Ford Racing Handling Pack? - Mustang Evolution
Old 07-25-2015, 06:08 PM   #1
Kustumb's Avatar
Has anyone bought the Ford Racing Handling packs?
Where do they stand in terms of quality/comfort?
I'm looking at this and its not available but I'll double check that on my end.
'Vert 14 GT.
2005-2014 MUSTANG GT CONVERTIBLE HANDLING PACK (1 INCH DROP) | Part Details for M-FR3-MCGTA | Ford Performance Racing Parts
Kustumb is offline   Reply With Quote
Old 07-25-2015, 06:59 PM   #2
BlackBetty5.0's Avatar
IMO you can put together a much better package than that for less than or the same cost. Depending on what you want out of the car.
BlackBetty5.0 is offline   Reply With Quote
Old 07-26-2015, 09:48 PM   #3
c_rizzle's Avatar
I was very tempted to get that. In hindsight I kind of wish I had.
If its in your budget, you should get it.
c_rizzle is offline   Reply With Quote
Old 07-26-2015, 10:42 PM   #4
NewMtang's Avatar
I have that package on my V6. Stiff enough for normal use, not recommended for any type of oval work. Drag strip ok. It dropped the front and the back "1.
If your wanting more of a drop look at some other packages. This has most of the things you will be needing for better handling. You don't need Caster Camber Plates. You might want to add Adjustable Upper and Lower Control arms.
If you want to be able to adjust your drop, get the coil over kits.
Old 07-27-2015, 10:35 AM   #5
Good quality and includes all new bolts. Springs and sway bars ford specs, but made by eibach, according to frpp. Having said that you could probably build a kit cheaper.
Cobrakit is offline   Reply With Quote
Old 07-28-2015, 08:11 AM   #6
c_rizzle's Avatar
Resale value.... you put together your own kit of various brand aftermarket parts & your car looks modded. People shy away from modded cars when buying used.
BUT if you install this "Ford Racing Handling Pack" people are MUCH more inclined to buy or at least not get scared away by a modded car.
Old 07-29-2015, 07:02 PM   #7
RacerX's Avatar
FR3a is a great setup. I added FR lower control arms and relocation brackets. Corners like its on rails.
I've driven other aftermarket setups and the FR kit is much better than hodge podge setups most recommend.
Name:	ImageUploadedByMustang Evolution1438218001.148023.jpg
2013 Mustang GT Premium 5.0 Sterling Grey 6MT 3.31
35% Tint, MGW Shifter, JHR Hectic Motorsports High Flow Clutch Line, Borla S-Type Cat-back, Airaid Race CAI, Bama 93H Tune, Roush Chin Splitter, GT500 Style Spoiler, GT500 Pedal Assy, Ford Racing M-FR3A-MGTAA, High Performance Key Fob Battery.
RacerX is offline   Reply With Quote
Old 07-31-2015, 06:15 PM   #8
hobo1's Avatar
3 years of driving bliss on my frpp mgtaa
Piloting a '13 GT with track, frpp handling, glass, mgw, bmr and sct
hobo1 is offline   Reply With Quote
Ford Racing Handling pack for 14 GT StangFlash 2011-2014 Mustang GT 4 06-10-2014 11:23 PM
Ford Racing handling pack BigP0314 2011-2014 Mustang GT 4 05-19-2013 10:22 AM
Ford Racing Handling Pack SolidRRaxle 2011-2014 Mustang GT 25 11-28-2012 01:11 PM
Ford racing handling pack tea84 2011-2014 Mustang GT 4 02-20-2012 08:26 AM
Ford Racing Handling Pack Delivered avengnd 2011-2014 Mustang GT 17 01-09-2012 06:00 AM
01:16 AM
