Tire patch - Mustang Evolution
Old 09-15-2015, 09:09 PM   #1
Psmith129's Avatar
Tire patch
Just put on some new nitto nt555's and had the misfortune of running over a screw within a week of having them . For those that have patched a tire ,will I be expecting the tire to not last as long ? Screw went into the tread luckily and not the sidewall .
Psmith129 is offline   Reply With Quote
Old 09-15-2015, 09:12 PM   #2
Rosariors3's Avatar
Have no experience about screw or nail in the tire and tread wear but I can't c why ur tire would wear more than the others
I might not know as much as you but i know how to drive better than you!!!
Rosariors3 is offline   Reply With Quote
Old 09-15-2015, 09:18 PM   #3
Psmith129's Avatar
Ya I don't think it will wear any different , just wondering about the longevity of a patch hoping it doesn't leak on me
Old 09-15-2015, 09:20 PM   #4
Rosariors3's Avatar
^ how do u like the tires? What did u have before them?
Old 09-15-2015, 09:21 PM   #5
oxford5pointoh's Avatar
It will be fine. If you have it patched the "right" way by having a shop pull the tire off and patch it from inside then re mount and balance you will never even know the difference. Those plug kits they sell where you stick the strip of rubber in from the outside of the tire are hit and miss. If it doesn't get a good seal you might get a slow leak that leads to abnormal wear if you don't keep up with it.
Old 09-15-2015, 09:23 PM   #6
Redonblackpony's Avatar
The patch will hold up just fine.
I had a screw in my Mickey Thompson Street Comp and had it patched. It held up to multiple road course lap days pushing the tires at their limits multiple times.
Redonblackpony is offline   Reply With Quote
Old 09-15-2015, 09:57 PM   #7
Senior Member
Spartanator's Avatar
If your a higher speed runner I'd watch that foot. I run 100+ almost daily but I also inspect my tires before I do so.
If it is patched correctly you should be fine for a while. Just keep an eye on the PSI.
I get my tires from Discount Tire and always get the warranty thing so I am covered.
When my mom bought her 2012 M3 vert' sticky tires (woman car) they were building 3-5 houses in the neighborhood. Can't tell you how many times the dealership replaced the tire(s) under warranty. She used to make me walk the street and I would find 2-6 nails, daily...
MT-82 hate.
Spartanator is offline   Reply With Quote
Old 09-15-2015, 10:11 PM   #8
Psmith129's Avatar
I like the tire so far , it's a good tire for a daily and has plenty of grip .It was between the Mickey Thompson and these but the Mickeys are on back order from quite a few places out here .
Old 09-15-2015, 10:15 PM   #9
Psmith129's Avatar
Thanks guys , glad to hear the patch will be fine . Still sucks picking up a screw with a brand new tire but it happens . I don't think I would ever try those plugs . Heard some horror stories . Out here in California they banned them from many tire places and dealerships due to failure.
Old 09-16-2015, 09:15 AM   #10
OX1
I'd put that patched tire on the back if possible.
Should be fine, but I'd always rather have a
flat (if/when) on the back than my steering end.
86 Capri, turbo, 3.27's-12.66 @ 107.75
14 GT-Roush Phs 3, VMP 93 tune, Whiteline Sway Bars, Roush U/L Rear Control Arms, Street 18 X 9/10 Bullits with 295/255 NT05/555's-Track 18 X 8/10 Bullit's on 305/35R18 MT ET STR SS and 235/50ZR-18 Michelin PSS
OX1 is offline   Reply With Quote
Old 09-16-2015, 09:32 AM   #11
Psmith129's Avatar
Patch is on the back thankfully
Old 09-16-2015, 02:54 PM   #12
showsomeskin's Avatar
Any time you plug or patch a tire you have lost the speed rating of the tire
Just FYI
showsomeskin is offline   Reply With Quote
Old 09-16-2015, 03:01 PM   #13
if tire was removed from rim and patched correctly with a patch that has a tit that fills and seals hole it will be good.only problem is you lose speed rating because belt was punctured.don't drive at high speed it might come apart.
ALLYDRIVER1 is offline   Reply With Quote
Old 09-16-2015, 03:30 PM   #14
rrharley91's Avatar
It's called a plug patch and if installed right will not affect you tire wear. As long as it was done by someone who did it correctly your good to go.
Sent from my SAMSUNG-SM-G890A using Mustang Evolution mobile app
rrharley91 is offline   Reply With Quote
Biggest rear tire size on 18" tire ChrisMustangs Mustang Wheels & Tires 6 06-24-2013 02:46 PM
Body Work on 2001 GT- looking for patch panel? Mikoh77 1996-2004 Mustang GT 3 05-16-2013 04:56 PM
tire questions for the tire guru's strictly180 2011-2014 Mustang GT 13 06-13-2012 09:00 AM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Fake Microsoft patch email Herbstang The Bar 4 06-27-2007 08:00 PM
06:04 PM
