Ditching eibach pro street junk. - Mustang Evolution
Old 10-14-2015, 02:11 PM   #1
grabber12's Avatar
Since day one the eibach pro street coil overs have been junk. Leaking then fixed, making noise then fixed and now making noise again. I'm going to replace everything! I am lowered and want to keep it that way and I also want a decent ride so what route should I go?
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 10-14-2015, 02:27 PM   #2
Grabber Blue5.0's Avatar
BMR everything with Strange adjustable shocks/struts. Done. Next question.
Old 10-14-2015, 02:32 PM   #3
grabber12's Avatar
Gonna look it up right now. Will the struts accept the gt500 strut mounts?
Sent from my SM-G920V using Mustang Evolution mobile app
Old 10-14-2015, 02:35 PM   #4
grabber12's Avatar
Right now I have no strut mounts. The coil over sits directly on top of my maximum motorsports caster plates. It has no rubber saddle and that's how the instructions said it should be. I'm thinking that might be part of the popping noise I'm hearing AGAIN!
Old 10-14-2015, 02:39 PM   #5
Jvibe92's Avatar
How are strange adjustable compared to koni is stiffness/stock feeling on the softest setting. I'm curious.
Jvibe92 is offline   Reply With Quote
Old 10-14-2015, 03:23 PM   #6
grabber12's Avatar
I recorded the crazy *** noise. This is nothing compared to when I'm driving. https://youtu.be/4I8T_BNOSgQ
Old 10-14-2015, 03:28 PM   #7
grabber12's Avatar
The car has 12700 miles. I just drove it last week on a 150 mile trip. on the 150 mile trip it was perfectly fine, no noise. I decided to take the Mustang out today and stretch her legs and the noise appeared as soon as I left my driveway. This may not be eibach but guys I know with just springs and not coil overs tell me they have never had an issue. With mine it's every 3000 miles.
Old 10-15-2015, 12:15 AM   #8
grabber12's Avatar
So I took the entire unit off the car. Inspected everything and didn't notice anything out of the ordinary. The stock strut mount bearing was used with the maximum motorsports CC plates and it does have some play in it but it had play on the stock unit and made no noise.
Old 10-15-2015, 09:13 AM   #9
k1DBLITZ's Avatar
I am looking into the Steeda Coil Over Kits when I pull the trigger...any reviews/opinions?
http://www.steeda.com/2011-2014-coilovers/
It says: The front coil over system is designed to use our exclusive upper strut mount kit which eliminates the weak factory upper spring perch which is prone to “popping” with increased spring rates and provides +/- 1 degree of camber adjustment not available with the factory mount.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 10-15-2015, 09:15 AM   #10
k1DBLITZ's Avatar
Listening to that video made me cringe.... sounds like metal on metal.
Old 10-15-2015, 10:46 AM   #11
Fabman's Avatar
I am very surprised to hear this.
I have been using all Eibach stuff for decades and have never had a problem.
I wonder what happened in this case?
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 10-15-2015, 10:54 AM   #12
Beviking's Avatar
+10 on that! WTH!?! You're not playing with us are you? Noise like that seems like you could find it real quick!
K1, sounds like you have to purchase the Steeda strut mounts also, unless they come with the kit? I bought them after I lowered the car and like other Steeda parts, just awesome!
Beviking is offline   Reply With Quote
Old 10-15-2015, 11:19 AM   #13
Fabman's Avatar
Jesus dude, something is loose big time.
Shouldn't be hard to figure that one out.
Tuned by AED
Old 10-15-2015, 01:02 PM   #14
grabber12's Avatar
Update: I worded one of my posts a little wrong. The MM caster plates uses part of the OLD strut mount. The front springs DO sit on the stock sadel (very thin). But anyways like I said I took the entire coil over out, checked it out, removed the spring, took the cheap factory plastic bearing out and Inspected everything (all ball bearings still there). During the removal of everything all bolts were tight. Installed it back on the car and the noise is gone! LOL. So I don't know guys.
Old 10-15-2015, 01:14 PM   #15
grabber12's Avatar
Here is a picture of the stock spring purch that's replaced but the MM caster plates. Notice that the stock bearing that's known for failing is still used. When I bought the caster plates I thought for sure I was junkies the factory junk but the instructions says clear as day to reuse the crap parts. So in eibachs defence this time it may not be on them. But that's still undetermined.
---------- Post added at 02:14 PM ---------- Previous post was at 02:13 PM ----------
Old 10-15-2015, 01:21 PM   #16
Fabman's Avatar
That's why we don't blast vendors until we are "sure".
Glad it's starting to work out for you.
Tuned by AED
Old 10-15-2015, 01:36 PM   #17
grabber12's Avatar
Like I said before and have posts about eibach problems and leaking. Then they wanted to charge me more money to fix it then a NEW coil over. So I have all the right to blast them. They took there sweet time while they had my shock as well.
Old 10-15-2015, 08:17 PM   #18
Beviking's Avatar
All I can think of when you mention the stock bearings in those mounts is canning jar lids being formed to make those. One of mine pulled apart in my hand upon removal. I also thought I could swap the ball bearings with bb's if I had to. Definitely not a strong point for ingenuity or longevity. Cost savings? I'd guess right up there!
Definitely stinks to get the runaround or seemingly put off by any company you patronize.
Old 10-15-2015, 08:27 PM   #19
grabber12's Avatar
Just got out from under the car and was making sure it's not a ball joint etc. Guess what I see! Passenger side eibach looks to be leaking. It's not a whole lot of oil but it sure wasn't nice and clean like the other shocks on the car.
Old 10-15-2015, 09:08 PM   #20
I'm hoping I don't have this problem. I'm almost done installing my suspension, and also have MM CC plates.
Old 10-15-2015, 09:11 PM   #21
Fabman's Avatar
I have the MM plates on my car as well. I didn't have to reuse anything from the old struts so I'm not sure what differs in the installation, but mine are perfect.
Tuned by AED
Old 10-16-2015, 09:36 PM   #22
grabber12's Avatar
Fabman what bearing did you use? Your MM plates came with bearings? If so what part number plates do you have
Old 10-16-2015, 11:53 PM   #23
Fabman's Avatar
I have a 2006 so maybe it's different but I just ordered the part for my year and it all went swimmingly.
Tuned by AED
Old 10-17-2015, 03:53 PM   #24
Fabman's Avatar
Here you go:
Maximum Motorsports Mustang Caster/Camber Plates MM5CC-1 (05-10 All; 07-14 GT500) - Free Shipping
Tuned by AED
Old 10-17-2015, 04:04 PM   #25
Beviking's Avatar
Do coil overs span 05-14 unlike the stock struts for 05-10 and 11-14 where you have be sure to get the corresponding year strut mounts?
I don't think these would come apart if I hit them with a hammer!
2011-2014 Mustang Parts | Steeda Autosports | Free Shipping! Also made for 05-10.
Old 10-17-2015, 04:21 PM   #26
Fabman's Avatar
Link is to a directory....
Tuned by AED
Old 10-17-2015, 05:17 PM   #27
grabber12's Avatar
Fabman: mine looks very similar to yours expect mine does not have the silver disk's. Is that silver disk a bearing? here are mine. Maximum Motorsports Mustang Caster/Camber Plates MM5CC-6 (11-14 GT, V6, BOSS) - Free Shipping
Other then the second leaking coil over (Eibach) in 1 year im good. The noise is gone all the sudden but never found what it was.
Old 10-17-2015, 05:40 PM   #28
grabber12's Avatar
For some of you following this problem with Eibach here is a post of my first issue. Im not the only one saying they leak. I will provide you guys with the link to my old post that states both my front coil overs were leaking and here we are 1 year later and yep still problems. Ok im done crying, its only money right lol Eibach strut leaking
Old 10-17-2015, 07:03 PM   #29
Fabman's Avatar
The disc is a spring perch. I'm using the stock size springs. Looks like the bearing is in that CC plate from the picture, but it's hard to tell. I can't imagine them not supplying them.
---------- Post added at 08:03 PM ---------- Previous post was at 08:02 PM ----------
Yeah, leaking sucks. I wouldn't put up with that either.
Tuned by AED
Old 10-17-2015, 07:14 PM   #30
Fabman's Avatar
I read the instructions and I didn't see anywhere where you re use the bearing.
The new bearing is in the new plate. Why did you feel the need to reuse any old parts?
Did it say so in the instructions?
Tuned by AED
Old 10-17-2015, 08:59 PM   #31
grabber12's Avatar
Fabman: On my #15 post I put up a picture. If you see on the instructions it says to use the stock spring perch. My stock perch has a plastic bearing that also get reused. There is no other way around it unless there is an aftermarket bearing that's not housed in plastic like the cheap OEM one. I know guys use the GT500 strut mounts because of the upgraded bearing and thicker spring saddle but the gt500 style for stock style springs and from what I've gathered it wont work for my coil overs. As if right now if the suspension isn't popping or creaking then its leaking hahahaha. I really don't want to buy a new setup but gosh. I'm in the market for a Circle D converter, not a redo on the suspension.
Old 10-17-2015, 09:06 PM   #32
Fabman's Avatar
We must be talking about two different things. That pictures shows a strut top with the spherical bearing in it where the shock goes through. That's the part that fails in the old style like mine. I don't know what's different in yours but there is a picture of a strut top with the bearing installed in your pic of the instructions, So I guess I am lost here.
Tuned by AED
Old 10-17-2015, 09:09 PM   #33
grabber12's Avatar
here I found the link to the instruction so you can see what gets reused. click the link then scroll all the way down to step 19. How to install Maximum Motorsports Caster Camber Plates on your 2011-2012 Mustang | AmericanMuscle
Old 10-17-2015, 09:15 PM   #34
Fabman's Avatar
That is definitely different than what I have....
Tuned by AED
Old 10-17-2015, 09:16 PM   #35
Fabman's Avatar
check it out.
How to install Maximum Motorsports Caster Camber Plates on your 2005-2009 Mustang | AmericanMuscle
Tuned by AED
For Sale: FS: Eibach Pro Street S coilovers Oh2freshstang Mustang Parts for Sale and Wanted 11 08-25-2014 08:43 PM
Ditching my Metra double DIN dash kit InfinibandGT 2011-2014 Mustang GT 12 05-08-2014 10:13 AM
Eibach Pro-System-Plus vs. Eibach Sport-System-Plus MustangGT02 1996-2004 Mustang GT 15 01-12-2013 02:45 PM
Ditching power steering? Stang.racr 1979-1995 Mustang GT 4 08-24-2011 02:36 PM
Eibach Pro Street S System??? fasternu_674 Pre-2005 V6 Mustang 1 01-05-2008 10:24 AM
03:23 AM
