Tapping a fuse, save? - Mustang Evolution
Old 08-16-2015, 11:04 AM   #1
Trying to tap a fuse in the engine compartment for halos.
I tried heated mirrors but found it would only get power if I turn on the defrosters.
What fuse is save to tap? I feel tapping a fuel pump or powertrain control module wouldnt make me feel worry-free.
How do people usually get 12v power that turns on and off with the car under the hood?
dseg is offline   Reply With Quote
Old 08-16-2015, 11:55 AM   #2
tap the circuit breaker for power windows.only circuit
breaker in under hood panel
ALLYDRIVER1 is offline   Reply With Quote
Old 08-16-2015, 11:58 AM   #3
The power windows are cartridge fuses and not mini fuses.
Old 08-16-2015, 11:59 AM   #4
scott_0's Avatar
fuse #39 in the under hood fuse box is hot when ever the motor running, I used it for my drl's on my headlight swap
sent from my S6 using tapatalk
Old 08-16-2015, 12:15 PM   #5
Exclamation
mine has a circuit breaker in underhood fuse block feeding window circuit,its a 2004 .its the only circuit breaker in under hood panel
Old 08-16-2015, 12:16 PM   #6
I have a '14 GT and it is only hot when I actually turn my rear defroster on, weird....
Old 08-17-2015, 08:53 AM   #7
Can i ask which halos you got? Im trying to find some for the center fog lights
visback is offline   Reply With Quote
Old 08-17-2015, 09:14 AM   #8
Angel Eye Halo CCFL 125mm White Rings | eBay
Old 08-17-2015, 09:16 AM   #9
Curious how these would work. Did you open up the fogs and insert them in? Do a DIY!
Old 08-17-2015, 09:17 AM   #10
My GT/CS doesn't come with the center fogs, they come with the lower valance fogs. But I mounted the halos anyway.
Old 08-17-2015, 09:18 AM   #11
Ohh, that makes sense now. Thanks!
Old 08-17-2015, 09:19 AM   #12
Here is my fog thread:
Mustang front Grilles
Fuse/fuse box Iamiguel 2005-2010 V6 Mustang 1 06-15-2012 05:16 PM
Tapping from a 2v Everett 1996-2004 Mustang GT 16 04-15-2011 02:19 PM
Tapping noise in tranny? 2003TangGT 1996-2004 Mustang GT 1 09-06-2007 01:08 PM
2000 mustang GT tapping sound in engine dreamcar00 1996-2004 Mustang GT 8 01-19-2007 04:58 PM
Wire tapping... DarkShadow The Bar 11 05-13-2006 09:52 PM
02:14 AM
