sean hyland supercharger - Mustang Evolution
Old 07-27-2015, 11:11 AM   #1
Does anyone know where I can purchase a boost bypass vacuum hose assembly and a intake air temperature sensor wiring harness?
hulk89 is offline   Reply With Quote
Old 07-27-2015, 10:30 PM   #2
Just the vacuum hose or the whole bypass regulator? The hoses are pretty simple - they just run from the manifold or a port on the front of the supercharger inlet. You should be able to use an air temperature piggy back harness like the one used in the Magnusson TVS kit. Your tuner will have to know this is installed as most TVS tunes use both AIT 1 & AIT 2.
Post a few pics of the set-up. Have you contacted SHM?
Nater is offline   Reply With Quote
Old 07-31-2015, 09:07 PM   #3
Here are some pictures
Old 07-31-2015, 09:18 PM   #4
I don't see any pics??
Old 08-01-2015, 01:09 PM   #5
hopefully they upload this time
ID:	188460   Click image for larger version
Old 08-01-2015, 06:13 PM   #6
In the second picture I see the bypass assembly on the passenger side of the motor. The picture is not close enough to tell, but there should be a 5/16" vacuum hose nipple on the bypass. You need to run a vacuum hose to the intake manifold - there should be a similar 5/16" vacuum hose nipple somewhere on the intake manifold/supercharger assembly. I cant tell from the pics where the air intake temp sensor is on that assembly.
Old 08-01-2015, 06:25 PM   #7
You can buy 5/16" vacuum house form Oreilly's or Auotzone for a few bucks. The bypass assembly has black top/yellow bottom and a silver actuating rod and is mounted on the passenger side of the supercharger assembly.
sean hyland 2.3l tvs supercharger hulk89 2011-2014 Mustang GT 11 06-26-2015 08:50 AM
Root style Supercharger vs Centrifugal Supercharger jackiegnat 2015 Mustang GT 12 03-27-2015 11:05 AM
Look it's Sean Penn in Drag Danger Dude The Bar 16 08-28-2005 10:35 PM
$200+ complete supercharger, help Stang01 Pre-2005 V6 Mustang 3 07-20-2003 04:07 PM
Supercharger or Nitrous? ERICK Pre-2005 V6 Mustang 8 05-12-2003 02:41 PM
02:42 PM
