After installing Long Tubes - Mustang Evolution
Old 10-14-2015, 10:01 AM   #1
runthatsleeper's Avatar
Hey guy just have a question for anyone how has installed long tubes. after you installed them did the car (this is where it gets hard to explain) like vibrate or feel like its a rumble rougher rider or crapper ride its hard to explain but its more noticeable between 70-80. is it because the collectors for the x pipe are bigger then the old one and are right under the seat?
Any help would be great
Thanks Connor
runthatsleeper is offline   Reply With Quote
Old 10-14-2015, 10:58 AM   #2
scott_0's Avatar
no, not unless you have something rubbing..........what headers?
Old 10-14-2015, 11:00 AM   #3
Pypes
Old 10-14-2015, 11:13 AM   #4
scott_0's Avatar
Originally Posted by runthatsleeper View Post
Pypes
hahaha oh boy, who did the install? does it effect the steering? if not, sounds like you have the issue I had with my first driver's side header, it was contacting the floor board under heavy load, was an awful vibration and roughness, they sent me a replacement, it didnt contact the floorboard, but instead hit the steering shaft, which was an easy fix, a couple washers under the driver's side motor mount. I suggest you climb under there and check for any where the headers may be contacting the chassis
Old 10-14-2015, 11:19 AM   #5
ok thank you i need to have a look now and mine also hit the steering shaft
Old 10-14-2015, 11:21 AM   #6
scott_0's Avatar
did you fix the steering shaft rubbing issue? if no, thats the issue man
Old 10-14-2015, 11:57 AM   #7
yes i fixed that right away because it was hitting so bad that i effected the steering so bad
Old 10-14-2015, 02:41 PM   #8
Jvibe92's Avatar
That's why you always buy headers with the best fitments. Things like this may happen.
Jvibe92 is offline   Reply With Quote
Old 10-15-2015, 10:31 AM   #9
thelastsumurai's Avatar
Now that your done criticizing his choice of headers. Lets try to help him.
I would suggest getting to a 4 wheel lift and standing under the car to see where is't rubbing. If you can't see it right away, try starting the car and duplicating sound while standing under the car.
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 10-15-2015, 10:45 AM   #10
Thanks for the help I need to find a lift next
Old 10-19-2015, 08:01 PM   #11
nicholasmadill's Avatar
Which headers have the best fitment, I'm planing on getting LTs also. Not sure weather I go with O/R X or cats though.
Sent from my iPhone using Mu
nicholasmadill is offline   Reply With Quote
Old 10-19-2015, 08:14 PM   #12
scott_0's Avatar
Kooks or ARH, I have heard a few complaints of fitment issues, but very few and far between, JBA's are a nice lower cost option, I've heard very few fitment issues from them, but for lowered cars, they hang down a bit more than the others
Sent from my S6 using tapatalk
Old 10-19-2015, 08:55 PM   #13
Yeah I'm planning on getting some. But also planing on lowering with eibach sport lines
Old 10-20-2015, 06:48 PM   #14
The_Chech's Avatar
I went the route with Kooks and they slid right in. I haven't had any issues what so ever.
2011 Kona Blue Gt
IG - The_Chech
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 10-23-2015, 08:14 PM   #15
Eleazer2's Avatar
Chech I'm installing Kooks headers tomorrow on my 2014 GT did you reuse the factory studs and nuts or did you use the stage 8 bolts that came with the headers
Eleazer2 is offline   Reply With Quote
Old 10-23-2015, 08:47 PM   #16
The_Chech's Avatar
I just reused the factory hardware I've had mine on for a few months and no leaks. I've just kept the new hardware invade I may need them some time down the road.
2011 Kona Blue Gt
IG - The_Chech
---------- Post added at 10:47 PM ---------- Previous post was at 10:46 PM ----------
What route are you taking to install them?
2011 Kona Blue Gt
IG - The_Chech
Old 10-23-2015, 08:55 PM   #17
Eleazer2's Avatar
I currently have JBA installed but I keep killing the upstream bank 1 sensor so Shaun at AED told me to ditch the JBA and go with Kooks so I bought the complete Kooks kit with off road X pipe and cat back. I have a lift at my shop I removed all the exhaust tonight left the headers on so I will have to remove those tomorrow I not removing my k member for the install. Did you have to install starter before putting on the passenger side header? The instructions say to put the starter on afterwards but from some post I've been reading the say you need to install the starter first.
Old 10-23-2015, 08:57 PM   #18
Eleazer2's Avatar
What exhaust are you running behind the kooks? You have a video?
Old 10-23-2015, 09:08 PM   #19
The_Chech's Avatar
The starter install with kooks is a pain it took me a bit to figure out which hand went were and what size extension to use to get it in. I've always installed the starter after the long tubes go in. You have to get the top bolt in on the starter blindly going in with only your hands to feel for it. IT SUCKS.... I had the Roush axle backs on with the reso's deleted but I'm not sure why but I kept blowing out the baffles inside the passanger side. I went through 2 set's of those before I switched to MBRP's 3" stainless steal set up.
I have a video on my Instagram that has a good clip of what it sounds like. I really miss the way it sounded on the interstate. It wasn't loud unless you went over 3k rpm's after that it sounded like a jet was trying to take off behind you.
Old 10-23-2015, 09:56 PM   #20
Eleazer2's Avatar
Send me the link
Old 10-24-2015, 09:01 PM   #21
hdez41's Avatar
I currently have jba longtubes and am lowered with eibach sport lines. Have had this setup for about 10k miles and no issues
hdez41 is offline   Reply With Quote
Having second thoughts on Long Tubes USMCSS 1996-2004 Mustang GT 12 02-09-2007 02:09 PM
*gauging interest* mac long tubes and catted h pipe... dark Mustang Parts for Sale and Wanted 7 06-12-2006 09:44 AM
long tubes kraz3y Pre-2005 V6 Mustang 14 03-02-2006 04:43 AM
v6 long tubes and h pipe joebadguy Mustang Parts for Sale and Wanted 10 10-26-2004 09:45 PM
long tubes? timpryor Pre-2005 V6 Mustang 18 07-04-2004 06:59 PM
02:55 AM
