Installing new injectors: Any directions? - Mustang Evolution
Old 08-21-2015, 02:04 PM   #1
Jvibe92's Avatar
Got my 47lb injectors ready to finally install! I'm going to do it myself, as I've heard it's not too difficult. Been searching around but doesn't seem to be any videos or write ups on how to install. I just like to follow these things to ensure everything goes right the "first time" haha.
Anyone know of any walkthroughs?
Jvibe92 is offline   Reply With Quote
Old 08-21-2015, 02:12 PM   #2
Rapinator126's Avatar
Doubt there is any videos. It's simple just pull off the fuel rails. Then take out old injectors and put new ones in.
🍼and 🌽 fed coyote.
Old 08-21-2015, 04:23 PM   #3
jp1seattle's Avatar
One thing I wished I did was blow out the area and/or vacuum out the crevices around the injectors before I took them out.
Other than that, have a bunch of rags ready.
jp1seattle is offline   Reply With Quote
Old 08-21-2015, 10:54 PM   #4
Voltwings's Avatar
just pay special care to not lose any O-rings. When putting my cobrajet manifold on I didn't have this problem, but when taking it back off and going to stock I did ... spent THREE DAYS datalogging and going over every stupid vacuum line and checking torque before I finally built a smoke tester and realized I'd just lost an injector o-ring -_- not one of my proudest moments.
Old 08-21-2015, 11:12 PM   #5
Jvibe92's Avatar
Oh gosh. Ok will do. I'll attempt my best 😕
Old 08-23-2015, 06:45 AM   #6
hctr154's Avatar
Definitely keep a shop vac handy; a surprising amount of dust a dirt build down in there. Don't forget to de-pressurize your fuel system first or you will get gas sprayed on your face, clothes, etc.
Sent from my SM-T217S using Mustang Evolution mobile app
2013 GT A6
hctr154 is offline   Reply With Quote
Old 08-23-2015, 09:35 AM   #7
Make sure the rails are fully seated down. All you have to be is careful. Ford provides nice little clips to hold the injectors in. You'll want to pull the rail fully and work in a clean environment. That means disconnecting one line on the drivers side, not really hard. The rail contains A LOT of gas, be ready with the shop rags.
Make sure the injectors go into the line angled like the ones that came out. It's tight in there.
Why are you installing larger injectors?
2014 Premium GT, SGM, Brembo, Auto, Tech, Comfort, etc. GT500s, Steeda UCA, VMP auto N/A tune. 100 shot nitrous on BBR tune. Best e/t 11.42 at 120.64
Old 08-23-2015, 12:57 PM   #8
hctr154's Avatar
I thought he was switching to e85...oh and be sure to put that sound deadening foam back around the injectors. Those injectors are surprisingly loud!
2013 GT A6
Old 08-23-2015, 02:41 PM   #9
dwbrand's Avatar
Really?!?! How are injectors loud?
(That's a serious question, I'm not trying to be a jerk or anything)
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 08-23-2015, 03:18 PM   #10
Jvibe92's Avatar
Yes, I'm going e85. Well looks like this'll be a fun install lol
Old 08-24-2015, 01:06 AM   #11
hctr154's Avatar
You would have to ask an engineer or someone smarter than me as to exactly why. Not a big deal...
2013 GT A6
Old 08-24-2015, 10:15 AM   #12
An injector is just a solenoid (moveable electric valve) with some holes in the end. Eight of them switching on and off at a very high rate of speed makes for some clickety-clack.
Old 08-24-2015, 04:04 PM   #13
UrMaster's Avatar
Just did that and ported my boss intake this past weekend. Looks others have mentioned depressurise the rail and have lot of tags handy. Not a bad swap at all.
Sent from my SM-G925V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 08-24-2015, 04:25 PM   #14
You don't even have to depressurize the fuel rail. Or need a lot of rags. I have done this probably 10 times so far. Pull the fuel line off the rail. Once you get the rails off bring it outside of the garage. And let all the fuel leak out on the ground. Then remove injectors.
Simple takes 30-45 min to swap injectors from start to finish. Very simple. And never once got fuel everywhere
🍼and 🌽 fed coyote.
Old 09-04-2015, 07:23 PM   #15
Jvibe92's Avatar
Are these okay to lube the o rings on the injectors Click image for larger version
Name:	ImageUploadedByMustang Evolution1441412609.655949.jpg
Old 09-04-2015, 08:27 PM   #16
Jvibe92's Avatar
Well the injectors don't fit? They are too small? Anyone know what's happening? I thought it was a direct replacement
Old 09-04-2015, 08:28 PM   #17
UrMaster's Avatar
Why would you grease the of rings, simply pop the Injectors in and reinstall rail.
Old 09-04-2015, 08:34 PM   #18
UrMaster's Avatar
Sounds like you received the wrong Injectors. Mine were direct fit.
Old 09-04-2015, 08:35 PM   #19
No reason they should be to small. Who or where did you get them?
And no do not grease them
🍼and 🌽 fed coyote.
Old 09-04-2015, 08:44 PM   #20
Jvibe92's Avatar
They are like an inch shorter. And it's ford racing bought from a guy on svtperformance website
---------- Post added at 08:44 PM ---------- Previous post was at 08:44 PM ----------
Well a half an inch shorter to be exact
Old 09-04-2015, 08:46 PM   #21
Jvibe92's Avatar
Name:	ImageUploadedByMustang Evolution1441417593.315551.jpg
ID:	190642hese are the ones I got
Old 09-04-2015, 08:49 PM   #22
Lol he sold you the ones from a gt500
They will work with some adapters. But then problems arise. Sell them and buy the proper ones
🍼and 🌽 fed coyote.
Old 09-04-2015, 08:57 PM   #23
Jvibe92's Avatar
Damnnnnit. I got screwed. You think I should just buy directly from Ford dealer tomorrow? Should be roughly same price as on online vendors huh
Old 09-04-2015, 08:58 PM   #24
Lol yes you did.
Go with late model restoration or AM
🍼and 🌽 fed coyote.
Old 09-04-2015, 08:59 PM   #25
Jvibe92's Avatar
I don't get them till Tuesday :/ Labor Day weekend... Damn
Old 09-04-2015, 09:27 PM   #26
Dam late model and Labor Day lol.
Did you tell the guy what you were putting them in? If so he either didn't know. Or just saw $ and didn't give a Sh1t
🍼and 🌽 fed coyote.
Old 09-04-2015, 09:36 PM   #27
hctr154's Avatar
This is what you need.
2013 GT A6
Old 09-04-2015, 09:49 PM   #28
Jvibe92's Avatar
Yeah he knew exactly what I needed. Lied to me I guess :/
---------- Post added at 09:49 PM ---------- Previous post was at 09:48 PM ----------
Yeah. Imma see if anyone is here in Houston that's selling them. I don't feel like putting my old injectors back in. Already paid for my new tune anyways
Old 09-04-2015, 10:53 PM   #29
Jvibe92's Avatar
Well found a guy in houston. Selling for the same price I bought these used. Came from a supercharged whipper 5.0. Less than 5k miles on them. Should be alright?
Old 09-04-2015, 11:01 PM   #30
Yes Just check all the o-rings first.
It's a old style whipple right ?
🍼and 🌽 fed coyote.
Old 09-04-2015, 11:04 PM   #31
Jvibe92's Avatar
What do you mean by old style? It was bought from ford racing
Old 09-04-2015, 11:13 PM   #32
Rear inlet vs the new front inlet.
🍼and 🌽 fed coyote.
Old 09-04-2015, 11:14 PM   #33
Jvibe92's Avatar
Let me ask
Old 09-04-2015, 11:22 PM   #34
Jvibe92's Avatar
It's a rear inlet
Old 09-04-2015, 11:27 PM   #35
It's a rear inlet
Your good then.
🍼and 🌽 fed coyote.
Self installing the boss 302 mani! Any advice or problems anyone has run into? Benzo 2011-2014 Mustang GT 6 10-03-2011 06:23 PM
Roush Insert for back bumper (vinyl decal) - Need to directions 2 install correctly? sk8brdkd Mustang Audio & Video 3 06-02-2010 09:29 PM
AEM Brute Force CAI Install Directions Arlo 2005-2010 Mustang GT 0 02-24-2008 11:26 AM
Directions I am taking in the upcoming months Danger Dude Mustang Audio & Video 15 09-28-2006 08:50 AM
F/S Factory Ford fuel injectors and bran new UD belt for 94-98 v6's Brian M Mustang Parts for Sale and Wanted 16 05-31-2004 09:06 AM
03:48 AM
