Correct trans oil for manual 5.0? - Mustang Evolution
Old 09-07-2015, 06:37 AM   #1
blmustang01's Avatar
Good evening, which is the correct transmission fluid to use for 2013 manual trans 5.0?
Is it XT-M5-QS / WSD-M2C200-D (2nd printing owners manual)
or
XT-11-QDC / WSS-M2C200-D2 (3rd printing owners manual) ?
I am leaning towards Royal Purple 01512 XT-11-QDC and removing factory fluid, shifting is getting notchy, like metal on metal shifting, plus all the occasional grinding with stock shifter I used to do and the 1st owner undoubtedly did with stock shifter, time for fresh oil...
2013 mustang gt/leather/pony projection/gt500 axle backs
blmustang01 is offline   Reply With Quote
Old 09-07-2015, 02:01 PM   #2
NvrNuf's Avatar
Royal Purple is certainly a very good oil, but, if your car is still under warranty, I wouldn't change the oil. If something happens to your MT82, a dealership may blame the oil and won't cover transmission repairs.
My dealership blamed notchy 1st and 2nd gear shifts on my MGW shifter and wouldn't even look into it. However, they added the friction modifier after I mentioned the Ford tech bulletin.
It always depends on the dealership.
2014 GT Premium, Custom Painted, 401A, MGW, Brembo, Steeda CAI & 93 Tune
Steeda Sports, HD Mount Koni STR.T BMR Rod/Poly adj. LCA & Relos, PHB & Bracket
Forgestar Custom Painted CF10 19x9+35 & 19x11+42 Roush Grilles & Chin Splitter
FRPP Quad Axleback 3dCarbon GT500 Spoiler MMD Window Louvers SHR Fuel Door JLT Oil Sep.
NvrNuf is offline   Reply With Quote
Old 09-07-2015, 02:56 PM   #3
I had the shifter/ bracket changed out not because I wanted to but because I had no choice. The stock shifter/bracket is by no means good quality, it is cheap quality causing mishifts, lockouts, grinding so really how could Ford blame a higher grade part for causing problems when they in fact built sloppy cheap quality causing problems to start with? I get how anything mass produced will have issues along the line, however, the stock shifter/bracket is awful and Ford probably won't cover to have it fixed so I fixed it myself.
There is always the "supposed" "risk" "they say" (Ford) of changing out the oil will cause "potential" problems so use "our product brand". I do realize how the transmission is sensitive to what oil is put in, it has to be meet their specs (as RP does). If ANY issues come along with using RP, I would simply drain and pump back in the old fluid but if it shifts like a hot knife through butter using RP then when at what stage would the transmission fail or have issues? Right after or 20k miles down the line? I will take my chance and lots of people use RP. How proprietary could their transmission be that it specifically must have their oil designed for it? I am sure Ford knows many many Mustang owners modify their car under warranty and gives them a good reason to dismiss repairs caused by modifications?
Old 09-07-2015, 04:07 PM   #4
NvrNuf's Avatar
You got a point. Maybe I should do the same thing. Switch to RP and change it back to stock should a warranty problem arise.
Old 09-07-2015, 04:10 PM   #5
Are you being serious? I do consider your warning as well what Ford will tell me as well. Also, you have modified your vehicle beyond what I have could ever do so why is the transmission oil you are afraid to change lol?
Old 09-07-2015, 04:16 PM   #6
NvrNuf's Avatar
Well...I'm hoping that should there ever be an internal tranny problem (synchros?) they couldn't blame that on the shifter, but maybe the oil.
Old 09-07-2015, 04:22 PM   #7
I never understood how a different brand oil is bad on trans when grinding will tear up the syncros with their stock shifter, just doesn't make sense to me.
Old 09-07-2015, 04:39 PM   #8
NvrNuf's Avatar
You are 100% correct. But, as I said in my first post, it depends on the dealership and, knowing mine, they look for any reason you give them not to honor warranty issues. They just don't care. If it's not stock, you're out of luck. Sad, but true.
Old 09-07-2015, 04:51 PM   #9
Exactly. That's when you go to each dealership and tell them as little as possible. They ask is it stock, I say yes! I will just lie to them, why not? They are a car dealership, they get paid to lie and everyone at the car dealership seems like their stress levels are off the charts.
Old 09-08-2015, 05:51 PM   #10
Hey, I'll let you know how the oil change works, changing this weekend for sure. May not do a damn thing but I need to see.
Old 09-08-2015, 06:05 PM   #11
oxford5pointoh's Avatar
I was literally looking into this myself. Rp seems to be the only thing that I can find for the MT-82, but does it also need the friction modifier or no?
Old 09-09-2015, 03:56 AM   #12
I found this Mt-82 fluid swap to RP synchromax, do i need friction modifier? - Ford Mustang Forum
I think it has it.
People sure are terrified to change it, maybe they should be trans is expensive to fix but I need to see if it works better or not.
Old 09-09-2015, 05:00 AM   #13
I think it has it.
Thanks man
1998 Mustang gt correct oil grade mcqueen2653 1996-2004 Mustang GT 8 09-27-2014 11:10 AM
Which Manual Trans Fluid? jjsg09 1996-2004 Mustang GT 9 05-02-2013 03:08 PM
Write one of these choices for each question ( To High) ( to Low) ( correct)? neville Classic Mustangs 7 03-09-2010 08:20 AM
What Oil Filters TO Use, And Not To Use JROC General Car Discussion 10 02-24-2007 08:19 AM
manual trans oil 00stang3.8 Pre-2005 V6 Mustang 4 12-28-2006 03:28 PM
08:59 PM
