E85 cold start issues? - Mustang Evolution
Old 09-26-2015, 08:57 PM   #1
Jvibe92's Avatar
Opinions needed
My cars on full e85. Runs well. No complaints there. But the cold starts are a real b*tch. After it idles down, I get rpm surges for awhile where it feels like the car will die. I usually kill it and restart it. After that's it's good to go. Curious if anyone here has similar issues on e85 cold starts?
Any possible things I can fix? I know I can log cold starts since o2 sensors are not providing valuable data yet.
Jvibe92 is offline   Reply With Quote
Old 09-26-2015, 09:08 PM   #2
Normal have your tuner richen up open loop idle mixture
ALLYDRIVER1 is offline   Reply With Quote
Old 09-29-2015, 02:04 AM   #3
hctr154's Avatar
Mine surges a little bit, but never gets close to dying.
2013 GT A6
hctr154 is offline   Reply With Quote
Old 09-29-2015, 05:09 PM   #4
Jvibe92's Avatar
I will post the video of what mines does! It's huge surging
Old 09-29-2015, 05:15 PM   #5
Rapinator126's Avatar
Part of running e85 in cold weather. No fix. If it gets real real cold it won't start lol.
🍼and 🌽 fed coyote.
Old 09-29-2015, 05:39 PM   #6
Jvibe92's Avatar
https://youtu.be/lwYmSE8y18M
---------- Post added at 05:39 PM ---------- Previous post was at 05:38 PM ----------
It's 80+degrees easily right now tho haha
Old 09-29-2015, 05:45 PM   #7
Who did your tune? What injectors?
🍼and 🌽 fed coyote.
Old 09-29-2015, 05:49 PM   #8
Jvibe92's Avatar
Shaun at AED and used lu47. Only at cold starts does it do that.
Old 09-29-2015, 05:51 PM   #9
It's more than likely a 02 sensor.
Stock headers?
Once winter gets here. Be prepared for something similar. And being hard to start at times.
But this is different now
🍼and 🌽 fed coyote.
Old 09-29-2015, 05:54 PM   #10
Jvibe92's Avatar
Hmm how would I determine if it's the o2 sensor?
---------- Post added at 05:54 PM ---------- Previous post was at 05:53 PM ----------
Yes stock headers
Old 09-29-2015, 05:54 PM   #11
To be a 100% for your piece of mind. Send Shaun a idle log.
But it could be something different that's why I asked if you have done anything after the e85 tune. Remove a manifold or anything?
How long have you been running 85
🍼and 🌽 fed coyote.
Old 09-29-2015, 05:56 PM   #12
Jvibe92's Avatar
Ok so warm start idle log in assuming? Warm starts are fine which confuses me
Old 09-29-2015, 05:58 PM   #13
Jvibe92's Avatar
I installed the injectors on my own that's the only thing that's changed since my last tune trough him.
---------- Post added at 05:58 PM ---------- Previous post was at 05:57 PM ----------
1 week on e85
Old 09-29-2015, 05:58 PM   #14
1 week on e85
Did it start doing it right after this?
🍼and 🌽 fed coyote.
Old 09-29-2015, 05:59 PM   #15
Jvibe92's Avatar
Yes. First cold start after e85 switch. When I did it on the dyno after the switch, it was still warm and no idle issues
Old 09-29-2015, 06:01 PM   #16
Ok we should have covered this b4 all the 02 crap. I assumed it just popped up.
Check your purge valve.
🍼and 🌽 fed coyote.
Old 09-29-2015, 06:02 PM   #17
Jvibe92's Avatar
I did fail my inspection due to o2 sensors not readying up. I did tune just a couple days before so idk if retuned affect o2 sensors in that respect
---------- Post added at 06:02 PM ---------- Previous post was at 06:01 PM ----------
Purge valve ?
Old 09-29-2015, 06:51 PM   #18
I went outside to take pic of mine but it's tucked away so can't get a good pic. Did realize I need a new battery though so eh. So here is a screen shot of one
Name:	ImageUploadedByMustang Evolution1443570732.872531.jpg
🍼and 🌽 fed coyote.
Old 09-29-2015, 07:01 PM   #19
Jvibe92's Avatar
Where roughly in the engine bay is it?
Old 09-29-2015, 07:13 PM   #20
On the Stock manifold its behind the throttle body on the manifold itself. Check everything you disconnected It's more than likely something you took apart while changing the injectors and didn't get sealed correctly again.
🍼and 🌽 fed coyote.
Old 09-29-2015, 07:15 PM   #21
Jvibe92's Avatar
But how would that make any sense sense during warm-up starts and warm idles it's fine
Old 09-29-2015, 07:30 PM   #22
Originally Posted by jvibe92 View Post
but how would that make any sense sense during warm-up starts and warm idles it's fine
sent from my iphone using mustang evolution
have you re-programed the pcm after injector install
Old 09-29-2015, 07:31 PM   #23
I'm giving you things to check. It started after your injector install which leads to something not being installed correctly.
Or your 02's or possibly the tune itself. Which is doubtful as most of Shaun's base tunes are better than a lot of people's data loged ones.
🍼and 🌽 fed coyote.
Old 09-29-2015, 07:32 PM   #24
Good lord I hope so. As Shaun's tune for e85 would have been for the 47's at a minimum.
🍼and 🌽 fed coyote.
Old 09-29-2015, 07:36 PM   #25
Jvibe92's Avatar
Yeah I'm sure he pcm isn't the cause. I'll check those things first. I need to drive it tomorrow so after tomorrow I'll recheck everything I've taken off before. If not that then I'll email Shaun one more time with a couple logs and hope it's not the o2. How much do o2 sensor run for?
Old 09-29-2015, 07:37 PM   #26
$100-150
🍼and 🌽 fed coyote.
Old 09-29-2015, 07:41 PM   #27
Jvibe92's Avatar
😔 ugh. Well I'll make a warm log right now just to have it ready. I'll check the purge valve in the morning when there's more light.
Old 09-29-2015, 08:27 PM   #28
ok so warm start idle log in assuming? Warm starts are fine which confuses me
no,when you have the problem
Old 09-29-2015, 08:30 PM   #29
Originally Posted by Rapinator126 View Post
$100-150
🍼and 🌽 fed coyote.
AROUND $40/50 HERE
Old 09-29-2015, 08:57 PM   #30
AROUND $40/50 HERE
That's a good price. But I don't use factory ones for the 🌽 and do not suggest he does either.
🍼and 🌽 fed coyote.
Old 09-30-2015, 12:23 AM   #31
Jvibe92's Avatar
But at cold start the o2 sensors aren't producing any valuable data? So data logging cold starts wouldn't be beneficial in this case for remote tuning?
Old 09-30-2015, 01:26 PM   #32
hctr154's Avatar
🍼and 🌽 fed coyote.
Why is that Rap?
2013 GT A6
Old 09-30-2015, 01:27 PM   #33
Originally Posted by hctr154 View Post
Why is that Rap?
The factory ones go bad faster with e85.
🍼and 🌽 fed coyote.
Old 09-30-2015, 01:51 PM   #34
Jvibe92's Avatar
Which are the "good" ones? I mean how will it stop from moisture ruining it?
Old 09-30-2015, 02:08 PM   #35
It won't stop that. They just last longer. And the NTK ones from AM
🍼and 🌽 fed coyote.
2010 GT - issues, issues, issues. Anyone experience this? Binks 2005-2010 Mustang GT 2 05-09-2015 11:22 AM
Running lean on Cold start in cold temperatures. Zed 2011-2014 Mustang GT 3 09-24-2014 08:23 AM
Random cold start issues. Harris2107 2011-2014 Mustang GT 8 04-09-2014 04:05 PM
95 gt cold start, stalling at idle issues.. need help BloodRedStang 1979-1995 Mustang GT 3 09-02-2013 10:31 AM
94gt factory cold air intake vs aftermkt cold air intake justjake94boss 1979-1995 Mustang GT 1 04-15-2012 12:22 PM
06:16 AM
