2nd traction light fault - Mustang Evolution
Old 09-21-2015, 01:59 PM   #1
Sunnycalibear's Avatar
I was driving down the highway the other day and I looked down and my traction control seemed to turn itself off and I wasn't able to turn it on until I parked and turned the car off then back on. When I noticed it turned off I also saw a second traction light. Has anyone else ever seen this traction light as well? I'm curious on what the second one means. Click image for larger version
Name:	ImageUploadedByMustang Evolution1442865541.493561.jpg
Sunnycalibear is offline   Reply With Quote
Old 09-21-2015, 10:06 PM   #2
The lights on from left to right are:
1. Tire Pressure Monitoring System or TPMS
2. Traction control off
3. AdvanceTrac system off.
Ive had these three lights come on when I was using a space saver spare and also when my alignment was severely out of spec because of a shady alignment shop. It caused the car to drive straight with the wheel cocked about 20* to the right. I think the fault came from the steering position sensor showing a bad reading that caused the system to shut down.
SecretAgent is offline   Reply With Quote
Old 09-21-2015, 11:14 PM   #3
Well I mean the tpms one is from my rims and I know the middle one is advancetrac off but I've never seen the one on the far right
Old 09-22-2015, 12:20 AM   #4
Both the middle and the one on the right are tied to the traction control/abs/AdvanceTrac. The far right will normally blink when traction control or AdvanceTrac kick on. The only time it will light up solid is when there is a system fault.
You may have a bad/dirty wheel sensor or a damaged wire.
Old 09-22-2015, 12:27 AM   #5
Probably going to get some tpms sensors and hope it never happens again! Haha
Old 09-22-2015, 04:28 AM   #6
Strange Mud's Avatar
I had my 2012 fault that way 1x with lights but no apparent problem it did not clear by trying to turn off TC but went away after restarting.
I also had it kick in 1x (and possible 2x) when it was not needed. Welcome to the world of computer controlled cars and the tech advice of "did you try turning it on and off?"
Strange Mud is online now   Reply With Quote
Old 09-23-2015, 12:03 AM   #7
Hellish Horse's Avatar
I've been having a similar problem with my 08 GT. When I get in my car everyday all the dash warning lights stay off. Usually by the time I drive 50 miles (but not always) my Traction Control & my Brake warning lights come on & stay on. After the car sits all night I can start the car with no lights lit up & after 50 mi. they come on again. Not sure what's causing this but it's been going on for over a month & I can't find the problem.
Hellish Horse is offline   Reply With Quote
Disconnected battery, TPM fault? Cbird 2005-2010 Mustang GT 7 07-05-2014 10:51 PM
Tire pressure sensor fault Rileychan01 2011-2014 V6 Mustang 12 06-17-2014 03:59 PM
Tire Pressure Sensor Fault? Black8thElement Mustang Wheels & Tires 4 04-28-2014 07:31 AM
Crack cover, not my fault! Who the hell doesnt torque the bolts down on IRS brace! drusmith 1996-2004 Mustang GT 12 03-16-2011 05:33 PM
I was involved in an accident that wasn't my fault, any suggestions what to do now? Attorney? avsalom Classic Mustangs 3 08-24-2009 04:40 AM
04:41 AM
