Sporadic P0303 Code - Mustang Evolution
Old 10-12-2015, 01:05 PM   #1
Region: Nebraska
Sporadic P0303 Code
I have been battling an intermittent P0303 code for some months now. The times that it has been showing up has always been during idle, never during driving.
My car has 53,000 miles on it. Like I stated, this intermittent code has been coming on for several months now. I have swapped all of the coil packs around several times amongst each other, to see if the problem would stay at cylinder three, or move. Nope, still misfire on cylinder three.
About a month and a half ago, I put in eight brand new OEM spark plugs. I also put an o-ring on my crankshaft position sensor and did the neutral crank relearn myself. The misfire code went away for several weeks, but it has since returned. Cylinder three again, only.
I have used a long screwdriver as a stethoscope so that I could hear the fuel injector clicking, and the fuel injector on cylinder three clicks with the same sound and clicks at the same frequency as all of the other fuel injectors.
I am lost now. Should I replace all of my fuel injectors? Can Ford do some kind of electronic diagnosis and tell me what is wrong?
helloWorld is offline   Reply With Quote
Old 10-12-2015, 01:23 PM   #2
Grabber Blue5.0's Avatar
Stock? Mods?
Old 10-12-2015, 02:13 PM   #3
Region: Nebraska
My car:
2013 Mustang GT
Automatic
AED datalog tune
JLT plastic cold air intake
Lethal stainless offroad h pipe
Lethal over axle pipes
GT500 single-tip mufflers
UPR firewall catch can
The new spark plugs are the OEM motorcraft plugs. I believe they were all gapped at .050 +/- a small amount
My handheld I am using is a SCT X4.
Old 10-12-2015, 03:33 PM   #4
Have you run this by Shaun? Or sent him logs so he would be able to see what's going on?
Old 10-12-2015, 09:28 PM   #5
Region: Nebraska
The logs I sent him about a month ago for my offroad h-pipe install did not seem to alarm him.
Sporadic starting issues.. OfficialMakkyZ Pre-2005 V6 Mustang 7 05-03-2014 06:33 PM
P0303 2011 GT after clutch replacement ryanast 2011-2014 Mustang GT 10 03-19-2012 04:39 PM
Sporadic fuel pressure gauge RedRoush 1996-2004 Mustang GT 3 05-01-2011 10:54 AM
FORD MUSTANG BRAINIACS what does r-code and/or c-code mean? kele74 Classic Mustangs 4 03-16-2010 05:12 PM
ECU code FA23...sound right? MUSTANGJUNKY420 Pre-2005 V6 Mustang 6 08-11-2003 04:35 PM
04:14 AM
