Question if car gets towed. MT-82 - Mustang Evolution
Old 08-09-2015, 11:08 AM   #1
Jvibe92's Avatar
Well my night went to sh*t last night when I payed for metered parking and arrived back to my car only 15-20 mins late. They towed it. What should I look for, damage wise, since I know I am manual, parking brake was set, and possibly was in gear(don't remember).
I am still pretty furious. 250$ for barely being late. Towed only 1 mile from where it was at.
Jvibe92 is offline   Reply With Quote
Old 08-09-2015, 11:16 AM   #2
Diehard's Avatar
They probably opened it and released the brake and such.
BTW...I know the feeling.
Old 08-09-2015, 11:54 AM   #3
scott_0's Avatar
better chance of body damage than there is damaging the drive train, youll be fine
Old 08-09-2015, 12:07 PM   #4
NewMtang's Avatar
Barely Being Late is like Barely Cheating on Your Wife or Girlfriend!
Old 08-09-2015, 12:31 PM   #5
Robostang's Avatar
Except that it will cost you a whole lot more than $250 if it is your wife!!!
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 08-09-2015, 12:51 PM   #6
Jvibe92's Avatar
Well I'm about to check it now -__-
Old 08-09-2015, 02:03 PM   #7
Was this at a parking meter on the public street?
Everywhere around here just writes a parking ticket if you are caught parked with an expired meter.
Old 08-09-2015, 03:27 PM   #8
olerodder's Avatar
Region: Oregon
Hope it went well...........as well as spending $250 can.
Old 08-09-2015, 04:45 PM   #9
Jvibe92's Avatar
Nope. Parking garage. But surprisingly no damage. But I am curious. How do they get into the car without damaging anything?
Old 08-09-2015, 04:53 PM   #10
paintmann111's Avatar
They use the stick or bladders to prop the door open.
paintmann111 is offline   Reply With Quote
Old 08-09-2015, 07:24 PM   #11
Diehard's Avatar
A "slim Jim" was used for many years on many cars. I don't know if the door lock linkage has changed much.
A quick google reveals that there are many devices used, depending on the car.
The flat bars on the right side of the picture is called a slim jim.
Old 08-09-2015, 08:26 PM   #12
kona010's Avatar
That's Houston for ya. They tow and ticket parked cars so much especially in the inner loop.
kona010 is offline   Reply With Quote
Old 08-09-2015, 08:27 PM   #13
The_Chech's Avatar
So what happens if they damage your car while towing? How does that even play out? Like lets say your side skirt gets ripped off in the process?
2011 Kona Blue Gt
IG - The_Chech
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 08-09-2015, 08:36 PM   #14
kona010's Avatar
2011 Kona Blue Gt
IG - The_Chech
Unless it was undeniably there fault they would more than likely deny deny deny that anything like that would've happened under there watch. I'm sure it would be a long drawn out process to make them fess up to minor scratches or dings.
That's my 2cents
Old 08-09-2015, 08:49 PM   #15
That sucks!
I'll know not to mess around when I park in Texas.
They usually break into the passenger side because if they cause any damage it is less likely that you will notice it.
Look closely at the passenger side door, around the roofline. And right above the window. Also, check the weatherstripping to make sure that they didn't tear that up.
Old 08-09-2015, 08:54 PM   #16
oxford5pointoh's Avatar
They will either put dollies under the rear tires or the scooped it from the back. They probably did not open the car. I've also seen these guys put the car in neutral from the underside by picking up the car but they would have to open it to get the hand brake off.
Old 08-09-2015, 10:34 PM   #17
olerodder's Avatar
Region: Oregon
Just glad you got it back in 1 piece and unharmed................
Old 08-10-2015, 11:05 AM   #18
The bad ones around the Daytona Area just
They will back up the flat top and drag the car up with a winch. They care less if they damage a tow-A-Way zone or handicap cheater car.
The better tow company's will use dolly wheels on the ground wheels and care a lot more about somebody's car.
It is a crap shoot on who gets there first.
Old 08-10-2015, 11:17 AM   #19
Noodles76's Avatar
They usually do not open the car. They hook it up and drag it into the flat bed.
Noodles76 is offline   Reply With Quote
Old 08-10-2015, 11:32 AM   #20
Sadly I was in the same boat one time. They put it on dollies and hoist it up on their flatbed.
'14 Grabber Blue Mustang GT
Manual, Premium, Steeda Tri-Ax shifter w/ red bracket, K&N CAI
mnl1121 is offline   Reply With Quote
Old 08-10-2015, 12:16 PM   #21
I suppose that if you wanted to make the tow truck drivers job as difficult as possible, you would lock your steering wheel with it turned all of the way to the left or right. Preferably, in the direction where the car will hit something when they try to pull it out. This would force them to put it on dollies.
Worst Modified Car Gets Destroyed OsirisGuy Pictures and Videos 8 11-03-2009 10:47 PM
Car question? Duh, of course it's a car question, silly!? imported_daman General Car Discussion 3 08-17-2009 06:40 PM
Wow... guy gets first question wrong on Who Wants To Be A Millionaire. Brent Pictures and Videos 15 11-14-2006 12:15 AM
Car gets sabotaged... MonteCitan The Bar 12 08-24-2005 05:51 PM
Dude in car gets flat out owned Brent The Bar 16 04-08-2005 03:02 PM
09:17 AM
