max HP for stock catback with catless X - Mustang Evolution
Old 09-26-2015, 06:47 AM   #1
OX1
At what point does it become a significant restriction?
86 Capri, turbo, 3.27's-12.66 @ 107.75
14 GT-Roush Phs 3, VMP 93 tune, Whiteline Sway Bars, Roush U/L Rear Control Arms, Street 18 X 9/10 Bullits with 295/255 NT05/555's-Track 18 X 8/10 Bullit's on 305/35R18 MT ET STR SS and 235/50ZR-18 Michelin PSS
OX1 is offline   Reply With Quote
Old 09-30-2015, 09:54 AM   #2
Rapinator126's Avatar
Something you will never have to worry about with a stock motor.
Chances are something 80% of people will never have to worry about.
🍼and 🌽 fed coyote.
Old 09-30-2015, 10:59 AM   #3
OX1
🍼and 🌽 fed coyote.
At some point beyond my warrantee (was going to keep it stock with an extended warrantee, but just bought a new fusion, so that will be my warrantee car, I just need one ), am considering an On3 Twin. Have no desire to change catback, unless I'd loss 50 HP from not changing it.
I am willing to lose some HP (or turn up the boost a bit to get it back) to keep it as close to stock quiet as possible. I'd be happy with 550 WHP through an auto if that helps.
Old 09-30-2015, 11:40 AM   #4
More than fine with 550hp.
🍼and 🌽 fed coyote.
Old 09-30-2015, 05:46 PM   #5
OX1
🍼and 🌽 fed coyote.
Thanks!!!!!!!!!!!
Old 10-01-2015, 01:03 AM   #6
kapcan2k's Avatar
With a On3 turbo setup you should be making more than 550whp easy
kapcan2k is offline   Reply With Quote
Old 10-01-2015, 04:07 AM   #7
OX1
I'd probably crank it up for some track runs, but even 500+ WHP on the street is usually pretty useless for traction.
I was just curious what the stock exh could handle, as unlike most, I think it has the perfect amount of "throat" for daily use. Stealth is GOOD!!!!!!
Old 10-01-2015, 08:35 AM   #8
Voltwings's Avatar
Turbo 4 cylinders put 550 through a single 3". Do the math, you essentially have 2, 2.5L 4 cylinders attempting to put 225 whp through a 2.75" exhaust at that point. Not even close to stressed.
Old 10-03-2015, 05:39 AM   #9
OX1
True, but I had not measured my stock exh size and even then, mufflers can be very restrictive on stock vehicles sometimes, even if the exh if properly sized.
My goal would be 10.90's (track only, would turn down the boost to whatever was needed to make it "drivable" on a sticky 295 street tire) with the only on3 twins, on3 catless X, and proper tire.
max power stock clutch holds Dubau2 2011-2014 V6 Mustang 21 04-04-2015 11:35 PM
Most stock sounding catless H pipe 33wings 1996-2004 Mustang GT 25 02-15-2015 02:23 PM
Max hp on stock motor laute01 General Mustang Discussion 5 02-01-2014 01:34 PM
Max power the stock block and internals can tak Brackemyre1 2005-2010 Mustang GT 16 02-22-2013 08:31 AM
Max boost psi for stock 2.3 head 93mstnglx 2.3 Mustang 0 11-21-2012 04:56 PM
01:15 PM
