Clutch problem or? - Mustang Evolution
Old 08-30-2015, 05:32 PM   #1
Region: Oregon
Clutch problem or?
2011 gt manual transmission 27k miles
I just bought it a couple weeks ago and have started To notice a slight shudder starting out in first gear. I've read several threads on similar issues but nothing sounds exactly like mine..
After car has sat overnight everything feels perfect until driving 20-30 minutes or so. If all city and/or driving hard it will show up quicker.
It feels as if you are letting the clutch out too fast or not giving it enough gas. I'm eliminating myself as a factor since it's perfect when cold. And I have an 07 gt as well and never had this issue.
If you hold rpms above 2000 it pretty much disappears. If you start out in 2nd it won't show either. If you do an aggressive launch it won't show.
My best guess is the clutch was improperly broke in or driven too hard and it has hot spots on the wheel.
Or maybe a slight fluid leak onto it? I would expect that to be as bad or worse when cold. A bad motor or tranny mount? Same thing, should show when cold.
Bbowl is offline   Reply With Quote
Old 09-07-2015, 02:34 PM   #2
NvrNuf's Avatar
I hate to be the bearer of bad news but I think it's definitely a clutch issue. Of course, it feels OK above 2000 rpm or launching in 2nd gear, but you should be able to start in 1st gear and accelerate slowly. You may need a new clutch.
2014 GT Premium, Custom Painted, 401A, MGW, Brembo, Steeda CAI & 93 Tune
Steeda Sports, HD Mount Koni STR.T BMR Rod/Poly adj. LCA & Relos, PHB & Bracket
Forgestar Custom Painted CF10 19x9+35 & 19x11+42 Roush Grilles & Chin Splitter
FRPP Quad Axleback 3dCarbon GT500 Spoiler MMD Window Louvers SHR Fuel Door JLT Oil Sep.
NvrNuf is offline   Reply With Quote
Clutch adjuster, clutch, or tranny Elcobrachingom SVT Mustang 3 09-05-2012 06:32 PM
clutch slipping and new clutch? iphonemaster93 Pre-2005 V6 Mustang 29 08-06-2012 09:37 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
just installed new clutch ram hdx drove about 5 miles and clutch got really hard? Cobra209 SVT Mustang 11 04-01-2012 04:44 PM
Dual Clutch Vs Single Clutch 504 Stang Rida 1996-2004 Mustang GT 7 11-29-2011 07:22 PM
02:57 AM
