Exhaust clamps - Mustang Evolution
Old 08-09-2015, 04:51 PM   #1
Fax22's Avatar
Exhaust clamps
The connection form my cat deletes t the factory h pipe is leaking pretty bad. I have tried to move those crappy ball clams around forever with no improvement. Are there any clamps I can run to the auto store and pick up that would fit better? Normal band clamps are alot wider but not sure if they would fit over the ball shape of the pipes.
Fax22 is offline   Reply With Quote
Old 08-09-2015, 04:53 PM   #2
Rapinator126's Avatar
Best option, is going to be welding it.
Old 08-09-2015, 04:57 PM   #3
Fax22's Avatar
Yes that would obviously work, but welding my exhaust makes it a pain if i ever want to swap anything out. I dont need a 100% fix, just the best fix without welding.
Old 08-09-2015, 05:01 PM   #4
Well unfortunately the way the connections are, you do not have many choices.
Old 08-09-2015, 05:04 PM   #5
Fax22's Avatar
Would wrapping the connection in high heat tape and then putting the clamps over that be enough to keep the seal better. It only seams to be coming out of the opening the clamps have where you tighten the bolt down.
Old 08-09-2015, 05:09 PM   #6
It may help.
Try not to make them so tight.
I hate the connections and clamps they use.
Other thing you can try is getting new clamps from ford, as the ones you are using may be bent.
That's why I dislike the clamps. If they are bent. As you tighten them. The side with the bolt will pull outwards Vs clamping down with equal pressure all the way around.
Old 08-09-2015, 05:10 PM   #7
Fax22's Avatar
Ok so over tightening them could make the leak worse? I have been getting them pretty tight.
Old 08-09-2015, 05:12 PM   #8
Yes bc it can bend the clamp. And pull the side with the bolt outwards. But If they are already bent, then get some new ones. And don't get them really tight.
Old 08-09-2015, 06:26 PM   #9
Fax22's Avatar
Ok thank you. i will try that with some high eat tape maybe tomorrow and let you know how it goes.
Old 08-09-2015, 06:36 PM   #10
Fax22, how do you know you have a leak? I ask this because I think mine is leaking as well and I wonder what symptoms your car is showing.
litfuse is offline   Reply With Quote
Old 08-09-2015, 06:47 PM   #11
Fax22's Avatar
Well i can hear it, smell it, and when i go under the car, i can feel it with my hand coming out at the clamp.
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Old 08-09-2015, 07:17 PM   #12
I just occasionally get what sounds like whooshing sound. I have been under the car when it's running and I do not feel the leak or smell it. I just wonder if mine is so minor, that it comes and goes. I just hope it's not messing with my tune.
Old 08-09-2015, 07:52 PM   #13
Fax22's Avatar
It could just be your intake if you have an aftermarket one. That wouldnt be coming from under the car though.
Old 08-10-2015, 05:05 PM   #14
I have the stock intake. I think it is just the crappy oem h-pipe clamps and exhaust getting out somehow. It's frustrating.
Old 08-10-2015, 06:21 PM   #15
I had a similar problem, where after taking the clamp on and off several times, it no longer fit correctly because it stretched. JEGS has the exact one and it's $20 cheaper than Ford. It solved the problem for me.
http://www.jegs.com/i/JEGS-Performan...30689/10002/-1
ads245 is offline   Reply With Quote
Old 08-11-2015, 12:32 AM   #16
Compstall's Avatar
Name:	ImageUploadedByMustang Evolution1439274616.667132.jpg
ID:	189106Click image for larger version
Name:	ImageUploadedByMustang Evolution1439274639.316797.jpg
Use these, found at Napa for about $10 each. All your problems will go away. I put a couple wraps of aluminum foil on the joints first.
I agree, for whatever reason once those factory clamps are moved they never seem to seal up real well.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 08-11-2015, 04:11 AM   #17
Fax22's Avatar
Those look like exactly what i need. Curved in the middle to fit the connection, but long enough to seal everything up.
Old 08-11-2015, 11:14 AM   #18
94gtconvert's Avatar
I had the same exact issue and I found the cheapest easiest fix. Go to your local pars store, I had to go to a small business one because I couldn't find it at auto zone or advance. Pick up some muffler cement/sealer. It's a mettle paste/ cement, for sealing joints. Mine actually says easy to take back apart on the tube, you just need to shader it off. I'd defiantly try it
94gtconvert is offline   Reply With Quote
Old 08-11-2015, 11:32 AM   #19
Fax22's Avatar
How long dies it take to cure fully before you drive it?
Old 08-11-2015, 04:08 PM   #20
3 hours. DONT START THE CAR AT ALL.
Old 08-11-2015, 04:18 PM   #21
Fax22's Avatar
Ok so i kind of did a mix of everything. High heat, self bonding tape, then wrapped in foil, then reused the stock clamps. Everything together fixed it up pretty good. No whisping noise, no smell, no heat by the doors. Not the pretiest thing in the world, but it got the job done for around 10$.
Old 08-11-2015, 05:06 PM   #22
BLKBETTY13's Avatar
I'd say you could've done without the foil. That's just gonna wither away.
BLKBETTY13 is offline   Reply With Quote
Old 08-11-2015, 06:09 PM   #23
Fax22's Avatar
Mabe, but it doesnt hurt until then. As long as it works.
Old 08-13-2015, 01:29 AM   #24
Compstall's Avatar
My fix has Zero cure time.
- Brent
Old 08-13-2015, 03:21 PM   #25
My fix was $3.79
exhaust
Wanted: 2013 mustang gt exhaust clamps jrdnsky59 Mustang Parts for Sale and Wanted 6 03-16-2015 08:55 PM
Exhaust Clamps HELP Slow4V 1996-2004 Mustang GT 10 10-10-2014 08:32 PM
Borla exhaust clamps Awest31 2011-2014 V6 Mustang 8 03-22-2014 01:02 AM
Exhaust clamps XSlashDashX 1996-2004 Mustang GT 3 02-15-2014 11:28 AM
CAI Clamps Foxone Pre-2005 V6 Mustang 5 07-07-2009 07:59 AM
06:07 AM
