Exhaust help - Mustang Evolution
Old 09-03-2015, 08:31 AM   #1
Exhaust help
I'm getting a lethal performance off road x 3 inch pipe.
Would it hurt the car to go from 3 inches back to stock 2.75 OTA ?
Should I do full 3 inches all the way back?
Thanks!
Lovebryan24 is offline   Reply With Quote
Old 09-06-2015, 02:35 PM   #2
NvrNuf's Avatar
I'm not an exhaust system specialist as this is a complicated science of its own. But as far as I understand, maximum engine performance relies on a certain amount of back pressure and pressure waves timing and good exhaust systems are tuned that way. Increasing a pipe's diameter reduces gas flow, decreasing the diameter increases flow. Changing pipe diameters could affect engine performance, probably just by a small amount.
To answer your question, it won't hurt at all to leave the stock pipes installed.
2014 GT Premium, Custom Painted, 401A, MGW, Brembo, Steeda CAI & 93 Tune
Steeda Sports, HD Mount Koni STR.T BMR Rod/Poly adj. LCA & Relos, PHB & Bracket
Forgestar Custom Painted CF10 19x9+35 & 19x11+42 Roush Grilles & Chin Splitter
FRPP Quad Axleback 3dCarbon GT500 Spoiler MMD Window Louvers SHR Fuel Door JLT Oil Sep.
NvrNuf is offline   Reply With Quote
Old 09-06-2015, 02:40 PM   #3
natestang07's Avatar
There is a good thread from years back explaining the science behind this. "Back pressure" isn't really the right term for it though. I do believe in a na application 3 inch is overkill
Old 09-06-2015, 04:54 PM   #4
The_Chech's Avatar
Not really sure why you would say 3" on N/A is over kill because I made a hell of a lot of power with my 3" setup.
2011 Kona Blue Gt
IG - The_Chech
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 09-06-2015, 05:26 PM   #5
Did you test before and after with the 2.75 and 3 inch?
Old 09-06-2015, 05:31 PM   #6
The_Chech's Avatar
I haven't but I made 50+hp over stock with just exhaust and a tune.
2011 Kona Blue Gt
IG - The_Chech
Old 09-06-2015, 05:35 PM   #7
Sounds about right for a tune headers and catless. I bet the gains m have been the same or Damn near it with 2.75 though
Old 09-06-2015, 05:38 PM   #8
The_Chech's Avatar
The cars getting boosted this winter and my tuner told me to go the bigger route.
2011 Kona Blue Gt
IG - The_Chech
Old 09-06-2015, 05:45 PM   #9
Rapinator126's Avatar
3" will not hurt the coyote na. 98% of aftermarket exhaust is 3" for it.
2.75 is the stock diameter
๐Ÿผand ๐ŸŒฝ fed coyote.
Old 09-06-2015, 06:05 PM   #10
I didn't say it would.. Said it was overkill for na lol. If you plan on boosting it deffinetly is the way to go though
Old 09-06-2015, 06:17 PM   #11
It's not overkill. You have to remember these cars flow a lot on the exhaust side.
A stock pair of coyote heads flow better than a full port job on a 3v.
Old 09-06-2015, 08:23 PM   #12
So going 3 inch exhaust you won't lose any bottom end torque?
chefron50 is offline   Reply With Quote
Old 09-06-2015, 08:36 PM   #13
No
Old 09-06-2015, 08:37 PM   #14
The_Chech's Avatar
Not from what I've seen and from what my car made on the dyno.
2011 Kona Blue Gt
IG - The_Chech
Old 09-06-2015, 08:55 PM   #15
Eturner's Avatar
Check out a thread called. Myths about "Backpressure". Started by...... ME!!!.... ๐Ÿ˜‹
Sent from the One and Only ME!..๐Ÿป
Old 09-06-2015, 08:57 PM   #16
Eturner's Avatar
There is bit of a Science to it!.. Things like pipe diameter, exhaust temp, and so on!.. But 3in pipe should be about perfect for you!..
Old 09-06-2015, 10:40 PM   #17
That was the one I was referring to. Good solid read
Old 09-06-2015, 10:52 PM   #18
Eturner's Avatar
Thanks!.. I found those wright ups a few years ago and decided to post them!.. At the time there where Several people on here Giving a bunch of False Info!.. And insisting how Backpressure is Needed, and Backpressure this and that and so on!.. Was just getting a bit Too annoying to me!.. Hahaha.
Old 09-07-2015, 09:02 AM   #19
Chrism's Avatar
3" all the way in my opinion
Chrism is offline   Reply With Quote
exhaust
Exhaust Exhaust Exhaust cdouglas12 2005-2010 Mustang GT 10 01-24-2015 09:37 PM
Need help Side exhaust skirt! also help with exhaust steven7010 2011-2014 Mustang GT 2 11-06-2014 03:57 AM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
02:27 PM
