Rpm needle moving around at idle - Mustang Evolution
Old 08-05-2015, 12:48 PM   #1
2013 gt mt82 junk....recently my Rpm needle been moving around at idle...not much bit enough to notice ...anyone have this issue and is it a problem? When I'm idling around 700-750 it will dip down. To 600ish then back up.. and when not dipping down it moves between 700-750 constantly. ..any help I would greatly appreciate
Jstorm is offline   Reply With Quote
Old 08-05-2015, 01:25 PM   #2
Voltwings's Avatar
Have you messed around with any vacuum lines lately? Typically a dancing idle is indicative of a vacuum leak. If you have a datalogger, hook it up at idle and see what your short term fuel trims are doing.
Also not sure why you mentioned the transmission because that has literally nothing to do with your issue?
Old 08-05-2015, 01:25 PM   #3
Strange Mud's Avatar
AC kicking on? I know they try and idle as low as possible (mpg)
Old 08-05-2015, 01:26 PM   #4
Ac on or off it does it ....mentioned trans just because. No vacumm lines messed with sinew the boss intake install. 4 months ago....just started this recently
Old 08-05-2015, 09:52 PM   #5
olerodder's Avatar
Region: Oregon
Voltwings is correct, do you have a data logger?
Also could be an intake leak/vacuum, causing the jumping needle.
The AC should make no difference..........at least on mine it doesn't.....with the AC on it should hold a slightly faster idle than normal....................mine normally idles 700 and with the AC it's above 700.
rpm needle not working dark2007 2005-2010 Mustang GT 12 11-29-2013 05:54 PM
rpm needle not working.. Andy714 2005-2010 V6 Mustang 3 02-10-2013 10:09 AM
Gauge needle help 1997 Cobra ffep 1996-2004 Mustang GT 1 07-07-2010 10:00 AM
Guage Needle Removal Help blue-saleen Pre-2005 V6 Mustang 5 01-15-2010 10:17 AM
Guage Needle repostioning Kfizz262 1996-2004 Mustang GT 4 04-08-2008 05:01 PM
10:03 PM
