My 2014 GT - Mustang Evolution
Old 09-15-2015, 07:28 PM   #1
Junior Member
kinda_slow5oh's Avatar
My 2014 GT
Mods:
MGW race spec short throw shifter, Roush axlebacks, Blow By Racing offroad x pipe, MPT 91 performance tune, MPT ghost cam tune, cervinis 4 inch cowl hood, Niche targa 20x8.5/20x10, Boss 302 rear diffuser, Eibach sportlines (not installed yet)
ID:	191213Click image for larger version
ID:	191214Click image for larger version
ID:	191215Click image for larger version
Sent from my LG-H810 using Tapatalk
kinda_slow5oh is offline   Reply With Quote
Old 09-15-2015, 08:13 PM   #2
2014oxstang's Avatar
Big fan of the hood.
2014oxstang is offline   Reply With Quote
Old 09-15-2015, 08:21 PM   #3
Junior Member
Thanks! I love it so much. Visibility sucks but you get used to it. I don't even notice it's there anymore lol
Old 09-15-2015, 09:42 PM   #4
I have the same hood. Love it
Old 09-15-2015, 09:46 PM   #5
Senior Member
Spartanator's Avatar
Not bad. If I had that big of hood, a blower would be required for me. Still shopping for a nice hood for my 2011 GT so I can't talk much... lol
MT-82 hate.
Spartanator is offline   Reply With Quote
Old 09-15-2015, 09:49 PM   #6
Junior Member
Ha ya I get questions daily about if it's boosted. Can't afford it yet but TTs are in the works.
Old 09-15-2015, 09:58 PM   #7
Rapinator126's Avatar
Single turbo is the best way to go on the coyotes. The twins add the eye candy but if your looking for all out performance. The single is the best bet.
I know of a few fast twin coyotes.
Just a proper sized single will hold the upper hand every time.
🍼and 🌽 fed coyote.
Old 09-15-2015, 11:37 PM   #8
🍼and 🌽 fed coyote.
What's the best kit out there Rap for a single? I'm assuming you wouldn't be able to run much boost SAFELY with stock compression? I'm going to be in the market soon for some FI.
Old 09-15-2015, 11:57 PM   #9
CPR
JPC
EDP
Any of those 3 will be amazing.
6psi with any of these kits will put you at what the motor will be good for with stock internals.
🍼and 🌽 fed coyote.
Old 09-16-2015, 05:22 AM   #10
I know a lot of people don't care for hellion kits but if you do a little fabrication work to it and run a different brand waste gate than theirs they can be beast. A friend of mine has one of their single kits and he gives my car running 12psi through a VMP a good run for its money at only 8 psi with his single turbo.
Old 09-16-2015, 09:08 AM   #11
I good portion of the piping needs to be replaced or fabricated once you get into high boost with the hellion single. At low boost it works good.
But if you want to start pushing 14psi + your going to have a big issues unless a good 40% is swapped out of fabricated.
🍼and 🌽 fed coyote.
Old 09-16-2015, 09:09 AM   #12
Junior Member
🍼and 🌽 fed coyote.
I see that your car is bottle fed. I was thinking about doing that before I boost it. Is your engine built?
Old 09-16-2015, 09:09 AM   #13
Sterlingbeast5.0's Avatar
Love the car man... GREAT color lol
Old 09-16-2015, 09:11 AM   #14
Junior Member
Ha thanks man. If only I could get in the American Muscle magazine like you lol.
Old 09-16-2015, 09:17 AM   #15
Yes it has a built motor.
🍼and 🌽 fed coyote.
Old 09-26-2015, 11:49 PM   #16
robbespz5.0's Avatar
🍼and 🌽 fed coyote.
Just searched EDP and came up on this thread, what experiences have guys had with this shop, I'm in Colorado Springs and they are right down the road and since I've been debating wether to go with a vortech/paxton or single turbo (since i keep hearing from you that it's the way to go on the coyotes) this just might be the perfect answer. I have stock motor and tranny for now.
11' 5.Ohhhhh Prem
robbespz5.0 is offline   Reply With Quote
Old 09-27-2015, 05:49 AM   #17
11' 5.Ohhhhh Prem
I know of 2 cars out in Austin with the kit. Both cars are stock motor also.
If I was to go single it would be the EDP kit. His price is good and if you order directly from him he has a unbeatable price on id1,000's also.
You will loose your front seat bar with his kit also.
🍼and 🌽 fed coyote.
Old 09-27-2015, 07:56 AM   #18
🍼and 🌽 fed coyote.
Well looks like I'll be going down to his shop this coming week so we can make plans for this winter. Thanks Rap. What route are you going with yours as of now.
What do you mean loose front seat bar?
11' 5.Ohhhhh Prem
Old 09-27-2015, 08:08 AM   #19
11' 5.Ohhhhh Prem
No problem
For me I'm Moving back to Houston in a few days. Once I get settled back in I will decide what I'm going to do.
The front sway bar has to be removed for the kit to be installed.
🍼and 🌽 fed coyote.
Old 09-27-2015, 12:04 PM   #20
There's a lot of guys running into issues with valve float when going above factory redline with the EDP kit. Seems the kit wasn't well designed to do anything but run to 6600rpm at less than 10psi. With all the issues arising with this kit, I'd stay away from it. For a single kit, I'd go with CPR.
SecretAgent is offline   Reply With Quote
Old 09-27-2015, 12:17 PM   #21
My 2014 GT
Wrong. Valve float happens with the stock valve springs usually around 700hp. And 7,000 + Plenty of people at the 800+ level with the CPR kit. It's identical to JPC
Nothing a set of trick flow valve springs won't fix. The boss ones are crap spend the $ and do it right the first time.
🍼and 🌽 fed coyote.
Old 09-27-2015, 01:25 PM   #22
The EDP kit has significantly more back pressure than both the JPC and CPR, making it more susceptible to valve float. Don't see how anything I've said here is wrong. But I forget I'm talking to the forum know it all.
Reason I'd choose the CPR over is Sam. Nothing against Justin or JPC, but if I can get pretty much the exact kit for a little bit cheaper, and have more personal customer service, I'm going with that.
Old 09-27-2015, 01:34 PM   #23
I'm explaining my personal experiences with valve float ect.
I have seen back pressure problems on the coyotes also. And they usually lift a head b4 the springs start to float.
High rpms and HP is usually what causes valve float on these cars.
I have not seen anyone with back pressure problems on the EDP kit. And for a price of $5,600 shipped it's hard to beat.
And even if you ran this kit at 6psi with e85 and made 650 with the 7475 it will be a rocket. And take down a blown coyote making 100 more to the ground.
The kit comes on strong
🍼and 🌽 fed coyote.
Old 09-27-2015, 01:38 PM   #24
And everything I say is from personal experience. I like how a lot of you pull the "forum know it all" BS but hey I don't care. At the end of the day i will give my experiences and stick to them.
🍼and 🌽 fed coyote.
Old 09-27-2015, 01:43 PM   #25
Last time I checked CPR was asking mid $6,000's for their kit?
JPC is $6,700 I believe.
At the end of the day though a single is a better choice over a twin kit IMO.
Twins are good for the eye candy if that's what your looking for.
🍼and 🌽 fed coyote.
Old 09-27-2015, 01:51 PM   #26
Lots of guys unhappy with the EDP kit around. They're running into valve float way before guys running other kits are. For a kit that's marketed as ready for 1200hp it's got a lot of explaining to do. The 2.5" up pipe and smaller exhaust housing are I think to blame, but I haven't had a kit in front of me to flow test so I can't say for sure. But there's plenty of people out there with issues, enough to keep me away from it until they figure out the root cause, or redesign the flaw.
Sorry for coming off brash, I'm speaking from experience as well, been in the turbo game for a long time.
Old 09-27-2015, 01:58 PM   #27
Pretty sure he changed the newer kits to a 3", may be wrong though.
If I do get it I will be going with the 74/75 vs the 76/75 so we will see how it does on my car once I'm get to start on her again.
🍼and 🌽 fed coyote.
Old 09-28-2015, 12:19 PM   #28
🍼and 🌽 fed coyote.
Keep us updated
11' 5.Ohhhhh Prem
Old 09-29-2015, 11:36 PM   #29
natestang07's Avatar
Originally Posted by white5o View Post
man that color though, Love it
Stop spamming for 50 posts. That crap is annoying.
Old 10-01-2015, 01:06 AM   #30
kapcan2k's Avatar
Love the picture with the flags
kapcan2k is offline   Reply With Quote
Old 10-07-2015, 07:33 PM   #31
Junior Member
Thank you
Old 10-07-2015, 07:34 PM   #32
Junior Member
Thanks! That was a little spontaneous idea we had on Memorial day and we started driving around with them. People started honking and yelling murica at us lol.
2014 Mustang :: 2014 Ford GT Celtic Member Garages 0 08-23-2014 12:59 PM
Traded a 2014 base for a 2014 premium nd4spd24 2011-2014 V6 Mustang 31 07-11-2014 08:18 AM
MARCH 2014: 709HP GT500 PLUS Blown 2014 GT Near Crash! - AmericanMuscle.com AMDanBailer AmericanMuscle 5 03-17-2014 08:19 AM
Mustang GT 5.0 2014 :: 2014 Ford Mustang jeanmorissette Member Garages 0 09-20-2013 07:08 PM
07:17 AM
