Lower control arm problems on 2013 mustang gt. - Mustang Evolution
Old 08-27-2015, 03:18 PM   #1
I took my car to the dealer because it was making weird noises going over bumbs and cruising on the highway. The tech inspected the car & they told me it was both my front lower control arms needed replacement, they also said both my rear sway bar links needed replacement and that a leak I have over the rear axle is coming from the vent tube which needs an updated part. I am not too familiar with all these suspension components so I was wondering if anybody else has had these problems and how hard would it be for me to just fix this my self. They want alot of money and it seems really fishy that I have to pay for suspension problems on such a new car. I only have about a thousand miles left on the 60,000 mile warranty. The noises are pops going over bumbs and it sounds like something is lose while on the highway. It also makes a popping sound at the wheels when i put it into first gear and give it gas.As for the leak, I got under the car and saw what looked like oil over the drivers side rear on the axle.
silvercoyote is offline   Reply With Quote
Old 08-27-2015, 03:54 PM   #2
Grimkreg's Avatar
I'm curious about the vent tube part update. Because mine leaks and I talked to one of the guys at the dealership and he wasn't the least bit concerned. It was when my buddy worked there too so I'd have thought they would taken good care of me
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Grimkreg is offline   Reply With Quote
Old 08-27-2015, 05:01 PM   #3
Robostang's Avatar
There is a TSB on the front lower control arms. Mine (2012) were replaced under warranty however you are well out of warranty on your car. I replaced them myself on my daughter's 2010 GT. The rubber bushings on the sway bar links are probably considered a normal wear item. I just replaced them on my daughter's car. And I believe that there is a TSB on the rear end vent. The gear oil leaks out of the vent during hard cornering. It really isn't much of a concern other than the oil on the axle. The fix to this is to add a vent tube and reservoir to catch the oil. All of these can be done at home. The lower control arms are the most difficult item and they took me about an hour each to replace. I do have a lift in my garage however. So, the bottom line is....pretty normal for our cars.
Rob
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 08-28-2015, 05:02 AM   #4
etr3.7's Avatar
I had a rear vent changed out at 28,000 miles, and now I am hearing my lca starting to go. I am just going to buy steeda because I am going to lower it, and if the stock one went out in such a short time why replace it with oem, when you can just buy something more Durable and it will help with the handling.
etr3.7 is offline   Reply With Quote
Old 08-28-2015, 06:01 AM   #5
BMR lower control arms and relocation brackets, BMR adjustable upper control arm, BMR adjustable panhard bard. Lower it, call it good.
2013 mustang
For Sale: Bmr upper control arm, lower control arms and relocation brackets blacked out gt Mustang Parts for Sale and Wanted 26 05-30-2014 09:04 AM
2013 V6 lower table-control arm replacement? MrMike 2011-2014 V6 Mustang 16 08-14-2012 09:46 PM
upper/lower control arm install chipshot101 1996-2004 Mustang GT 4 07-27-2004 07:18 PM
Lower control arm bolts Monkey Pre-2005 V6 Mustang 1 07-15-2003 10:37 AM
12:15 PM
