Brake rotor replacement? - Mustang Evolution
Old 09-09-2015, 09:11 PM   #1
Region: New Mexico
Hey guys, it's time to replace pads and rotors in the next couple months for me. I'm the kinda guy that usually chooses to upgrade instead of stock if replacement is due but, I'd love to hear other's ideas. I'm thinking a nice slotted and/or drilled. What do y'all think?
I have a '14 GT with the Brembo package.
Sent from my SM-G900P using Mustang Evolution mobile app
slimguns is offline   Reply With Quote
Old 09-10-2015, 09:40 AM   #2
olerodder's Avatar
Region: Oregon
Personally I think cross drilled rotors are more prone to cracking under high heat loads and although they look neat I can't see using them on the street or the track.
I would just go with OE rotors or even have your's turned as long as you stay within the recommended thickness that is stamped on the rotor. Spending $20 a rotor to have them turned sure beats $90 for new.
How about converting your puny 11.8" rear rotors to 13.8" GT500 rotors. I did on my TrakPak Mustang.........having the extra 2" of rotor sure looks a lot better and fills up the wheel better...........stops a little better and will dissipate heat a lot better than the stock ones. Since I didn't want to install the OE GT500 caliper bracket I bought relocation brackets along with OE GT500 rear rotors...took about an hour to do both sides.................IMHO
Old 09-10-2015, 02:18 PM   #3
jande063's Avatar
I agree with OleRodder, I also avoid slotted or drilled rotors. With a modern pad, there is just no need for the gas escape path provided by either.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 09-10-2015, 02:26 PM   #4
You have really good brakes. I've found Raybestos rotors to be superior and Centric makes a really good dust free ceramic pad called the "Posi Quiet". You can get both on Rockauto.
The cross drilled rotors are kinda gimmicky IMO especially for a street car.
2000 Mustang GT Steeda build #48. Bolt ons, suspension, Novi 2000.
Old 09-10-2015, 08:09 PM   #5
ddtmoto's Avatar
Region: Utah
On mine I went with drilled rotors, as usual for me, and upgraded to this guy's brake bracket/adapters to use 13.8" GT500 rotors on the rear to more match the size of the front Brembos. Looks so much better filling the huge open space of the tiny oem rear brake setup. I have used drilled rotors for many years on my street cars and trucks. All of my motorcycles have drilled rotors, track bike included. Apples and oranges, I know.
05 14 Mustang 14" Rear Brake Rotor Adapter Brackets GT Boss 302 GT500 V6 13 8" | eBay
ddtmoto is offline   Reply With Quote
Old 09-11-2015, 10:45 PM   #6
Region: New Mexico
And these work wroth the brembo calipers?
Old 09-12-2015, 07:07 AM   #7
ddtmoto's Avatar
Region: Utah
They upgrade the rear tiny stock rotors, this set-up don't touch the front calipers/rotors. Just the ticket for the BBP systems.
Old 09-12-2015, 09:37 AM   #8
olerodder's Avatar
Region: Oregon
Brembo brake packaged Mustangs only have Brembo calipers in front. They share rear calipers with Boss/GT500............all you need to do is either buy the OE bracket and tear your rear end down and pull the axles to put the OE bracket on or buy the Ebay guys bracket which just moves the caliper up to match the 13.8" rear rotor.
One on the left is with the 11.8" rotor and one on the right is the 13.8" rotor. The wheels are 2014 GT500's and are 20" diameter and I'm using OE Ford rotors.
Name:	2015-04-08 10.54.47.jpg
ID:	191017   Click image for larger version
Name:	2015-04-11 12.52.16.jpg
Old 09-12-2015, 07:21 PM   #9
ddtmoto's Avatar
Region: Utah
...from puny, to manly. Size does matter....
Old 09-12-2015, 08:19 PM   #10
Would it just be easier to buy those adapters from eBay than removing your axels? I've never removed them before, but am not afraid to experiment.
Old 09-12-2015, 09:18 PM   #11
ddtmoto's Avatar
Region: Utah
Oh yes, so much easier. The adapters make it a relatively simple job. The toughest part is waiting for the rotors and adapters to arrive.
Old 09-12-2015, 10:59 PM   #12
Region: New Mexico
I think I'll have to go that route. Relatively simple and looks great! I'm sold. ..
Last thing, so i just buy a 2014 gt500 rear rotor and the brackets, that's it right?
Thank you all for the idea. ..
Old 09-13-2015, 08:35 AM   #13
ddtmoto's Avatar
Region: Utah
Yes sir. Brackets and the rotors, that's it.... the self adjusting park brake caliper pistons will probably need to be run back into their bore a bit to accommodate for new pads or fresh rotors. The piston rotating brake tool is very helpful for this ....
Old 09-13-2015, 10:29 AM   #14
No need to upgrade the calipers? Stock GT ones will work?
Old 09-13-2015, 01:38 PM   #15
olerodder's Avatar
Region: Oregon
Stock GT calipers actually are the same ones used on the Boss 302 and GT500, the only difference are the pads.
I would suggest for anyone living where they salt the roads or use chemicals on the roads during winter to prime/paint the aluminum brackets before putting them on so they don't corrode, and to buy the same type of pads you have in front on your car currently. It's a very straight forward procedure. Yes, NAPA sells the brake tool for twisting the caliper pistons back in.........you will need to do this........and also unscrew the master cylinder and put a rag over the opening so it it would burp back it won't splash on the engine/firewall/fenders. This just helps relieve the pressure when you screw the caliper pistons back in.....remember liquid does not compress.
Old 07-22-2016, 11:31 PM   #16
Region: New Mexico
So I'm finally buying parts to do this and want to answer one last question.
Do i need longer brake lines? I could've sworn I read that but I cannot find it now. Did I make that up somewhere along the way?
Thanks again guys. ..
Old 07-23-2016, 12:46 AM   #17
olerodder's Avatar
Region: Oregon
You do not need loner brake lines for the rear.
When you take the rear calipers off I don't remember if you have to disconnect the emergency brake cable at the caliper or not...also if you have the aluminum adapters off EBay you should prime them and paint them before you put them on.
Old 07-24-2016, 03:13 AM   #18
five.ohhh's Avatar
Region: Iowa
Very informative guys! Thank you!
2014 GT Track Pack 6MT
five.ohhh is offline   Reply With Quote
2004 Bullitt Mustang Rear Rotor Replacement Question junoS197Bl08 1996-2004 Mustang GT 7 06-07-2011 02:45 PM
rear brake rotor hot mightymav72 Pre-2005 V6 Mustang 6 12-27-2010 07:34 PM
Brake Rotor Concern runvsofthisbull Pre-2005 V6 Mustang 20 03-30-2010 08:01 AM
Brake rotor question colinsv6stang Pre-2005 V6 Mustang 5 03-29-2006 09:33 AM
Brakes and Rotor replacement robert0803 Pre-2005 V6 Mustang 11 08-14-2004 11:56 AM
12:13 PM
