2013 gt grinding 5th gear ;[ - Mustang Evolution
Old 10-13-2015, 03:05 PM   #1
Thumbs down 2013 gt grinding 5th gear ;[
hello all. today i was driving shifting at 3krpm 1-2-3-4 smooth like butter. but then when i went to 5th. clank ! gear was grind. i don't know why? the clutch was depressed fully. any reason? any help please and thanks
tlebron20 is offline   Reply With Quote
Old 10-13-2015, 03:23 PM   #2
great tips guys !
Old 10-13-2015, 03:43 PM   #3
Devil Strider's Avatar
How about you be patient and wait for someone to answer you.
Sent from my SM-N910P using Mustang Evolution mobile app
Devil Strider is offline   Reply With Quote
Old 10-13-2015, 03:45 PM   #4
ok
Old 10-13-2015, 04:36 PM   #5
Robostang's Avatar
5th gear synchro may be bad.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 10-13-2015, 04:50 PM   #6
so how can i fix it?
Old 10-13-2015, 04:51 PM   #7
Jbone007's Avatar
Dose it happen all the time now or just that once?
Jbone007 is offline   Reply With Quote
Old 10-13-2015, 04:54 PM   #8
no not all the time. maybe once a month or twice
Old 10-13-2015, 04:58 PM   #9
Jbone007's Avatar
Still under Warranty? I would have it checked if you are sure that it is not driver error, I have ground 5th a time or two, by letting the clutch out a bit too soon!
Old 10-13-2015, 05:00 PM   #10
i believe its still under warranty. ill give them a call tmm. could it possibly be that didn't have enough speed for 5th?
Old 10-13-2015, 06:12 PM   #11
It's more then likely a synchro going bad. If still under warranty just make an appointment at your local dealer and get it fixed.
2012 GT Ignot Silver
Evolution5.0 is offline   Reply With Quote
Old 10-13-2015, 07:40 PM   #12
Voltwings's Avatar
There's a TSB on 5th gear. I was literally just driving on the highway and my 5th gear completely went out, 100% would not go into 5th at all. Took it in and they fixed it, no questions asked.
Old 10-13-2015, 08:39 PM   #13
Robostang's Avatar
Warranty should cover it. Just need to have the tech experience it when it happens. Intermittent problems can be a pain since you can't count on the problem occurring when the tech drives it.
Old 10-13-2015, 10:03 PM   #14
Originally Posted by tlebron20 View Post
great tips guys !
you most likely missed a shift. I answered on the other post
ALLYDRIVER1 is offline   Reply With Quote
Old 10-14-2015, 10:56 AM   #15
Koryak's Avatar
Voltwings post above about a TSB for 5th is really interesting and should be checked out. This M82 gearbox is direct drive in 5th with the input connected to output. The synchro design may be different. Also, 5th has less rev drop from 4th than 6th from 5th! - must be a Ford & EPA mileage thing.
Koryak is offline   Reply With Quote
Old 10-14-2015, 11:37 AM   #16
I also have a grind in 5th. At first I thought it was me, letting out the clutch a liitle too soon. I started being a little more cognizant of my shifting habits, even went as far as installing a clutch extension pedal to make sure I was putting and keeping the pedal all the way down. It still grinds, and I noticed it happens at cold starts...when I'm hitting 60+mph on 4th to merge into traffic...first thing in the morning, and after work. If I shift normally at those speeds it'll grind, but once it warms up it won't. I started pausing at least 2 seconds before I shift into 5th now. Lately though, it happened twice even though I paused. I had taken my car to a dealership almost 3 months ago, and they couldn't replicate the problem. I even went one morning while they had my car there, took the service manager along for a test drive, but I couldn't get it to grind. I set an appointment at another dealership for next week. I'm hoping since the weather is getting cooler they can recreate the problem. Luckily it is still under warranty. Only mods have been a shifter and suspension components.
Mossman45 is offline   Reply With Quote
Old 10-14-2015, 12:16 PM   #17
Robostang's Avatar
Just be prepared for the dealer blaming the aftermarket shifter. If I were you I would put the stock shifter back in before I took it to the dealer.
Old 10-14-2015, 12:26 PM   #18
Thanks for the info Robostang. I already spoke to the service manager where I'm taking it to, and explained what I had done. He said the installed shifter would not void the warranty. But I totally understand what you mean. One dealership I had spoken to had told me I had voided the warranty by not having them install it.
Old 10-14-2015, 12:56 PM   #19
I have the same problem going into 3rd gear, changed out of tranny oil and put it in a glass jar when I put it out in the Sun ic metallic particles in the oil so I know 3 gear synchro is gone
Sent from my SM-N920T using Mustang Evolution mobile app
---------- Post added at 01:56 PM ---------- Previous post was at 01:55 PM ----------
Ben Calimer built my stage 2 transmission so I sent it back to him for repair
---------- Post added at 01:56 PM ---------- Previous post was at 01:56 PM ----------
Sad thing is it only had 200 miles on it
He says these trannies very finicky
chefron50 is offline   Reply With Quote
Old 10-14-2015, 04:08 PM   #20
Since the MT 82 was introduced in 2011 replacing the Tremec there have been numerous problems with this Tranny. Part of the problem it is made in China so the quality is in question. Hope it is still under warranty.
gowa69 is offline   Reply With Quote
Old 10-14-2015, 07:40 PM   #21
The stock mt82 that came on my 2013 boss works perfectly no issues whatsoever, I had Ben build me one to handle more power
Old 10-14-2015, 07:44 PM   #22
not sure what 'tsb'' is. if my tranny was bad wouldn't it grind all the time and not just once? a month
Old 11-02-2015, 10:53 AM   #23
Not to take over your thread, but a quick update:
I got my car back a couple of days ago. The dealership was able to replicate the issue after a few tries, so they repaired the tranny by replacing the 5th gear synchro. It now shifts tighter and smoother than before, and the grind is gone. Also the notchiness I experienced in 2nd and 3rd is now gone, though I did have them install a steel braided clutch cable.
Old 11-02-2015, 11:23 AM   #24
I went through Ben Calimer, he is a MT 82 guru
5th gear, gear noise? SitinprettyGT 1996-2004 Mustang GT 6 01-10-2013 06:37 PM
Help! 1st gear issue / 5th gear grinding Missxalii General Mustang Discussion 2 06-06-2012 01:18 PM
5th gear grinding eddie1 1996-2004 Mustang GT 0 11-01-2008 12:54 PM
5th gear problem Murph00 Pre-2005 V6 Mustang 4 11-11-2004 08:39 PM
5th Gear Issue cagedthought Pre-2005 V6 Mustang 5 11-01-2004 12:09 PM
07:16 AM
