Steeda HD Strut Mounts alignment problem - Mustang Evolution
Old 07-19-2015, 01:17 PM   #1
NvrNuf's Avatar
Hello everyone,
I've just installed Koni STR.T, Steeda Sport Springs and HD Strut Mount. The HD Strut Mounts are installed with the logos facing out and the plates are at the outermost position, according to Steeda's instructions.
At the alignment shop, the left camber was -0.4 and the right -1.4. I'd like to stay in the middle with about -0.75 which could not be achieved on the right side as the mount was already at its limit and could not be moved out any further.
Should I be concerned with a camber of -1.4 because of uneven tire wear?
A 1 deg. camber difference between the Steeda HD Strut Mounts seems excessive to me. Has anyone had similar issues?
Did I miss something?
Thank you all for your help!
2014 GT Premium, Custom Painted, 401A, MGW, Brembo, Steeda CAI & 93 Tune
Steeda Sports, HD Mount Koni STR.T BMR Rod/Poly adj. LCA & Relos, PHB & Bracket
Forgestar Custom Painted CF10 19x9+35 & 19x11+42 Roush Grilles & Chin Splitter
FRPP Quad Axleback 3dCarbon GT500 Spoiler MMD Window Louvers SHR Fuel Door JLT Oil Sep.
NvrNuf is offline   Reply With Quote
Old 07-19-2015, 03:39 PM   #2
scott_0's Avatar
I'm not familiar with the installation of the Steeda mounts, so I'm not sure if the logos direction has any bearing on the adjustability, but, the mounts can be installed to allow for more negative camber if facing inwards, seems to me as if the mount with more negative camber is installed in the orientation that allows for more negative camber, where as the other side is not. Steeda reps are pretty active on the boards, I'm sure they'll chime in shortly
Sent from my Galaxy S6 using tapatalk
Old 07-19-2015, 04:40 PM   #3
NvrNuf's Avatar
According to Steeda, outward facing logos allow for maximum adjustability. I'm already wondering if rotating the mount 180 deg. would help or make things worse.
For Sale: Steeda HD strut mounts 11-14 for sale aftermath81 Mustang Parts for Sale and Wanted 1 02-02-2015 03:29 PM
Steeda heavy duty strut mounts 11-14 aftermath81 2011-2014 Mustang GT 10 01-15-2015 06:45 PM
For Sale: Steeda Upper Strut Mounts Arustik Mustang Parts for Sale and Wanted 7 04-01-2014 10:56 AM
06:56 PM
