Whaling noise from front end - Mustang Evolution
Old 10-07-2015, 05:32 PM   #1
Jvibe92's Avatar
What noises do bushings, ball bearings, etc make when they are old/bad that can be replicated at a specific speed;50-65 in my case. It's a whining, "wah wah wah wah wah wah" noise that's deep in tone.
Jvibe92 is offline   Reply With Quote
Old 10-07-2015, 05:45 PM   #2
Billgluckman's Avatar
Most likely a tire.
Billgluckman is offline   Reply With Quote
Old 10-07-2015, 05:58 PM   #3
Jvibe92's Avatar
No. I was thinking Wheel bearing? Definitely not the tire noise
Old 10-07-2015, 07:08 PM   #4
Check for play in the bearing...bad bushings won't do that. I had to replace what looked like perfectly good tires because of the same sound. Are you still on pirellis? Mine got very noisy at around 23k miles.
Old 10-07-2015, 08:16 PM   #5
94gtconvert's Avatar
Mine does the same thing, that being said my week bearings are fine, and my brakes aren't warped. Their actually brand new. I'm certain I have a bad tire. Their both wearing weird.
94gtconvert is offline   Reply With Quote
Old 10-07-2015, 10:44 PM   #6
Jvibe92's Avatar
I got nitto nt555 and they are under 7k miles on them
Old 10-08-2015, 05:06 AM   #7
Eleazer2's Avatar
You sure it's not coming from the rear axle assembly is it all the time or when you under a light load mine stops when I let off the gas I also installed a mgw shifter that has more trans noise but if I recall mine did this when before the shifter install I have a 2014 mustang Gt with the track pack 3.73 gears I have 11k miles on the car it's been this way since I bought the car brand new. The whine sounds Almost sounds like a go kart when you let off the gas at the kart track.
Eleazer2 is offline   Reply With Quote
Old 10-08-2015, 11:33 AM   #8
thelastsumurai's Avatar
Interesting. Usually a whine (if that's the sound) is a bearing. But on a relatively new car? IDK.... Jack it up and check out the play and spin it and listen carefully. Are you sure it's from the front?
Power steering pump(which we don't have), alternator, water pump, and the dreaded timing chain guides, all make sounds which sometimes include a whine. r u under warranty ?
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 10-09-2015, 04:53 PM   #9
Jvibe92's Avatar
https://youtu.be/RkJonzOt00o
https://youtu.be/AK_oMeSDrdE
Here's the videos.
Old 10-09-2015, 05:15 PM   #10
Eleazer2's Avatar
sounds like the metal brake dust over hitting the back of the rotor or the brake pad is dragging the rotor check the back of the rotor where the dust shield is
Old 10-09-2015, 07:27 PM   #11
Yeah it definitely sounds like something is dragging against the rotor. Pull the wheel, spin the rotor, probably the shield as the guy above said.
Or could be a bad bearing. Is there any side to side play?
Old 10-09-2015, 08:48 PM   #12
Jvibe92's Avatar
No side play from what I can tell. I'll pull the wheel and spin the rotor and see what happens. Both sides do it. The drivers side does it way worse than the passenger side. You think this could cause the noise I hear?
Old 10-09-2015, 10:03 PM   #13
I couldn't hear the noise in your driving video so I honestly don't know.
Old 10-10-2015, 12:56 AM   #14
Jvibe92's Avatar
The noise is the wah wah wah wah wah. I have the car in neutral and am coasting. I mean I can hear it. Phone doesn't pick it up too well I guess
Old 10-10-2015, 12:59 PM   #15
kpmurphy16's Avatar
I have that exact same noise. Going to ford Monday to sort it out. I have all new Pirelli tires and I am betting it is a bearing, but won't know until ford looks at it early Monday.
Look at my other two posts describing this. It starts at 50mph and runs until 80. Don't hear it under 50mph.
kpm
kpmurphy16 is offline   Reply With Quote
Old 10-10-2015, 02:10 PM   #16
Jvibe92's Avatar
Well I'm at a place getting it fixed now. I'll let you know if it's fixed
Old 10-10-2015, 02:13 PM   #17
kpmurphy16's Avatar
Please do. I go Monday morning and will let you know as well. Hope it fixes. I hate it when the 'stang has a lame leg and can't run like it's designed.
kpm
Old 10-10-2015, 02:59 PM   #18
Jvibe92's Avatar
Well it's not the rotor, brake pad, caliper, or dust shield that's causing the noise. Not sure what it could be. It doesn't do the scraping them however
Old 10-11-2015, 06:04 AM   #19
Eleazer2's Avatar
The roaring sounds like a bad tire in the video but the dust shield sound like it is rubbing I would just take the tire off and pull the shield away from the rotor and spin the wheel. It sounds just like a brake dust shield
Old 10-11-2015, 06:07 AM   #20
Eleazer2's Avatar
If it's a bearing try to turn and see if the noise goes away usually it will get worse turning one way and if you turn it the other way it should stop or the sound will get lower. But in you jack up that side of car and wiggle the tire see if there is any play in the bearing
Old 10-12-2015, 12:07 AM   #21
Jvibe92's Avatar
Wheel is fine. Hub bearing is fine. How can you diagnose a bad front LCA? Since I know it creaks a crap ton over bumps. Maybe a bad bushing? The front tires have a good chunk of tread left. Doubt it's that. Just annoyed af and its 90 still so I can't drive with the windows down 😔
Old 10-12-2015, 06:19 AM   #22
Eleazer2's Avatar
Try to push down on the front fender maybe it's a strut. Have you put lowering spring on the car? Those struts are bad about coming apart I had to replace mine with steeda struts after putting springs on mine
Old 10-12-2015, 01:21 PM   #23
Jvibe92's Avatar
I got Koni yellows on gt500 strut mounts with bmr sp009
14 front end to 12 front end Cise 2011-2014 V6 Mustang 24 05-17-2015 02:14 PM
For Trade: My 2014 V6 Front End for your 2011-2012 GT Front End CodyC Mustang Parts for Sale and Wanted 3 03-15-2015 08:42 PM
86 front end into an 89 front end Beatjunkiexorge 2.3 Mustang 1 05-18-2013 07:07 PM
Front end Noise ?????? ArmyStangGT 1996-2004 Mustang GT 7 02-09-2009 08:13 AM
05 GT front end knocking noise texastosh 2005-2010 Mustang GT 2 09-01-2007 01:57 PM
03:42 AM
