panhard bar - Mustang Evolution
Old 07-31-2015, 06:59 PM   #1
panhard bar
I've recently lowered my 2014 mustang with bc coilovers, I'm told I need an adjustable panhard bar. Is there one someone would recommend? thanks
A A Ron is offline   Reply With Quote
Old 07-31-2015, 07:04 PM   #2
Logiq's Avatar
Steeda or BMR
Black 2014 Mustang GT /w Track Pack - Multiple exterior mods, Borla S-Type axel backs, Lund Tune, ARH LT Headers, O/R H, Steeda Tansmission Mount Insert, Steeda Panhard bar and brace, Koni Yellow Shocks/Struts, Steeda HD upper strut mounts, Steeda LCA/UCA and mount. BMR LCA relocation brackets, Steeda Sport Springs, Boss IM, Steeda CAI.
Logiq is offline   Reply With Quote
Old 07-31-2015, 07:06 PM   #3
thanks. single, double or triple adjustment?
Old 07-31-2015, 07:26 PM   #4
Logiq's Avatar
I got the single from steeda. I guess it would just depend on how much adjusting you would want/need.
Old 07-31-2015, 08:54 PM   #5
thanks again. is there anything else I should get to improve handling/hole shot.
Old 07-31-2015, 09:01 PM   #6
Logiq's Avatar
I would recommend lca, relocation brackets, uca and mount. Since you're doing the panhard bar, replacing the brace isn't a bad idea either.
Old 07-31-2015, 09:03 PM   #7
Logiq's Avatar
Someone feel free to correct me if I'm wrong as I am by no means a suspension expert. I just know what others have done and suggested and what I've done myself.
Old 07-31-2015, 10:04 PM   #8
The_Chech's Avatar
panhard bar
A A Ron I have the BC's well and I found it easier to get BMR's double adjustable one because you can literally adjust it by hand while under the car with out lifting it, then lock it with a wrench once you get your axle centered.
As for the upper control arm and mount I kept it all BMR as well as the lower control arms and relocation bracket.
2011 Kona Blue Gt Premium on coilovers and kooks full exhaust.
IG - The_Chech
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 08-01-2015, 10:30 PM   #9
olerodder's Avatar
Region: Oregon
The brand is kind of six of one and half a dozen of the other the... important thing is to get all of one brand..................I've use Whiteline and I'm sure BMR is fine also...............a double adjustable is all you need and all I've ever used on street cars or race cars.
When I lowered mine I just started out with an adjustable pan hard bar........the next thing I put on was LCA's..............then an adjustable UCA. You should really look at replacing the rearend carrier bushing that the UCA attaches to on the axle housing..........I used a BMR because the design is like the OE GT500 bushing only Poly instead of rubber. The OE GT500 bushing is a harder durometer than stock and would also be a good choice as it's much stronger than the stock bushing.
With my setup...I used the adjustable LCA's and preloaded the chassis slightly which along with the carrier bushing allows my Mustang to hook really well without having to relocate the LCA's.
I don't really care for the relocation brackets hanging so low.....
You really don't need adjustable LCA's or UCA unless you want to play around with pinion angles.............especially if you don't want to put relocation brackets on............
If you need help just ask......................there are people on this forum that are a wealth of knowledge.
Old 08-01-2015, 10:46 PM   #10
olerodder's Avatar
Region: Oregon
IG - The_Chech
An old racers tip....................use red loctite on the threads and when you tighten everything take a permanent marker and draw a line across the flats of the lock nut and corresponding one on the bar.......this is a real quick reference to show nothing has moved.................and yes, I have seen them move under heavy use.
Pardon the picture..........I was making adjustments and forgot to mark the flat of the locknut....................at least I've got two corresponding marks.
Name:	2015-05-27 11.14.51.jpg
Old 08-02-2015, 09:08 AM   #11
I'm going to do all BMR thanks everyone for the advice. One final question do I want the
QA1 spherical bearing heim joints?
Sent from my SM-N900V using Mustang Evolution mobile app
Old 08-02-2015, 09:20 AM   #12
The_Chech's Avatar
For the differential bushing? And awesome choice! You won't be disappointed going with BMR. I haven't had a single problem with any of my BMR suspension comments and I beat the crap out of my suspension.
IG - The_Chech
Old 08-02-2015, 09:21 AM   #13
olerodder's Avatar
Region: Oregon
Rod ends as I've call them for 40+ years and not really suited for the street.
Unless they are sealed they get very dirty quite easily and would wear quickly.
Also, they transmit vibration and noise..............100 times more than poly bushings.
Leave the rod ends for a race car.
Old 08-02-2015, 07:34 PM   #14
tj@steeda's Avatar
PM sent regarding our influence in the Downriver area & partners in the Livonia area.
Hope to hear from you soon!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 08-02-2015, 10:30 PM   #15
Downriver making it on a post. Never would have thought
Sent from my SM-G900P using Mustang Evolution mobile app
smallengineguy is offline   Reply With Quote
Old 08-03-2015, 06:46 PM   #16
Thanks for all the advice everyone, I appreciate all of it
Old 08-03-2015, 09:53 PM   #17
adam.martinson's Avatar
Region: Idaho
When I lowered mine I went with the BMR panhard bar, LCA, and UCA without the bracket and everything seemed fine.
2015 GT PREMIUM TRIPLE YELLOW
Roush Axleback, Ford Racing Resonator delete x-pipe
adam.martinson is offline   Reply With Quote
Good Aftermarket Panhard Bar? Skinsfan6 2005-2010 Mustang GT 7 03-05-2010 10:07 AM
rear sway, or panhard bar? A5295 1979-1995 Mustang GT 12 07-16-2007 08:05 AM
panhard bar eagle05 1979-1995 Mustang GT 12 07-09-2007 08:03 AM
Will a MM Rear Swaybar work in junction with the MM Panhard bar? MustangMatt Pre-2005 V6 Mustang 8 02-02-2005 04:28 PM
Panhard Bar Question njstang97 Pre-2005 V6 Mustang 6 11-07-2004 11:31 PM
04:58 PM
