Another tire thread - Mustang Evolution
Old 09-08-2015, 08:57 PM   #1
Psmith129's Avatar
Another tire thread
Do any of you guys that are lowered with a staggered setup have any issues with the rear tires rubbing on the fenders ? Tire I'm running is a 275 30/20. I can't feel or hear it rubbing , just noticed tire marks on the inside fender
Psmith129 is offline   Reply With Quote
Old 09-09-2015, 10:29 AM   #2
NvrNuf's Avatar
Lowering the car shifts the axle left. You may need an adjustable panhard bar to center the axle again. It's what I did. I have 285 tires on 19x11 rear wheels (+42mm offset). No rubbing!
2014 GT Premium, Custom Painted, 401A, MGW, Brembo, Steeda CAI & 93 Tune
Steeda Sports, HD Mount Koni STR.T BMR Rod/Poly adj. LCA & Relos, PHB & Bracket
Forgestar Custom Painted CF10 19x9+35 & 19x11+42 Roush Grilles & Chin Splitter
FRPP Quad Axleback 3dCarbon GT500 Spoiler MMD Window Louvers SHR Fuel Door JLT Oil Sep.
NvrNuf is offline   Reply With Quote
Old 09-09-2015, 01:35 PM   #3
The_Chech's Avatar
I have a 305/35/20 in the rear and I'm still able to tuck my tires. Depending on your offset is probably what's causing your tires to rub.
2011 Kona Blue Gt
IG - The_Chech
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 09-09-2015, 03:29 PM   #4
Psmith129's Avatar
That makes sense
Old 09-09-2015, 05:44 PM   #5
olerodder's Avatar
Region: Oregon
I'm not lowered as much as The_Chech.........I'm lowered 2" in the rear and running 285x35/20's on 14 GT500 rims which are 9.5" wide and have a 50mm offset. I'm running 275x40/19's in front with a 44mm offset.
As NvrNuf pointed out........if you don't already have an adjustable pan hard you should probably invest in one. From the factory the rearend is bias towards the drivers side and lowering the car will move it further.................could be as simple as bring the rearend back to center.
I can still go to a 295x35/20 and still be ok.............it's all about the offset.
Old 09-09-2015, 08:30 PM   #6
Psmith129's Avatar
Is there only one way offset can be changed ?
Old 09-09-2015, 08:50 PM   #7
olerodder's Avatar
Region: Oregon
Not sure what you are asking.
Wheel offset can be changed by the wheel manufacturer or you can have specially made wheels, or you change the width of the wheel by having it widened or you can have it narrowed. You can also tub a car and narrow the rear axle and this will all you to put very large wheels and tires inside the body line.................
You can use spacers but I don't recommend them and have never used them as I feel it's a band aid approach...........if you need a certain offset buy a wheel with that offset.
This explains offset a little better;
https://www.rsracing.com/TechWheel.aspx#backspace
Old 09-09-2015, 08:53 PM   #8
Psmith129's Avatar
Cool thanks for the link , that explains it
Old 09-10-2015, 04:02 PM   #9
Diehard's Avatar
Where exactly are the marks you see?
Drivers side/passenger side? Or both?
Inner wheel well/outer wheel well?
You should be able to easily see/measure if the wheels are centered or shifted to one side relative to the body.
Old 09-10-2015, 04:22 PM   #10
Psmith129's Avatar
Marks are on the driver side on the inner wheel well so I'm guessing a panhard bar would fix it
Old 09-10-2015, 04:34 PM   #11
olerodder's Avatar
Region: Oregon
Very easy way to check is take a "plumb bob", a piece of string about 14" long with an nut tied on one end and tape it to the body just above and in the center of the wheel well on both sides. Let it settle.................measure from the string to the wheel rim on both sides. Take one side.....say it is 2.125" and the other is 2", subtract one from the other, which would give you .125 inches....divide that by two and that would be the distance your rearend would have to move....if the distance is less than 1/8th of inch you are pretty much good to go unless you want to try and split the difference.
Hope that helps.
Let us know what the measurements are....Ok?
Another tire thread bigsmitty24 2011-2014 Mustang GT 19 02-23-2014 06:53 PM
another tire thread haha wyostang08 Mustang Wheels & Tires 4 11-15-2012 02:30 AM
05:03 PM
