help watermarks on my 13-14 taillights mustang.. - Mustang Evolution
Old 09-18-2015, 02:58 PM   #1
orellana5.0's Avatar
Name:	ImageUploadedByMustang Evolution1442609844.520121.jpg
Anyone out there know how to removed this ? Not sure if is from the inside or outside. I've washed my car and here in Texas is always hot and I just can't seem to take these off not sure if is from the inside or need something else to remove it has anyone else had this problem.
orellana5.0 is offline   Reply With Quote
Old 09-18-2015, 06:46 PM   #2
DiESeven's Avatar
I had the same thing. I couldn't get it off. I was lucky enough for the dealership to get them replaced under warranty. It was a battle though.
Instagram: @v6beast
Old 09-18-2015, 07:15 PM   #3
oxford5pointoh's Avatar
I started getting that on mine after I made fun of DieSevens. But I was able to buff mine out. Good as new
Old 09-18-2015, 08:02 PM   #4
Seanp94's Avatar
Try using a clay bar to remove it.
Seanp94 is offline   Reply With Quote
Old 09-18-2015, 08:57 PM   #5
Kevin.Cook
Guest
Posts: n/a
I get that on mine here in Texas also. I use a shammy and Invisible Glass cleaner and it gets them looking shiny and new. Might be worth a try?
Old 09-18-2015, 09:12 PM   #6
NewMtang's Avatar
Thumbs up Good Luck.
Originally Posted by orellana5.0 View Post
Attachment 191309
______________
Since the 13-14s are all sealed units, try the following. Use some white vinegar on it to clean the water spots. Poor water from the inside of the trunk around the seal of the lights. If it is on the inside, take it to the dealer if it is under warranty.
You might check and see if there are any bulletins posted about this and if you can diagnose it yourself, get your car back quicker.
If it isn't under warranty, get a tube of black silicone and put it on the inside, making a seal.
Good Luck.....
Old 09-19-2015, 12:39 AM   #7
Just buff it out with some fine polish. I use an orbital on mine and they come out looking nice.
ads245 is offline   Reply With Quote
Old 09-19-2015, 11:27 AM   #8
Water marks on tai lights
Try Blue Magic or Duz All
tonyjuan is offline   Reply With Quote
Old 09-19-2015, 02:13 PM   #9
I wouldn't use Blue Magic, that is a Metal Polish. . . .
Old 09-19-2015, 02:41 PM   #10
hobo1's Avatar
Wash more often, use 303 on it a few times a year. You'll never get them.
Another solution - use Griots Garage #3 then #2 with a terrycloth towel. Polish with each, then wipe off and 303 it.
Piloting a '13 GT with track, frpp handling, glass, mgw, bmr and sct
hobo1 is offline   Reply With Quote
Old 09-19-2015, 03:44 PM   #11
Use Blue Magic head light restore. It'll do the job. BTW, I use the metal polish on plastic before and it didn't harm the plastic, it actually worked pretty good.
10:59 PM
