Motor mounts - Mustang Evolution
Old 09-29-2015, 07:44 PM   #1
Redonblackpony's Avatar
Motor mounts
Has anyone with a 2011-2014 Mustang GT had to replace the motor mounts? If so what did you replace them with and how tough a job is it?
Redonblackpony is offline   Reply With Quote
Old 09-29-2015, 07:54 PM   #2
oxford5pointoh's Avatar
I've seen them removed and replaced in long tube header install videos and it doesn't look hard at all. One at a time support the motor on the corners of the oil pan with a floor jack and a piece of wood.
As far as what to replace it with. I'd look at Steeda motor mounts.
Old 09-29-2015, 08:18 PM   #3
scott_0's Avatar
haven't installed aftermarket motor mounts, but I have installed long tubes, and it involves removing and reinstalling them, not too hard a job, but w/e you do, DO NOT jack/support the motor by the oil pan! use a block of wood on the transmission bell housing just behind the oil pan
sent from my S6 using tapatalk
Old 09-29-2015, 08:29 PM   #4
I've seen a few videos and they jack it just slightly on a corner of the oil pan with a block of wood obviously.
Of course you want to avoid bending or breaking anything. I wouldn't have mentioned it unless I had seen it done that way. I thought it was a bit of a risky maneuver myself but once you see them do it it seem safe.
Watch some YouTube videos OP
Old 09-29-2015, 09:06 PM   #5
It looks pretty straightforward, I should be able to do it in my garage.
After all, I've done all the other mods on my car without any major mishaps
Old 09-29-2015, 09:11 PM   #6
69mach1390's Avatar
Jack it on the trans bellhousing not the oil pan I've installed lots of longtubes on these cars don't jack it on oil pan
69mach1390 is offline   Reply With Quote
Old 09-29-2015, 09:14 PM   #7
Agreed. The oil pan seems like a bad place to lift from
Old 09-29-2015, 09:33 PM   #8
69mach1390's Avatar
Also UPR adjustable motor mounts are good ones
Old 09-29-2015, 09:45 PM   #9
Thanks for all the input.
I'll do my research and make a decision.
Motor mounts Berbantor 1996-2004 Mustang GT 7 10-30-2011 08:32 AM
Help with motor mounts mlaytonsr1 1996-2004 Mustang GT 4 07-13-2009 04:44 PM
03:52 AM
