Nitrous kit question - Mustang Evolution
Old 10-18-2015, 07:33 PM   #1
UrMaster's Avatar
Probably picking up a NX plate kit this week. I have lu47 injectors ,full header back off road exhaust and ported boss Intake with jlt and a 5c converter. E85 tune by AED. My question is if I run a 100 shot am I going to need a boost a pump or will I be fine? I'll be getting a nitrous tune from Shaun for the nitrous. What about if I step it up to 125 or 150 shot? Wouldn't go any more on a stock motor anyways.
Sent from my SM-G928V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 10-19-2015, 10:38 AM   #2
Jvibe92's Avatar
You don't need a BAP imo. If you did Shaun would of said something but it just an insurance thing. I wouldn't worry about it unless you go over 150
Jvibe92 is offline   Reply With Quote
Old 10-19-2015, 11:11 AM   #3
UrMaster's Avatar
Yeah haven't even asked him about it. Didn't even think to until now. Wasn't gonna hit him up until I have the kit and everything and ready for the tune.
Old 10-19-2015, 06:04 PM   #4
Konawin's Avatar
I'm interested in the answer. I have nearly your identical set up and when I asked Shaun if he'd tune me on nitrous he said he'd only tune a direct port kit.
Konawin is offline   Reply With Quote
Old 10-19-2015, 06:41 PM   #5
UrMaster's Avatar
That's weird, told him today I was doing a plate kit. He said he could tune up to 150 on e85 and 100 on 93.
Old 10-19-2015, 07:18 PM   #6
Rapinator126's Avatar
Surprised he is going to tune a NX plate. He used to only do a hardlined plate kit or a direct port. The NX plate is notorious for having a lean spike on the hit.
🍼and 🌽 fed coyote.
Old 10-19-2015, 11:24 PM   #7
Jvibe92's Avatar
Yeah he'll do a plate kit on e85 for sure. I've spoken to him a lot about it. Direct port is best imo. I think it costs like 300$ to drill/plumb your intake manifold.
Old 10-21-2015, 01:56 PM   #8
UrMaster's Avatar
Where can I get more info on that? Never heard about a lean spike in any kits.
Old 10-21-2015, 02:24 PM   #9
Jvibe92's Avatar
Yeah it's common on hit. You can talk to Shaun about it. Or just look it up via Google. It's nothing too bad. Just run e85 or 93 with some race gas
Old 10-21-2015, 05:03 PM   #10
My word not good enough. That's fine with me also lol
🍼and 🌽 fed coyote.
Old 10-22-2015, 08:19 PM   #11
UrMaster's Avatar
So do I really need a different tune for a wet plate kit since the kit add fuel? Can't I use the handheld to remove some timing instead of paying yet again for another tune?
Old 10-22-2015, 08:25 PM   #12
What shot were you planning on running?
And depends if your tuner left the tune software itself unlocked.
🍼and 🌽 fed coyote.
Old 10-22-2015, 08:34 PM   #13
Old 10-22-2015, 10:26 PM   #14
UrMaster's Avatar
100 shot on e85 for the moment.
Old 10-22-2015, 11:59 PM   #15
Jvibe92's Avatar
There's more involved then just taking a couple degree of timing off. I'd get a nitrous tune. 100$ through Shaun
Old 10-23-2015, 03:41 AM   #16
Lets not get to technical here it's a 100 shot buddy.
🍼and 🌽 fed coyote.
---------- Post added at 03:41 AM ---------- Previous post was at 03:40 AM ----------
Me I would run it.
Advice I would give someone else is to get it tuned to be safe
🍼and 🌽 fed coyote.
Old 10-25-2015, 08:45 PM   #17
MarkCoyote's Avatar
Do you need an after market CAI for a plate kit
MarkCoyote is offline   Reply With Quote
Old 10-25-2015, 08:47 PM   #18
No the cai has nothing to do with the kit.
🍼and 🌽 fed coyote.
Old 10-26-2015, 04:03 PM   #19
Jvibe92's Avatar
Random question time:
The main point of nitrous is to never bounce of the rev limiter while spraying or between shifts correct?
Short shifting on nitrous would be bad huh?
Old 10-26-2015, 04:13 PM   #20
That's why you have the nitrous shut off b4 your set limiter.
🍼and 🌽 fed coyote.
Old 10-26-2015, 06:11 PM   #21
Jvibe92's Avatar
I know that part; the window switch; but what about In between those ranges.
Old 10-26-2015, 06:39 PM   #22
Not sure what your asking here.
🍼and 🌽 fed coyote.
Old 10-26-2015, 07:22 PM   #23
Jvibe92's Avatar
Too tired to explain haha. Pretty much, is it dangerous to shift in the middle of a nitrous pull. Say 6k rpm? I know from my best logs, I never fully lift off the pedal. I usually stay on it like 30-40 degree of throttle.
Old 10-26-2015, 07:35 PM   #24
No it's fine.
🍼and 🌽 fed coyote.
Old 10-26-2015, 07:35 PM   #25
UrMaster's Avatar
In trying to see where I should have the car shift at on the juice. Got a nos window switch and he and it set to come on between 4k and 7k. He's manual on a stock intake though. I have the boss and an auto but I'm nervous to spray it to 7500rpm. Would it be better to have it shift at 7000 or keep it at 7500, or have the spray shut off after 7000 and come back on after a shift?
Old 10-26-2015, 07:41 PM   #26
Have the spray come on at 3k and shut off right b4 it shifts.
🍼and 🌽 fed coyote.
Old 10-26-2015, 09:43 PM   #27
UrMaster's Avatar
🍼and 🌽 fed coyote.
What like a couple hundred rpm or so? What's the most rpm these motors can be sprayed safely?
Old 10-27-2015, 10:31 AM   #28
You can spray from 3k to 7500, stock with a 100-150
🍼and 🌽 fed coyote.
Old 10-27-2015, 01:47 PM   #29
UrMaster's Avatar
Where's a good place to find mapping for e85 and 93 with the NX coyote kits ?
nitrous
Running a bigger shot of nitrous / NITROUS GUYS Jsmorley81 2011-2014 Mustang GT 5 02-14-2014 01:31 PM
ZEX 82015 Dry Nitrous Kit For Sale-Texas downtime Mustang Parts for Sale and Wanted 7 04-19-2006 12:00 PM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 12:43 PM
WTB: Nitrous kit Monkey Mustang Parts for Sale and Wanted 3 01-16-2005 08:14 PM
a must for anyone buying their first nitrous kit tire The Bar 6 02-16-2004 02:27 AM
10:45 PM
