White smoke - Mustang Evolution
Old 07-26-2015, 12:09 PM   #1
White smoke
So all of the sudden I started noticing white smoke coming out my exhaust, car still runs fine, but when I'm sitting at a red light you can see the smoke coming out and it has a weird smell to it, any ideas?
Sent from my SM-N910V using Mustang Evolution mobile app
dee_gt is offline   Reply With Quote
Old 07-26-2015, 12:14 PM   #2
BLKBETTY13's Avatar
Probably just condensation burning out.
BLKBETTY13 is offline   Reply With Quote
Old 07-26-2015, 12:16 PM   #3
Yea at first that's what I thought but it's been going on for a few days now and when I get on the gas I look in the rear view and smoke everywhere
Old 07-26-2015, 12:34 PM   #4
The white smoke is most likely being caused by coolant that is entering the combustion chambers via a leaking intake manifold gasket, or a leaking head gasket.
Old 07-26-2015, 12:37 PM   #5
Well I guess it's time to put it in the shop
Old 07-26-2015, 12:51 PM   #6
My car has exactly the same problem.
Is your car still covered under the power train warranty?
Old 07-26-2015, 02:22 PM   #7
Parrotpaul's Avatar
Piston ring?
2011 Mustang GT Premium
2002 Camry Solara
2000 Pontiac Grand Am
Parrotpaul is offline   Reply With Quote
Old 07-26-2015, 02:34 PM   #8
I put my money on it being the head gasket.
Old 07-26-2015, 02:35 PM   #9
Robostang's Avatar
Originally Posted by Parrotpaul View Post
Piston ring?
Piston ring would cause blue smoke from burning oil. As stated earlier, this sounds coolant caused by a blown gasket.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 07-26-2015, 07:58 PM   #10
Not always as slam dunk as white smoke means coolant. If you still have cats, you can get grey-white smoke from unburned fuel. What does it smell like? Sweetish? that's coolant. Look inside your overflow, if you're down on coolant that could indicate or its full of milkshake spooge, that's oil getting into the cooling system. Pop the plugs out and take a look. heavy crusty white or reddish coolant deposits is a giveaway. If it hasn't been happening long you might find one plug cleaner than the rest type of thing.
A compression test is in your future...maybe when you pull the plugs you can do that
White smoke coming out exhaust greg70056 2011-2014 V6 Mustang 27 12-22-2012 10:45 PM
White smoke Surffer227 Pre-2005 V6 Mustang 5 03-15-2012 02:11 PM
White on white or white on black? Ware12 Pre-2005 V6 Mustang 28 01-20-2012 11:49 AM
white smoke when accelerating? psycho5.0 1979-1995 Mustang GT 7 04-10-2011 05:32 PM
Thick white smoke and oil everywhere...HELP!! AliceIvers General Mustang Discussion 10 03-19-2011 01:33 PM
08:10 AM
