Removing Catylatic converters - Mustang Evolution
Old 09-12-2015, 12:07 PM   #1
What is the easiest way to bust the nuts loose on the studs to pull the cats?
5.joe is offline   Reply With Quote
Old 09-12-2015, 03:28 PM   #2
Jreeves30's Avatar
Lots of pb blaster. Let it sit for an hour or so then add some more. 3 ft extension through the hood and a 15mm universal socket for the top passenger side nut. A lot of strength is needed to break them loose. Just be prepared. I though I was going to break my ratchet but they finally came loose. Good luck!
A couple more months and my license plate will say 1fstcpa!!!!
I'm only and accountant to feed my car parts addiction.
Jreeves30 is offline   Reply With Quote
Old 09-12-2015, 05:17 PM   #3
Thank you for the advice! I finally said screw it and busted out the torch.
Old 09-13-2015, 02:18 AM   #4
Jreeves30's Avatar
Lol. That works too! If you were in the Orlando area I would have just told you to bring it over. I have done this to two separate 5.0s now (including my own).
Old 09-13-2015, 03:57 AM   #5
RJ13GT's Avatar
Yeah mine were incredibly hard to remove for a car as new as it is. They squeeked the whole way off. That is after pb blaster the day before and before removal.
Sent from my SCH-I545 using Tapatalk
2013 5.0, Black, Auto, Procharger P1SC stg 2, 4.13'' pulley(8 psi), JMS bap, 3'' x pipe, Circle D 3c, Kooks axleback, BMR control arms. 593rwhp
RJ13GT is offline   Reply With Quote
Old 09-13-2015, 09:01 AM   #6
Old school trick if heat isn't an option. Get in there and tighten the nuts a 1/4 turn. It breaks the thread interface and then 9 out of 10 will wind right off.
This from rebuilding turbo hot sides; I guarantee ther is no mor stuck nut on planet earth than those.
Another trick to add to the torch's effectiveness, have a hose or squirt bottle with water ready. Heat the sucker up hard slam water into it. This shock cooling often blows the rust right off.
Old 09-13-2015, 10:33 AM   #7
All I had was wd40, sprayed that on, waited an hour, came off after that luckily.
Old 09-13-2015, 06:06 PM   #8
WhiteCali5oh's Avatar
Region: West Virgina
Used 3 ft extension through the engine bay, with an impact and it came right off. Went back on the same way. Also using a swivel socket made it way
Easier to get the correct angle needed.
WhiteCali5oh is offline   Reply With Quote
Old 09-13-2015, 06:41 PM   #9
Yeah, I'd recommend a swivel socket. I didn't have one (nor did I have an impact), so I was only able to get the tip of the socket on the bolt.
Old 09-14-2015, 07:53 AM   #10
REG
Bolts
I soaked them anywhere from a few hours to over a day. I had the passenger side outer stud break, it went a 1/4 turn and just snapped.
We could punch the stud out, even with map gas heating it, so we ended up drilling it and welding a s/s nut to the back of it and using a s/s bolt.
Difficult to start but once it went it was fine. Put antisieze on everything, did n't want to risk breaking another stud.
REG is offline   Reply With Quote
Old 09-14-2015, 08:28 AM   #11
RJ13GT's Avatar
I had one stud strip i cut the stud off and went thru about every drill bit i had and about an hour drilling that hard mofo out.
help removing the catalytic converters RocknCali 2011-2014 V6 Mustang 8 08-02-2013 10:45 PM
removing catalytic converters exclusive_10 2011-2014 Mustang GT 33 06-26-2013 08:23 PM
Removing converters, MIL eliminators tommygrubb2001 Pre-2005 V6 Mustang 10 02-25-2013 04:11 PM
Catylatic converters??? Blackedout General Mustang Discussion 75 03-07-2011 07:00 PM
help with torque converters and shift kits charkelly9 Pre-2005 V6 Mustang 6 08-26-2004 03:45 PM
02:31 PM
