Squeak after lowering - Mustang Evolution
Old 07-21-2015, 06:15 AM   #1
Saleen90's Avatar
Good morning all,
I just installed eibach sportline springs and a BMR pan hard. I didn't replace shocks and struts. I will get to them eventually. After about a week of having the new springs on, I'm hearing a lot of squeaking happening over bumps and general slightly uneven road surfaces. The only time I don't hear the squeaks is on a highway. Not sure if the road noise going that speed drowns out the squeaks or if it's an even enough surface that the squeaks aren't happening. If anyone can help me on finding the squeaks. Maybe you've experienced this too. Thank you in advance.
Saleen90 is offline   Reply With Quote
Old 07-21-2015, 06:26 AM   #2
KARgt13's Avatar
It's not the shocks and struts. I changed mine and I still get the same squeaks you do. Low speed bumps or rough roads but nothing on the highway.
KARgt13 is offline   Reply With Quote
Old 07-21-2015, 06:39 AM   #3
Saleen90's Avatar
Hmm... you think there's a place to grease up?
---------- Post added at 12:39 PM ---------- Previous post was at 12:38 PM ----------
Hmm... You think there's a place to grease up?
Old 07-21-2015, 08:32 AM   #4
oxford5pointoh's Avatar
Did you lube up your Panhard bar bushings? If not, that's my guess
🇺🇸Vote Ox for July MOTM!🇺🇸
IG @Oxford5pointoh
Old 07-21-2015, 08:35 AM   #5
Saleen90's Avatar
IG @Oxford5pointoh
No I didn't do that. I'll try that. Thanks
Old 07-21-2015, 08:39 AM   #6
It should have come with some line for poly bushings (I'm assuming you don't have spherical bushings)
IG @Oxford5pointoh
Old 07-21-2015, 10:10 AM   #7
Saleen90's Avatar
IG @Oxford5pointoh
Im not sure what bushings I have? I got the BMR adjustable ph bar off AM. And what line that should have been included are you talking about. I think the only thing that came in the box was the ph.
Old 07-21-2015, 10:17 AM   #8
Saleen90's Avatar
Old 07-21-2015, 10:46 AM   #9
Robostang's Avatar
He meant to type "lube". Poly bushings need plenty of it. I didn't put enough on mine during install and had to go back a couple of months later and do it again.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 07-21-2015, 05:13 PM   #10
Saleen90's Avatar
Ohh got ya. Ok I just looked and directions said for 3 pumps. I'm gonna try that now and see what happens. Thank you.
Old 07-21-2015, 05:23 PM   #11
Yeah sorry, lube. Damn phone
IG @Oxford5pointoh
Old 07-23-2015, 12:27 PM   #12
Saleen90's Avatar
I was able to grease up the one side of the pan hard and now that I'm writing this I just realized that I think I have it on backwards. I can't get to the driver side grease point because it points straight down and it's blocked off. And the other side grease point is parallel to the pan hard. So... I'll fix that tonight. But I think I was semi able to get some grease in on the driver side (maybe not though.) it still squeaks. And I was riding around this morning with my head out the window. And I'm 99% sure the squeaks or at least a majority of them are coming from the back. The only thing I can think of making the noise are the LCAs. Now that the car has a new symmetry. They may be riding 'funny' so now I need to figure out how and where to maybe put some grease on the LCAs.
Old 07-23-2015, 02:08 PM   #13
KARgt13's Avatar
I believe you can unscrew those grease fittings and swap them as opposed to taking the whole panhard bar off.
Old 07-23-2015, 09:29 PM   #14
Saleen90's Avatar
Well I'll remember that advice for someone else. I didn't check here in time. Thanks though!
Throw out bearing squeak after replacement austinknoll Pre-2005 V6 Mustang 9 02-18-2014 01:32 PM
Squeak noise after lowering springs sebasflorez Pre-2005 V6 Mustang 11 08-29-2013 03:56 PM
10-14 before and after pics after mods gtstyles2 Mustang Paint, Appearance & Detailing 16 08-27-2013 02:45 PM
Rattle after lowering kit JonChambers03 2005-2010 Mustang GT 10 06-01-2013 07:58 AM
07:55 PM
