LCA relocation bracket adjustment - Mustang Evolution
Old 10-12-2015, 07:06 PM   #1
Fax22's Avatar
I bought the bmr LCA relocation brackets for my car after I lowered it. I have eibach sportlines which is a pretty aggressive drop and was wondering which holes I needed to mount the control arms in the bracket to get the best performance. I was thinking the middle holes but for all I know I could need the lowest holes to get the angle right.
Is there a certain angle the arms should be at that I could measure?
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Fax22 is offline   Reply With Quote
Old 10-12-2015, 07:50 PM   #2
Robostang's Avatar
With the car sitting on the ground the LCAs should be parallel to the ground. You might want to adjust them to that the rear of the LCA is slightly lower than the front. This will help push the axle down under hard acceleration.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 10-12-2015, 08:35 PM   #3
Fax22's Avatar
Ya i wasnt entirely sure what the stock ride height angle was and if doing a more aggressive angle towards the rear would be an improvement.
Old 10-15-2015, 10:49 AM   #4
k1DBLITZ's Avatar
There is a great article on LCA adjustment here: cherod.com/mustang - LCAs
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 10-15-2015, 11:23 AM   #5
Fax22's Avatar
So if i wanted the most aggressive force on the axle I need to put it probably on the lowest adjustment like I thought. Is there any side affects to an aggressive setup like that?
Old 10-15-2015, 12:12 PM   #6
Voltwings's Avatar
You could overload your tire's ability to grip and actually make traction worse. Its a balance.
Old 10-15-2015, 12:50 PM   #7
Diehard's Avatar
And like that referenced article points out, "Note that running the LCA at an angle (any angle, good or bad) will result in slightly more ride harshness on rough roads."
Old 10-15-2015, 01:14 PM   #8
Diehard's Avatar
Volt...I tried googling this subject but had no luck finding anything on what you are pointing out.
Could you try explain a bit on exactly what this means and/or what is taking place? In layman's terms.
Or even better, a link to an article.
Thanks
Old 10-15-2015, 01:22 PM   #9
Voltwings's Avatar
Thanks
I called Kelly from BMR a while back, i'll try to repeat what he said, hopefully without butchering it too much.
We've established the point of the LCA is to load the rear axle via weight transfer. When parallel, it takes a good amount of weight transfer (think WOT) to fully load the axle. The LCA is basically a fulcrum though, and the more extreme you make the downward angle, the less overall weight transfer it actually takes to load the axle. If you have some so-so tires and are very quickly and heavily loading the axle, you can expect traction problems.
Old 10-15-2015, 02:35 PM   #10
Fax22's Avatar
That actually makes sense. Kind of lol. I definitely want it more aggressive than parallel and my car is on sportlines so the body is pretty low. I don't think I will have to worry about it being TOO aggressive. I imagine this being more of an issue on stock ride height cars.
Old 10-15-2015, 05:29 PM   #11
Voltwings's Avatar
I'm pretty sure anything beyond parallel is for a pretty dedicated drag set up. I'd start with parallel for a street car just to see.
Old 10-15-2015, 05:59 PM   #12
olerodder's Avatar
Region: Oregon
Where your suspension is now, measure from the center of the front bolt attaching the LCA to the ground...measure the rear LCA bolt center to the ground...then subtract one from the other...it will either be a positive number or negative number...as everyone has already said parallel for the street...all the way down for drag racing and in the middle for autocross etc. Also have you measured the pinion angle? As you start changing the angle of the LCA's you will also change the angle of the pinion...
Old 10-15-2015, 06:01 PM   #13
Fax22's Avatar
Ya i do plan on getting an UCA soon.
Old 10-15-2015, 07:30 PM   #14
olerodder's Avatar
Region: Oregon
Since you lowered your car with the same springs I put in mine your pinion angle has changed and you need to know what that angle is at every step of transforming your rear suspension...when I dropped it with the Sportlines the pinion angle changed from 0 to a -1.5 degrees and when I installed my adjustable LCA's and UCA I was able to pre-loaded chassis by adjusting the UCA/LCA's and get the pinion angle back up to -.5 degrees. I didn't bring it back to 0 degrees as I am running a poly bushing in the UCA and in the carrier bushing and don't have as much give as the rubber carrier bushing...mine was tearing and cracking with less than 8000 miles...just glad I changed it when I did.
Old 10-15-2015, 07:50 PM   #15
Diehard's Avatar
It appears to me that changing the angle of non-adjustable LCA's does not change the pinion angle. The relocation brackets adjustment holes should be located radially from the pivot point on the body. That means each adjustment hole should be at the exact same distance from the bodies pivot point, which would not rotate the rear end (or change pinion angle).
Old 10-15-2015, 07:59 PM   #16
Diehard's Avatar
I see the majority of people tend to adjust pinion angle with the UCA and use non-adjustable LCA's.
I often wondered when and why I sometimes see references to using the LCA's to adjust pinion angle and in your case using both Upper and lower. Is that for more adjustment? Don't they both do the same thing? (Rotate the rear end to adjust pinion angle?)
Old 10-15-2015, 08:04 PM   #17
olerodder's Avatar
Region: Oregon
If you only adjust the UCA you are now putting the non-adjustable LCA's in a bind situation by pulling the top of the axle down or up...if you want the rear suspension to work it needs to be able to move, pivot and all work together...if you put one thing in a bind nothing works freely....
Old 10-15-2015, 08:13 PM   #18
Diehard's Avatar
Thank you. I'll have to think about that as I go to sleep tonight.
Old 10-18-2015, 06:42 PM   #19
Fax22's Avatar
Just for future reference, I need up putting the LCA's on the lowest hole (most aggressive) and the angle is perfect with the sportline springs. Its only slightly more aggressive than parallel.
Lca & uca & relocation bracket Laquisha 2011-2014 Mustang GT 43 11-15-2014 12:02 AM
LCA relocation bracket for SR? 2014oxstang 2011-2014 Mustang GT 35 06-11-2014 11:23 AM
LCA relocation bracket? Are they really worth it? Jsmorley81 2011-2014 Mustang GT 8 09-18-2013 11:20 AM
spohn lca relocation bracket 610swolf 2005-2010 Mustang GT 2 06-18-2013 05:55 AM
LCA Relocation Brackets M3to5.0 2011-2014 Mustang GT 14 11-15-2011 03:01 PM
03:35 AM
