Rear End Suspension Noise?? - Mustang Evolution
Old 09-11-2015, 12:40 AM   #1
Hey Everyone, hoping someone can help me out with this. I have a 2014 5.0 and am hearing a clunking noise from the rear end of the car. I started hearing this noise after I installed my adjustable panhard bar which was installed about a week or 2 after my SR lowering springs. I am pretty sure it came after my panhard bar, which is when I started noticing it. It makes noise when ever going over uneven pavement, and potholes at lower speeds, 0-30mph. Closest resemblance would be like something rolling around in your trunk. All the springs are sitting correctly, everything is bolted up except passenger side nut on the panhard bar that you loosen to make adjustments because I could not tighten it when the bar was bolted on so I was going to get to it later. The driver side bolt is tight and the bar does not rotate either. I am going to tighten that bolt but i doubt its causing that noise. Anything else I should look at while I am down there? Bump stops? Also would tightening the rear swaybar too much cause that noise also? Thanks for any help!
visback is offline   Reply With Quote
Old 09-11-2015, 07:10 AM   #2
KARgt13's Avatar
I have the same clunk. I've tried everything shock and spring related. It's quite probably your sway bar end links. That's where all research has led me. The factory ones are known to go bad fairly quickly. I just haven't gotten to the dealership to have them check it.
KARgt13 is offline   Reply With Quote
Old 09-11-2015, 10:00 AM   #3
primemover's Avatar
I had the same noise after a repair was done to my car. Brought it back to the shop and they admitted they didn't tighten the pan hard bar all the way. The noise is gone now.
2014 GT brembo package manual trans. 3.55 gears
Roush axle backs
Bama v2 performance tune.
primemover is offline   Reply With Quote
Old 09-11-2015, 01:04 PM   #4
bazinga11's Avatar
A good reason for suspension related clunks is mostly the bolts not torqued to spec. Just food for thought for future modding
Sent from my SGH-I337M using Mustang Evolution mobile app
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
Rear end noise??? woodly1069 Pre-2005 V6 Mustang 2 04-30-2008 07:56 AM
Rear end noise bsmith782 1996-2004 Mustang GT 31 08-23-2006 08:46 AM
rear end noise + PS favor jimmy_beaner The Bar 10 06-21-2005 12:00 AM
08:15 AM
