Lowering sprigs on stock suspension? - Mustang Evolution
Old 08-11-2015, 12:22 PM   #1
I know it's always better to upgrade your shocks/struts when lowering your car but wondering what the ride it's like if I were to lower my 14 GT on say Sport lines or Ford racing K springs
Will the drop do any damage on the stock suspension
Sterling_5.0 is offline   Reply With Quote
Old 08-11-2015, 12:39 PM   #2
Grabber Blue5.0's Avatar
The Ford Racing K springs ride like crap even with upgraded shocks/struts. On their own they're even worst. You will still need to address the upper control arm and mount as well as the lower control arms and relocation brackets. Do it right the first time.
If you need someone to install parts let me know. I can do it probably less than 15 mimutes from where you live.
Old 08-12-2015, 09:01 AM   #3
olerodder's Avatar
Region: Oregon
I have had the Eibach Sportlines on for the past 6000 miles with my stock suspension and although it does ride a little stiffer....which I like...it has caused no real issues or tire wear. My car is a TrakPak and although the struts/shocks are little stiffer than normal it just depends on the ride feel you are looking for. I also didn't change the strut mounts and they do creak/pop on occassion...... it hasn't really bothered me that much.......I will be changing struts/shocks in the near future as soon as I decide if I want coil overs or struts/shocks....and which ones.
As for using camber bolts or caster/camber plates..........I see no need for them.
I have helped lower 5 late model Mustangs including mine and none have need any camber bolts or caster/camber plates. When I took my Mustang to Ford after putting the springs in the alignment although on the high side of camber and low side of caster was within factory Ford specs............so, the Mustang can be lowered without changing anything although I would get a new set of strut mounts when you put the springs in...........just to start fresh as Ford calls the struts mounts one time use only and they are considered throw away items. I reused mine............."don't do as I do, do as I say"..............that's up to you.
Old 08-12-2015, 09:28 AM   #4
Strange Mud's Avatar
do it once....
I see Meriden...look for my threads RoboStang and I run cruises 3x year. Next on is the last wknd of October (Durham in the house). I met Grabber at the last one.
Old 08-12-2015, 10:59 AM   #5
My wife has a 2013 Roush RS
That's the V6 Roush does dress up on
Roush lowers the car 1 inch with their springs no other suspension parts at all
With the 19 inch Brembo wheels it looks great and rides pretty good as well
If you are looking to lower the car for looks this works
If you want better handling then do a complete suspension upgrade with components designed to work together
Jakkbeyar is offline   Reply With Quote
Old 08-12-2015, 01:49 PM   #6
alterego's Avatar
Glad to see this thread, didn't want to start another one that the know it all's just reply "lol".
I desperately want to lower my GT. but I'm always on a budget. I have been looking at a Steeda kit but it'll have to wait. So reading this it appears I can simply replace my springs with some Steedas and get the stance I want?? I want the handling as well but another dollar later.
alterego is offline   Reply With Quote
Old 08-13-2015, 05:37 AM   #7
Fax22's Avatar
On my 2012 v6 i used sr springs without replacing the dampers or mounts. It was fine for a while but as time went on, either the dampers or the mounts started wearing out and making a ton off noise over bumps and creaking when turning. It still looked good, but on my new 2014 gt, i just installed sportlines, koni orange dampers, and J&M cc plates. It rides super smooth and firm and no noise. I just installed them last week though... i suggest at least getting the shocks and struts with the springs considering the konis are on sale right now.
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Fax22 is offline   Reply With Quote
Old 08-13-2015, 05:49 AM   #8
Yeah most likely going to do everything at once but was seeing if anyone experienced any major issues or problems with just springs ...where are the konis on sale ?
I picked up some 19" svt wheels so maybe ill try to do everything at once
Old 08-13-2015, 05:52 AM   #9
Fax22's Avatar
Both the oranges and yellows are on sale at American Muscle and i think Late Model Restoration. AM for sure though and then our forum discount doesnt hurt lol.
Old 08-13-2015, 05:56 AM   #10
Thanks I'll take a look....do you have any pictures with that set up? ^
Old 08-13-2015, 05:58 AM   #11
Fax22's Avatar
This was the end result after the oranges, cc plates, and sportline springs. 19" wheels. Havent settled all the way since i just did this a week ago.
ID:	189269   Click image for larger version
Old 08-13-2015, 09:27 AM   #12
Old 08-13-2015, 09:37 AM   #13
Fax22's Avatar
Also, until i get my alignment done, my front wheels have some negative camber. Its how they want you to position the cc plates at first since its easier for you to get them even on both sides like that than trying to center them yourself.
---------- Post added at 11:37 AM ---------- Previous post was at 11:36 AM ----------
You can kind of see it in the second picture
Old 08-13-2015, 09:56 AM   #14
Yeah I see that now that you point it out .. Nothing a good alignment/ adjustment won't fix
Old 08-13-2015, 10:07 AM   #15
alterego's Avatar
Will a spring swap require an alignment?
Old 08-13-2015, 10:12 AM   #16
Fax22's Avatar
Ya it will. Lowering your car messes with the geometry of the car. Especially with cc plates. Also need an adjustable panhard bar for the backend. Mine was so bad after i dropped my car. The sportlines drop 2" in the back.
Old 08-13-2015, 10:20 AM   #17
Local guy to me I've been helping lowered his car without fixing the pinion angle with an upper control arm and now his rear is fudged up and leaking all over the place. So there are other pieces to the puzzle that need to be addressed.
Old 08-13-2015, 10:21 AM   #18
Fax22's Avatar
Well ive never heard of anything leaking on our cars after lowering it unless when you were messing with the axle, you did something weird
Old 08-13-2015, 10:41 AM   #19
Yeah it's tough I like the sport lines but the seem to be a more even drop all around not sure if I want to go with the kind of racked look
Old 08-13-2015, 10:44 AM   #20
olerodder's Avatar
Region: Oregon
If you just swap springs.....depending on what springs you use........no you don't need an alignment........although I would have it checked. I went to my Ford dealer and asked if he would check the alignment.........he did.......and didn't charge me...........also, Les Schwab Tire centers don't charge if the alignment falls within factory specs........if you are worried about paying if the alignment is good and they do no adjusting.
I've helped lower 5 late model Mustangs including mine and none of them were out of alignment after the swap. All five used the stock struts and shocks along with stock strut mounts. I lowered mine 1.5" in front and 2" in the rear and although I'm on the high side of factory spec for camber and the low side for caster I've had no tire wear in 6000 miles and the car handles great.
Is this the correct thing to do it..........if you are not willing to spend over $1k initially you can certainly do what I did with no adverse suspension issues. I would recommend getting an adjustable pan hard bar so you can bring the rear end back to the correct offset.
As for ride.........my TrakPak rides stiffer than OE but I'm fine with that...it does make noises when going over speed bumps and in driveways.......
Now, with that said I am going to change the struts and shocks before the end of this summer..........just not sure in what direction.
Old 08-13-2015, 10:53 AM   #21
olerodder's Avatar
Region: Oregon
I think Grabber Blue5.0 made an excellent point!
Whenever you change the suspension ride height on your Mustang you need to check the pinion angle. Although I have a 1 piece aluminum driveline when I lowered mine it came out to be -0.05 degrees. Some of the other cars I helped lower were anywhere from -1 degree to +1 degrees.
As was mentioned earlier when you lower a car it can and will change the suspension geometry...................
Old 08-13-2015, 10:54 AM   #22
First of all I didn't install the parts so I did nothing of the kind. What I did was FIX his pinion seal leak which was caused by early premature wear from his pinion angle and then set up his pinion angle properly. Trust me I know how to properly set up a suspension.
Old 08-13-2015, 10:59 AM   #23
olerodder's Avatar
Region: Oregon
I assume you meant "raked" look, not racked look.............I can't say about any other springs but Eibach does make the Proline springs that will give you the raked look you are after.
Old 08-13-2015, 11:02 AM   #24
Yes sorry iphone auto corrects the **** out of things
Old 08-13-2015, 11:03 AM   #25
olerodder's Avatar
Region: Oregon
I have seen at least two Mustangs that were lowered and the owners never checked the pinion angle.......they both lost pinion seals and started leaking oil....the seals are just" plastic" and are pretty easy to destroy............I replaced mine with the updated "steel seal".
Old 08-13-2015, 11:04 AM   #26
Anyone haven pictures of the set ups they are running ?
Old 08-13-2015, 11:29 AM   #27
olerodder's Avatar
Region: Oregon
If you look at my garage you will what my setup is.
Old 08-13-2015, 01:56 PM   #28
alterego's Avatar
Ya'll giving me mixed feelings. I want to drop my car. I really want a steeda stage 1 kit but don't have that to spend right now. But if I could do it a little at a time I'd trow $200 at springs this weekend and get those slapped in.
Old 08-13-2015, 02:25 PM   #29
Fax22's Avatar
My opinion simplified: at least buy dampers with the springs +panhard bar.
Old 08-13-2015, 02:44 PM   #30
olerodder's Avatar
Region: Oregon
So......why the mixed feelings?
If you just want to drop the car then drop the car. Add the other parts as the money becomes available.
When the money comes the first thing I'd get is an adjustable pan hard bar, then it's kind of up to you which direction you want to take.
I've got 6000 miles on my 14................I didn't change struts or strut supports although did get an adjustable pan hard bar.
Although I doubt you will need any caster/camber plates I'd have the alignment checked just be sure.
Old 08-17-2015, 09:30 AM   #31
Rprill90's Avatar
Did you get Camber plates installed also when lowering the car?
Rprill90 is offline   Reply With Quote
Old 08-17-2015, 09:50 AM   #32
olerodder's Avatar
Region: Oregon
So...............did you drop the Mustang?????
Old 08-17-2015, 09:53 AM   #33
olerodder's Avatar
Region: Oregon
If you are referring to me..................no............had no need for caster/camber plates. Although my alignment was on the high side of Ford specs for caster and low side for camber.
Old 08-18-2015, 12:02 PM   #34
Diehard's Avatar
olerodder...I was just made aware of Maximum Motorsports caster camber plates which talked about the ability to raise the strut travel up a bit so you can run stock struts and shocks on a lowered vehicle (around 1.5 inches of drop).
The ad for this CC plate says, "The range of suspension travel can be shifted, allowing for additional bump travel on lowered cars."
This sounds like one could use the stock struts at or near their designed heights, which I would think would extend their life. Looks like they come with (2) Long Spacers and (2) Short Spacers.
What do you think about this?
Old 08-18-2015, 12:35 PM   #35
olerodder's Avatar
Region: Oregon
I just looked on their site and couldn't see anything about a ride height adjustable CC plate.........please forward the page or number.
Thanks
Eibach pro kit sprigs and stock bump stops need some help ! crashkid500 2011-2014 Mustang GT 17 08-19-2014 03:34 AM
Lowering sprigs on 2001 cobra Red_venom_01 SVT Mustang 10 08-24-2013 07:34 PM
K sprigs install Reinkey 2011-2014 Mustang GT 18 11-30-2011 10:41 AM
lowering suspension kit Myles 1996-2004 Mustang GT 41 01-13-2011 01:39 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
05:01 AM
