Best clutch for 435 RWHP 5.0? - Mustang Evolution
Old 08-26-2015, 06:27 AM   #1
Want something that doesn't sacrifice drivability. It's not a daily but I'd like to have a clutch that isn't a pain to drive around town. How's the exedy 500? Any better?
dude0715 is offline   Reply With Quote
Old 08-26-2015, 06:34 AM   #2
AFIAK the stock clutch is good to 600hp. Don't need to fix what isn't broke. Unless you got one of the early run 2011s with clutch issues that is.
Old 08-26-2015, 11:13 AM   #3
Jvibe92's Avatar
Unless you like to rev over 7k. The stock clutch doesn't hold up well above that point
Jvibe92 is offline   Reply With Quote
Old 08-26-2015, 11:45 AM   #4
Rapinator126's Avatar
Had the stock clutch at 650hp at 7800rpms.
🍼and 🌽 fed coyote.
Old 08-26-2015, 11:47 AM   #5
Then went with spect stage 3+ and aluminum flywheel.
🍼and 🌽 fed coyote.
Old 08-27-2015, 11:19 PM   #6
Redonblackpony's Avatar
My stock clutch lasted almost 4 years. Two years of tracking the car took its toll. One of the four Springs exploded through the clutch plate. When racing my car I shift at 7000+ RPM.
Replaced it with McLeod RST twin disk. Clutch pedal is lighter then stock! Grabs twice as hard.
Redonblackpony is offline   Reply With Quote
Old 08-29-2015, 08:43 AM   #7
tj@steeda's Avatar
This is a very good one & recommended by our experts:
Exedy 2011-14 Mustang Mach 500 Performance Clutch 639-07807CSC | Free Shipping!
Let me know if you would like me to put you in contact with one of our sales professionals to help answer any additional questions you may have.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 08-29-2015, 09:18 AM   #8
🍼and 🌽 fed coyote.
How the **** is that? If I get mine to 7200 rpms, I have no second gear, almost every single damn time. Unless you "short shift" to second then run the other gears out.
2013 GT Premium 5.0 M6 BLACK ON BLACK
MOOSEDAWG29 is offline   Reply With Quote
Old 08-29-2015, 09:24 AM   #9
[QUOTE=MOOSEDAWG29;2284387]
🍼and 🌽 fed coyote.
Old 08-29-2015, 09:26 AM   #10
With the clutch yes I wouldn't bang first to 2nd.
After the clutch swap
Clutch,flywheel, fluid change , shifter, clutch line, spring assist, driver mod it works
🍼and 🌽 fed coyote.
🍼and 🌽 fed coyote.
Old 08-29-2015, 09:28 AM   #11
I hate this app. About to break this dam phone in half also.
But never banged first to 2nd with the stock clutch. Can't hook up anyways so no point.
🍼and 🌽 fed coyote.
Old 08-29-2015, 09:31 AM   #12
Rather be lucky than good any day of the week. Unfortunately, I'm good just not lucky.
Old 08-29-2015, 09:37 AM   #13
Clutch swap will solve a lot of the problems also.
As well as the mgw shifter arm bushing if you have a Barton
🍼and 🌽 fed coyote.
Old 08-29-2015, 09:49 AM   #14
🍼and 🌽 fed coyote.
It's definitely the clutch, it's like it never disengages when I get that high. 7000 fine 7100 basically fine, 7200 not fine. Also I have the mgw race spec and it makes the shifts better but doesn't fix that.
Old 08-29-2015, 09:55 AM   #15
Even when shifting from 2-3, 3-4, 4-5?
🍼and 🌽 fed coyote.
Old 08-29-2015, 10:02 AM   #16
🍼and 🌽 fed coyote.
Old 08-29-2015, 10:35 AM   #17
I don't know that I've ever had a problem with any other gear change other than the 1-2. But then again I don't know that I let it get passed 7000 or 7100 in the other gears. Having to make sure I don't hit 7200 going in to 2nd I guess I don't let myself let it go that far into others either.
Old 09-02-2015, 01:31 AM   #18
I have a supercharged 13 boss,had to change the clutch out too.Any shifting above 7200rpm's and I got locked out too.Changed to a mcleod rst and braided clutch line and now shift as high as 7800 rpm's with zero issues.
chefron50 is offline   Reply With Quote
Old 09-02-2015, 05:53 PM   #19
Yes sir👍🏻
Old 09-04-2015, 07:26 PM   #20
Jdjake's Avatar
Has your original clutch gone out? If not I would keep using the stock one until you have issues.
Jdjake is offline   Reply With Quote
Best tire for 436.7 rwhp car tarch1988 Mustang Wheels & Tires 36 08-02-2015 11:31 AM
How much RWHP/RWTQ can the stock clutch handle? Speed_Mister 1996-2004 Mustang GT 9 12-02-2014 03:18 PM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
best mods for rwhp for stock 3.8l only have $1000 to spend 02mach6stang Pre-2005 V6 Mustang 18 06-11-2008 10:12 AM
99^ longblock for sale, dynoed 233 RWHP w/auto! RGR Mustang Parts for Sale and Wanted 11 03-12-2004 05:31 PM
05:53 PM
