Another BMR UCA & LCA clunk/knock thread - Mustang Evolution
Old 10-03-2015, 07:43 AM   #1
Hey guys!
I know its been asked many times but i couldn't find the correct answer for my issue.
I recently installed along with my VMP TVS kit the BMR LCA and adjustable UCA with BMR Mount.
I am not sure what angle the guy who installed it for me set it to,
but since then, i have an annoying clunk (i think from the UCA) whenever i am the gear shifts in in the lower gears (1,2 & 3).
My car has an auto transmission and if it matters i installed back then Eibach PRO-KIT
I made sure everything is tighten as expected and put grease in all the bolts.
How can I solve this this? is it possible that the angle is incorrect?
Please assist
Thanks!
demas is offline   Reply With Quote
Old 10-05-2015, 01:14 PM   #2
Ammermeow's Avatar
Probably just drive train clunk. This gets really loud when you replace the stock pieces with their soft rubber bushings. When does it make the noise? When you let off and on the gas or over bumps?
Sent from my SM-N910V using Mustang Evolution mobile app
2012 GT Brembo M6, BBK CAI, Dynomax axleback, Bama tuned, UPR UCA & mount, Hotchkis LCA/panhard bar/adjustable swaybars, Whiteline relocation brackets, Barton shifter & bracket, Eibach ProKit Springs.
Ammermeow is offline   Reply With Quote
Old 10-05-2015, 04:20 PM   #3
RJTheIV's Avatar
That's odd. I have the exact same suspension setup and all I get are light squeaks over bumps(barely audible)
RJTheIV is offline   Reply With Quote
Old 10-05-2015, 08:20 PM   #4
Pinion angle may have been set wrong.
Old 10-05-2015, 10:15 PM   #5
Just heard mine today. Is yours at parking lot speed while turning? That's when I hear mine the most.
blackbella5.oh is offline   Reply With Quote
Old 10-06-2015, 03:32 PM   #6
Famine's Avatar
Region: South Dakota
It could just be the drivetrain. You should check the uca. Make sure you have the correct pinion angle and ensure that you have it loctited. If you don't, it may have come lose and that will give you the clunk.
Famine is offline   Reply With Quote
Old 10-08-2015, 09:28 AM   #7
I hear it mostly when the gear (Auto) is shifting to a lower or to an upper one.
I tried to set the pinion angle and have 1,2 negative angle but so far it only got worse... :S
Old 10-08-2015, 08:48 PM   #8
thelastsumurai's Avatar
Do you have a drive shaft loop installed.
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 10-09-2015, 08:41 AM   #9
Nope, suspension wise i only replaced:
UCA w/ mount
LCA
Springs
Sad Sad Sad Day for me and my family M3to5.0 The Bar 27 03-07-2016 07:49 PM
BMR LCA/UCA - poly or spherical/rod end hispeedlodrag 2011-2014 Mustang GT 3 02-27-2015 12:57 PM
Installed BMR adjustable UCA, LCA, loud noise/clunk on sharp turns Riko 2011-2014 Mustang GT 24 12-14-2014 02:46 PM
Lca & uca & relocation bracket Laquisha 2011-2014 Mustang GT 43 11-15-2014 12:02 AM
Sad Sad SAD day Seph The Bar 9 04-06-2004 10:24 AM
04:41 AM
