholio is offline   Reply With Quote
Old 07-27-2015, 12:48 AM   #10
grabber12's Avatar
I have the same issue. I even had Borla send me a new exhaust because I couldn't find out what it was. New exhaust still rattles only after long drive or after heavy duty fun . Mine is also on drive side. I can replicate the sound with certain amount of throttle once it starts. It was gone for a long time then today I drove it 35 miles and toward the end it came back. I've gotten under the car and looked at everything one day and nothing seems close enough to touch even if it did flex under heat.
Sent from my SM-G920V using Mustang Evolution mobile app
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
exhaust
Hot hot! OutlawGT 2.3 Mustang 7 12-04-2011 10:39 PM
Exhaust rattle noise? Exodus1021 2011-2014 Mustang GT 5 09-07-2011 03:32 PM
Exhaust rattle jt525 General Car Discussion 8 05-18-2011 08:28 PM
Dash Rattle?? Tranny Rattle?? ricklmesa Pre-2005 V6 Mustang 0 03-08-2006 07:19 PM
i finally got my exhaust but now theres a rattle... 1997grnstang Pre-2005 V6 Mustang 9 09-23-2004 11:34 AM
» Members Mustangs
Sally
Destro415
Ted
whyxitx
Add your Mustang
10:18 AM
