RTR REAR LICENSE PLATE SURROUND - Installation Tips - Mustang Evolution
Old 10-07-2015, 11:11 AM   #1
k1DBLITZ's Avatar
Just installed one of these the other night... thought I'd offer a few tips for everyone else.
1.) Make sure you have a hook tool. You will definitely need one to to get the stock surround removed. You can pick up a hook kit at Lowes or Home Depot for a just a few bucks.
2.) Remember that hook kit I mentioned in step 1? Well, you have to pull... HARD to get the stock surround removed. I ended up breaking 2-3 of the stock clips when removing. This is not a problem unless you intend to go back to stock for some reason.
3.) Make sure you have enough daylight! I was anxious to get this bad boy installed and ran out of daylight. I had to use one of those hook lights, which made it incredibly hard to see the sharpie lines I drew to cut out the bumper.
4.) A hacksaw isn't going to hack it! There are multiple problems I ran into when using a hacksaw, such as: It takes too long. The blade kept bending. After 1 or 2 back and forth motions the teeth would become clogged with plastic and stop cutting. I continually had to remove plastic from the blade.
5.) I borrowed a dremel from a friend. This is way to go! However, 2 BIG WARNINGS! Be VERY CAREFUL NOT TO CUT YOUR WIRING. It is directly behind the area you will be cutting out. The second warning is, WEAR EAR PROTECTION. That dremel on plastic was insanely loud. Fairly positive the neighbors weren't happy with me, and my ears were hurting by the time I was done.
6.) Have some black rustoleum on hand to spray the inside of the bumper area before you install the surround because that section of the car isn't painted.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 10-07-2015, 11:50 AM   #2
oxford5pointoh's Avatar
Wouldn't it be a million times easier to just take the bumper off? I've had mine off to do the diffuser and it takes all of 5 minutes. That would make the removal of the stock part a non issue, the wire cutting a non issue.
Old 10-07-2015, 12:30 PM   #3
Sterlingbeast5.0's Avatar
Might have been easier that way. I did the same thing and was seriously worried I was going to pull the whole bumper off as hard as it was to get off. lol. Looks good though.
Side note/question: Maybe it is a florida thing... I seem to get sand and dirt in those surround holes 2 minutes into first drive after clean?? Am I alone?
Old 10-08-2015, 07:42 PM   #4
k1DBLITZ's Avatar
A little too early to tell, but seems to be staying clean.
2013-2014 License Plate Panel/Surround...Custom Conversion? Coyote2820 2011-2014 Mustang GT 9 03-14-2017 10:18 PM
Truefiber blackout panel and License Surround installed K2Steeda 2011-2014 Mustang GT 9 08-11-2014 06:02 PM
Wanted: '13-'14 Stock Rear License Plate Surround Jackal43x Mustang Parts for Sale and Wanted 2 08-06-2013 08:07 PM
RTR License Plate Surround Jackal43x Mustang Paint, Appearance & Detailing 0 07-15-2013 04:01 PM
License plate Falcon The Bar 3 11-09-2003 11:34 AM
11:07 AM
