Exhaust Leaks - Mustang Evolution
Old 09-21-2015, 06:07 PM   #1
Exhaust Leaks
Well I have been hearing a rattling from under my car for the past few weeks, also the exhaust fumes have been smelling worse than normal. I have cat deletes, so I am use to the normal odor that is given off. I looked under my car today, but couldn't find a source, but did notice three of my clamps are leaking. I tried adjusting them, but to no avail, made one worse to the point you can hear it while driving. Any tips on fixing these leaks?
Old 09-21-2015, 08:38 PM   #2
Mig welder oir if you didn't distort the pipes new clamps
ALLYDRIVER1 is offline   Reply With Quote
Old 09-21-2015, 08:50 PM   #3
Pipes are fine.
Old 09-21-2015, 09:21 PM   #4
Senior Member
Spartanator's Avatar
Dang, if mine did that I'd have a whole new exhaust system...
What do you think about wrapping the leaks and then new clamps? That's an cheap option if your budget is tight right now....
MT-82 hate.
Spartanator is offline   Reply With Quote
Old 09-21-2015, 09:45 PM   #5
I'm probably going to get some kind of wrap or I heard furnace cement works well. Haha.
Old 09-21-2015, 09:51 PM   #6
Senior Member
Found some stuff:
http://www.summitracing.com/search/p...e/exhaust-wrap
I thought it would be cheaper.... Time to break out the dryer ductwork... lol
MT-82 hate.
Old 09-22-2015, 12:05 AM   #7
Tyoung68's Avatar
They sell an exhaust sealant at any regular autopart store just have to let it sit for a day to let it harden
Old 09-22-2015, 12:08 AM   #8
Tyoung68's Avatar
Name:	ImageUploadedByMustang Evolution1442898474.394530.jpg
This stuff
Old 09-22-2015, 01:22 AM   #9
Those sealants are just band aids that mask the problem. Fix it right by buying new clamps. They can be found for cheap online. Just make sure you don't over tighten them and distort the clamps.
SecretAgent is offline   Reply With Quote
Old 09-22-2015, 09:05 PM   #10
if pipe connections are still round just replace the clamps and don't over tighten them.don't use autozone advance or orilley junk.buy good clamps from a muffler shop. I like the full circle like chysler uses,you can't distort them
Old 09-30-2015, 11:17 AM   #11
Originally Posted by white5o View Post
get it on a left and you will find out where is it leaking
I guess you didn't even attempt to read my post, like most of your other posts. I know where the leaks are.
Just an update. I have fixed them all.
Old 09-30-2015, 11:31 AM   #12
Diehard's Avatar
Share your fix approach.
Old 09-30-2015, 11:34 AM   #13
k1DBLITZ's Avatar
So what method did you end up using to fix them all?
I've noticed I have a small leak on the drivers side where my x-pipe connects and the clamps are tight as can be.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 09-30-2015, 11:40 AM   #14
Exhaust Leaks
Where the h pipe meets the OTA pipes I just bought wider clamps on Amazon. You could also double clamp them. For the spots where the h pipe meets the cat delete I used that furnace cement then clamped over the cement. I will recheck those soon; to see how the cement is holding up.
exhaust
Anti freeze leaks from exhaust joe_117 1996-2004 Mustang GT 41 11-29-2014 11:18 PM
Exhaust leaks Moyhuerta 1979-1995 Mustang GT 6 06-16-2012 02:26 PM
1971 rear window leaks. HELP! Snowmoose14 Classic Mustangs 8 04-17-2011 06:17 PM
Diebold Accidentally leaks 2008 election results Brent Pictures and Videos 2 02-25-2008 07:52 PM
2000 Convertible Top Leaks sctalbott Pre-2005 V6 Mustang 2 11-10-2003 09:58 PM
08:48 AM
