Cylinder #2 Misfire - Mustang Evolution
Old 08-19-2015, 09:37 AM   #1
Cylinder #2 Misfire
I have just recently begun to get the code for a random misfire on cylinder 2, it began where while driving I would have a loss of power for a stretch and would cause the engine to bog down, at first I figured it was dirty fuel, since I get premium and one of the last times I filled up was in a small town where I am sure many people do not get that grade. I started off by just changing the spark plug and the ignition coils, and running some Seafoam fuel system cleaner through my gas. I have not had the problem while I am driving now, however when I sit in the driveway at idle, it will start to bog down again and at times the RPM's will go down to as low as 500... Not exactly sure where to go from here, except for cleaning fuel injectors.... Also could an O2 sensor have to do with this, I also have received the code for Bank 1 Sensor 1 being lean, although I changed that O2 sensor in the past year??
steelcanes5.0 is offline   Reply With Quote
Old 08-21-2015, 05:32 PM   #2
hdez41's Avatar
I had the same thing with my rpm dropping down to 500 and at times even dying out. I thought it was the 02 sensors but I changed both of them and the problem still persists. I don't know what it could be
---------- Post added at 11:32 PM ---------- Previous post was at 11:31 PM ----------
Also does your rpm get stuck when downshifting to 3rd gear and down
hdez41 is offline   Reply With Quote
Old 08-21-2015, 05:35 PM   #3
hdez41's Avatar
My car when I downshift it feels like it wants to keep going and the rpm very very slowly goes down. As opposed to before it went down relatively fast when downshifting
Misfire in cylinder 4 Balltaatic01 1996-2004 Mustang GT 20 11-28-2012 06:37 PM
Cylinder #2 misfire. storieddeth 2005-2010 Mustang GT 10 09-26-2012 07:33 PM
2000 dodge caravan cylinder 5 misfire Niko Brown General Car Discussion 1 08-27-2012 06:44 PM
Cylinder 1 Misfire? stew99 Pre-2005 V6 Mustang 3 11-02-2011 10:31 PM
Misfire cylinder #1 with Check Engine Light JRMustang Pre-2005 V6 Mustang 29 03-14-2011 11:49 PM
07:01 AM
