Rotating noise - Mustang Evolution
Old 09-08-2015, 09:23 PM   #1
stangbaby13's Avatar
Rotating noise
I've been having transmission problems with my 2014 GT. it only has 23k on it. When driving, if I take the car out of gear and coast it, there is a loud rotating noise that comes from the rear of the car. Any idea what it could be?
stangbaby13 is offline   Reply With Quote
Old 09-08-2015, 10:25 PM   #2
still under warrenty take to dealer
ALLYDRIVER1 is offline   Reply With Quote
Old 09-09-2015, 12:37 AM   #3
It's in litigation for a lemon law lawsuit, but I'll try and see wussup. Maybe this time they can figure it out..
Old 09-09-2015, 04:24 AM   #4
Strange Mud's Avatar
if you really want help and you have other info it's helpful to share what other problems/symptoms/things you have tried.
Old 09-09-2015, 08:06 AM   #5
Well, generally, rear end, driveshaft and brake noises stay consistent with road speed. So, clutch in and still there? That isolates the search. Outer axle bearings tend to moan rather than make a rotating sound. inners tend to grind as they disintegrate. Rear gears tend to whine on accel or coast at particular road speeds. Tires tend to rumble as they age, particularly the factory summer Pirellis on BBP or TP.
In and out with the clutch engagement? Transmission and clutch likely culprits.
Variable with rpm? Engine and accessory drives.
Why are you pursuing lemon? What's wrong with the car that's led to that? Is this the only issue? Maybe record it for us and post a vid.
Old 09-09-2015, 09:31 PM   #6
Chopped out tires from lack of maintance? Thats what it sounds like
Old 09-10-2015, 10:33 AM   #7
The noise is while the car is in motion, I can be in gear or out, it's just easier to her when I'm neutral. I can relate the noise to a dyno when they let off the throttle.
I'm pursuing lemon law because the car has had numerous tranny issues,
1. There is a loud popping noise when engaging the clutch in reverse.
So if I'm in revers and I press the clutch while rolling there's a bang!
Ford has tried 5 times to fix the issues but aren't able to. Now that I'm hearing noises coming from what I think is the driveshaft/gears.
2. Extreme rocking in any RPM. This problem mostly occurs in traffic. I can be in 1st-6th gear at any rpm and the car becomes very jerky while adding throttle or taking my foot off the throttle.
It's not the tires, I have 305 MTs on the rear, I am not lowered so there shouldn't be any even wear. The tires only have 10k.
Old 09-10-2015, 07:51 PM   #8
Senior Member
Spartanator's Avatar
Sucks that you are lemonizing it. Are you the original owner?
MT-82 hate.
Spartanator is offline   Reply With Quote
Old 09-10-2015, 08:04 PM   #9
I'm looking at it as a new start, I took off all the mods except for the rims. And yeah I got it new
Lightening your Rotating Mass Effect Trojan Horse Pictures and Videos 0 10-31-2011 10:27 AM
Rotating assembly Dannyb937 2005-2010 Mustang GT 47 01-06-2011 07:32 AM
Rotating Assembly upton7 1996-2004 Mustang GT 4 06-30-2009 07:17 PM
4.2 rotating assembly, MORE!!! RGR Mustang Parts for Sale and Wanted 4 04-20-2006 08:15 PM
w00t got most of my rotating assembly today Brent Pictures and Videos 27 06-25-2005 04:15 PM
04:29 PM
