How do I unplug this connector?(pics) - Mustang Evolution
Old 09-13-2015, 12:17 PM   #1
As stated I think the fan connector wire is cooked causing the fan not to come on.
Name:	ImageUploadedByMustang Evolution1442168235.624532.jpg
Name:	ImageUploadedByMustang Evolution1442168208.324810.jpg
dude0715 is offline   Reply With Quote
Old 09-13-2015, 12:39 PM   #2
Robostang's Avatar
Hmmm...trying to understand the question. It looks like you unplugged it already?
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 09-13-2015, 12:41 PM   #3
It's was the gray peice on pic 1 I ended up getting it. Now my issue is what is this called and how do I get one.
Name:	ImageUploadedByMustang Evolution1442169673.642854.jpg
Old 09-13-2015, 12:53 PM   #4
Robostang's Avatar
You will probably need to buy the entire harness. It looks like there might be a part number on that label that is on it. Other than a Ford dealer, you might search a salvage yard for a used one.
Old 09-13-2015, 01:13 PM   #5
Attachment 191085
Attachment 191084
go to any good parts house ask for a cooling fan connector pigtail,will come with 6/8 inchs wire.solder on and use heat shrink pver solder joints.or like someone else said go to junk yard with wire cutters and snip one off
ALLYDRIVER1 is offline   Reply With Quote
Old 09-13-2015, 01:15 PM   #6
from looks of connector,fan motor bad, drawing to much current melted plug. replace pigtail and fan motor
Old 09-13-2015, 01:18 PM   #7
Robostang's Avatar
Good point. Best to find the cause of that burnt connector and fix it. Of course it could be that the connection at that point was bad.
Old 09-13-2015, 10:29 PM   #8
Turned out just the wire was bad. Fan motor still good so happy
Old 09-13-2015, 10:47 PM   #9
turned out just the wire was bad. Fan motor still good so happy
sent from my iphone using mustang evolution
what was the amp draw on fan?
Old 09-14-2015, 11:55 AM   #10
thelastsumurai's Avatar
Attachment 191090
Looks like a ford part number on there. Go to the parts department at your local ford dealer...
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 09-15-2015, 04:08 PM   #11
WJBertrand's Avatar
That part is called a blower resistor, it's what provides different fan speeds for your HVAC system.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Spout connector 86gt 1979-1995 Mustang GT 7 10-01-2011 03:50 PM
subframe connector kickerofdoom Pre-2005 V6 Mustang 1 04-11-2011 04:04 PM
Programming connector 96mustangmaine 1996-2004 Mustang GT 2 03-31-2011 08:27 AM
inspection connector JerryK123 1996-2004 Mustang GT 0 09-03-2010 03:17 AM
01:41 PM
