P2195 code on 2014 Mustang GT - Mustang Evolution
Old 10-04-2015, 12:53 PM   #1
Eleazer2's Avatar
This is the 2nd time I have gotten this code bank 1 sensor 1 stuck lean I replaced the oxygen sensor about 6,000 miles ago and the issue went away it's now back again same code when looking at datalog I notice the lamda stays .98 or lower for bank 1. I have Jba longtubes headers off road h pipe and jlt air intake along with jlt oil seperator I have the car tuned by Bama performance i had a few issues when they first sent me the tune back when my first o2 sensor failed but since then I no got the tune corrected feels like it makes good power but 3 days ago the p2195 error came back i bought another 02 sensor and cleared the codes and the lamda voltage is back in sync with bank 2 sensor 1. What could the issue bad tune? Anyone else having this issue?
Eleazer2 is offline   Reply With Quote
Old 10-04-2015, 02:04 PM   #2
BAD PART?
ALLYDRIVER1 is offline   Reply With Quote
Old 10-04-2015, 02:29 PM   #3
natestang07's Avatar
I would get a revised tune. Are you using o2 extensions?
Old 10-04-2015, 02:33 PM   #4
scott_0's Avatar
this
sent from my S6 using tapatalk
Old 10-04-2015, 02:35 PM   #5
Eleazer2's Avatar
No extensions and I have data logged with Bama several times they are requesting more logs of cruising. I understand a seams or failing but the factory sensor went out around 8,000 and I bought another oem sensor and it lasted 3,000 miles I'm now on a 3rd sensor. Im running jba titanium headers I notice they get cool quickly and I'm wondering if this is causing the issue. If I cut the car off and let it set for 5 minutes I can start it back up and the temp is less than a quarter of the way to normal
If I start driving it will start running poorly around 3,000 to 4,000 rpm when taking off once it's up to normal temp it will run great. I just can figure out what is causing the sensors to fail.
Old 10-04-2015, 03:08 PM   #6
Eleazer2's Avatar
No in not using extension I am using the factory harness pulled straight into the o2 sensors
Old 10-04-2015, 03:52 PM   #7
Grabber Blue5.0's Avatar
Are the sensors in the 3:00 and 9:00 position? If so you'll keep blowing sensors until that's corrected. It's a common problem.
Old 10-04-2015, 04:17 PM   #8
Always point out stuff I had absolutely no knowledge on.
Old 10-04-2015, 04:35 PM   #9
Eleazer2's Avatar
I think the JBA comes in about the 9 o'clock position but how come its just Bank 1 giving me issues bank 2 is in the exact same location but facing at 3:30 or 4 o'clock position. Anyone else running JBA longtubes that have the exact same issue?
Old 10-04-2015, 04:45 PM   #10
I am on a 3v without issue
Old 10-04-2015, 05:07 PM   #11
Eleazer2's Avatar
Did you relocate your O2 bungs I believe they have a location I can use in one of the primaries however I know it's only monitoring the one cylinder
Old 10-04-2015, 06:05 PM   #12
If I remember right both of my o2s are in the primaries.
Old 10-04-2015, 06:18 PM   #13
Eleazer2's Avatar
Will you check and let me know I would appreciate it for some reason when I did the install I believe I was told to use he collector if you do have them in the primaries how long have you had them without any error codes ?
Old 10-04-2015, 06:21 PM   #14
scott_0's Avatar
they absolutely NEED to be in the collector
Old 10-04-2015, 06:32 PM   #15
Looks like it is about as far up on the collector as possible
Old 10-04-2015, 07:42 PM   #16
Eleazer2's Avatar
If they need to be in the collector then what's the solution I don't think I can relocate the 02 higher on the collector since the o2 sensor will hit the body
2014 mustang
Car idling rough p2195 and p2197 hdez41 2011-2014 Mustang GT 63 08-30-2015 01:21 PM
P2195 and P2197 VIG 2011-2014 V6 Mustang 5 02-23-2015 11:01 PM
p2195 p2197 mustanguitarist 2011-2014 V6 Mustang 6 04-24-2014 12:34 PM
FORD MUSTANG BRAINIACS what does r-code and/or c-code mean? kele74 Classic Mustangs 4 03-16-2010 06:12 PM
Check engine light-codes P2197,P2195 The Darkside Pre-2005 V6 Mustang 35 12-11-2008 11:12 AM
07:13 AM
