Dyno Results for E85 bolt on 5.0 - Mustang Evolution
Old 09-19-2015, 12:10 PM   #1
Jvibe92's Avatar
Well just made the switch. Made 415hp/400tq on the first dyno run. Running an off-road h pipe, intake, and AED E85 base tune. Gas was actually e70, as per test kit results. No knock. More timing and power to be had.
Just letting y'all know if y'all want to know results on the switch. Gain was 20hp/13tq. Only have a picture of my 93 run. I'll upload the e85 later tonight.
Name:	ImageUploadedByMustang Evolution1442682618.079184.jpg
Jvibe92 is offline   Reply With Quote
Old 09-19-2015, 01:14 PM   #2
utm18's Avatar
Good gains. What intake?
utm18 is offline   Reply With Quote
Old 09-19-2015, 01:35 PM   #3
Rapinator126's Avatar
Dam good for e70.
Only thing I see is I hope that's the stock manifold. Bc if it's the boss Shaun didn't play with the cam timing at all, no reason for it to be dropping at 6800 if you have the boss. So hopefully he did with the e85 tune.
🍼and 🌽 fed coyote.
Old 09-19-2015, 06:39 PM   #4
hctr154's Avatar
I have a similar set up. Manual or automatic?
2013 GT A6
hctr154 is offline   Reply With Quote
Old 09-20-2015, 12:49 PM   #5
Jvibe92's Avatar
Manual. Stock IM. CL intake
Old 09-20-2015, 12:54 PM   #6
Jvibe92's Avatar
I just have it set for allowing me to rev it out.
Old 09-20-2015, 12:59 PM   #7
Jvibe92's Avatar
Name:	ImageUploadedByMustang Evolution1442771773.935233.jpg
I apologize. Corrected I ran 409/398. Run probably had gas in it still as I didn't drive it out to burn the rest of it. But regardless there ya go. E70 bast tune. Gain was 13/11. Gonna run it one more time next week when I do the true datalog for Shaun on e85-90. I found a good batch. Then installing 3:73s
Old 09-20-2015, 01:34 PM   #8
hctr154's Avatar
I tested several stations around here....HEB, Kroger, Valero and Sunoco. Sunoco was always at least e85 if not slightly higher.
Keep us posted.
Sent from my SM-T217S using Mustang Evolution mobile app
2013 GT A6
Old 09-20-2015, 04:28 PM   #9
Jvibe92's Avatar
Yeah. Gas was originally taken from a Valero. I'm going to do a back to back pull of e70 then e85. I get the runs for free so why not. Haha. But looks like with just an off-road h pipe, since Cai doesn't do anything really, and a tune, you can achieve 400 plus for hp and tq
Dyno results after bolt-ons - 07 GT 07GT 2005-2010 Mustang GT 16 04-09-2007 07:19 AM
SCT Tune / Dyno #2 Results 2005RedGT 1996-2004 Mustang GT 9 02-21-2005 10:36 AM
99^ split port camming and tune dyno results... (NO PORTING!!!) RGR Pre-2005 V6 Mustang 6 04-09-2004 08:07 AM
Air Silencer Dyno results ? drichard Pre-2005 V6 Mustang 4 10-15-2003 06:10 PM
12:27 PM
